Goodman U-30 Furnace
I have a Goodman gas furnace Model U-30. Electric Ignite. Went to turnit on for the first time this year. When setting temp on thethermostat, you can hear it click, but no fire. Followed instructionson door to turn off all electricity to it, turn gas off, wait 5minutes, turn gas back on, turn all electricity back on it. Still won'tlight. The only thing I hear is a humming noise from the unit itself. We didnot turn the gas off to it last year so I don't think it is off. Afraid to mess with that myself.
  • anotherday Oct 25, 2008
    This is actually a GMP075-3 Model. Sorry about that.
    Also, the red light is blinking 3 times. I don't have a code sheet.
    Novelist:
  • 124 Answers
Observe the sequence of operation. stat calls for heat and sends a signal, to furnace. check for 24 volts to common and white wire at furnace.first the forced draft motor starts and should have 120 volts to the plug it attaches to. after forced draft motor starts the pressure or vacuum switch closes should show no 24 volt when checked across terminals. shortly after the ignitor glows and shortly after click the main gas valve opens and main burners fire. shortly after the indoor fan comes on and hot air blows into the ductwork. follow the chain of events to see what doesnt happen and it is a clue to whats broke. maybe start by switching fan switch on stat to on. if fan comes on you have high and low voltage thereby eliminating the stat power and transformer as a problem. if you can see the ignitor look for it to be cracked . look close dont touch any part of it .it is powered by 120 volts when energized from board. dont forget when you take the door off there is no power to the furnace so be prepared to tape the safety switch closed when you are diagnosing.
Posted on Oct 24, 2008
Arcoaire furnace ran out of propane and now wont ignite
Check along the gas supply line to the furnace and make sure there isn't a valve that is shut off. If you have a gas oven see if the ranges light and have gas. I'm assuming you've also turned on the gas supply at the furnace itself as well. Check that the furnace has electricity it won't be able to open the automatic valve let alone fire the igniter. My brand new furnace had a safety switch that went out 3 days after installation preventing it from lighting. You might contact Arcoaire about that. http://www.arcoaire.com/
Dec 23, 2013 | Ovens
Problem with Goodman furnace electric ignition
Power is there, or no lights would blink. Steady blinking or flashing three times, stop, three times Etc
Nov 23, 2011 | Goodman Heating & Cooling
The Goodman Heater was installed in 2004. Thermostat set at 75F, the fan that blows CO2 out was on for about 1 minute, then I could hear the sound of the gas blowing into the furnace, but the ignitor...
Problem: Your furnace will not ignite the gas to produce heat for your home. When a furnace has a bad ignitor what I see most of the time is the following sequence of operation:
1. Thermostat calls for heat. 2. Draft inducer motor starts. 3. Pressure switch attached by a small plastic or rubber tube senses the negative pressure produced by the draft inducer and closes. 4. Draft inducer runs for 30 seconds to a minute before you hear a gas hissing sound. The ignitor did not glow, the flame sensor (a small metal probe about 1/8" in diameter, with a white porcelain base) does not sense the flame, so after 8 to 10 seconds the hissing sounds stops with no ignition of gas to heat your home. Your furnace shuts down and goes into a lock out condition until you turn your power switch back off and on again. Then the sequence starts all over again with no ignition of the gas. Solution:You probably need to purchase and install a new ignitor. I would suggest that you inspect your ignitor closely for cracks. Make sure you do not touch the ignitor with your bare hands. If you do not visually see a crack, then you could have a furnace control board problem or a limit, rollout switch problem. The furnace's control board might not be supplying the voltage to the ignitor. If your furnace lights and the gas stays on for 8 to 10 seconds, then shuts right back off, then you need to clean your flame sensor with light sand paper or steel wool. You might need a new flame sensor, but most of the time they can be cleaned an will work well after cleaning.
Nov 30, 2010 | Goodman GMS80903BNA Heater
Goodman furnace model # GMNT100-4B On vacation, neighbor checked house, house filled with gas. He shut off main and furnace. came home turned on gas to everything except furnace. All good. Furnace will...
Solid red typically means bad controller. Try unplugging the furnace, wait about 30 secs, then plug it back in. The possibility that the controller was sending voltage to the valve even when there was no flame is a bad sign. If the controller starts the furnace, watch it very closely and see what it does. If the solid light comes back on, it's time for a new board.
Mar 24, 2010 | Goodman GMS90703BXA Heater
My gas goodman heater will not ignite.
It is probably not the glow coil, if this is a 80% regular
furnace, Make sure the induced draft blower is working. I once went to a house where I came across
this problem, the only difference is that it would acutually start and then shut off. I took the vent apart
at the furnace and found a bird that was preety cooked.
If this is a90% High Eff. furnace, make sure the pvc
vents are not plugged. To troubleshoot the intake
Vent. Remove the combustion plate and then turn
the unit on, if it runs you have a problem with the
intake vent.
You could temp. remove the exhaust vent and then turn on the power if it runs then your exhaust vent
is probably plugged. You could go outside and make sure the vents are free.
Make sure you have gas available, these are the most commom issues that could solve your problem
Jan 14, 2010 | Goodman GMS90703BXA Heater
I'm considering installing a Goodman LP Gas Furnace:sizing? Ops?
Gerge, if you go to website www.energycodes.gov
you can do a heat load calc yourself. Basically, you figure out the sizes of walls, total area of glass. total doors to outside, ceiling area and types of building materials used. It is pretty easy and then you will know for sure. The contractor should be suppling you with one but if not use this, it is free!
Nov 03, 2009 | Goodman GMS90703BXA Heater
Furnace starts properly, then shuts down, led flashes 8 times
The first thing to look at is the flame sense rod.
Shut off power to the furnace, remove, clean sensor with steel wool or sandpaper then reinstall the sensor. Reapply power and it should run properly.
Jan 10, 2009 | Goodman GMS90703BXA Heater
Goodman GMS90904CXA Wont ignite, light blinks 3 times
I had the same problem, I had to remove the lower black rubber stopper right next to the exaust fan and hook up a drain to the unit, as soon as the water drained out the furnace fired right up.
Nov 19, 2008 | Heating & Cooling
Heating & Cooling Logo
340 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
