Question about Dishwashers
How to remove a thermal fuse from whirlpool dishwasher
  • rbhome Feb 13, 2012
    what is your model #? Most thermal fuses are mounted in the control panel, so you have to unscrew the top of the door to remove the top panel.
  • Vicky Feb 14, 2012
    Where would you find the thermal fuse on whirlpool dishwasher model du900pwkq0?
  • 37 Answers
SOURCE: Whirlpool dishwasher first 5 years ok last year
Your drain is gummed up and it may be the hose too. First remove the trays. Then, clean out everything from the bottom of the inside dishwasher pan. Also clear the drain hole in it. BE CAREFUL THAT YOU DO NOT CUT YOUR SELF ON ANY BROKEN GLASS THAT MAY BE IN THE BOTTOM. Next, go under your sink (or where ever the hose hooks your dishwasher into your drain) remove the hose and clean around both sides of the connections (be sure to replace it exactly how it was to prevent leaks-also check for leaks during and after your first test run). Lastly, run the washer empty using only 1/4 of vinegar. Hope this helps!
Posted on Mar 16, 2009
jumptrout51
  • 3361 Answers
SOURCE: causes of a blown thermal use and a whirlpool gold dishwasher
Your lint vents in the dryer are clogged.
Your connecting vent on the rear is clogged.
Your through the wall vent is clogged.
Could be any one of these problems or a combination of these.
In any event, you have poor air flow.
Posted on Apr 02, 2009
  • 112 Answers
SOURCE: where do you get a thermal fuse for a whirlpool
try your local appliance repairer centre or google the makers website...they will send or tell you of local stocker of service parts.
Posted on Jul 24, 2010
  • 557 Answers
SOURCE: I have a Whirlpool DU1055XTSS
water is getting on the wiring somewhere, take it apart right after a cycle and see if you have a door leak, or the motor is going bad
Posted on Oct 20, 2010
ginko
  • 19396 Answers
Hi.
If the thermal fuse is blowing, that means that there is overheating.
Common causes for overheating are:
Thermostat cutting off too late.
Plugged element.
Plugged element means that the element stays always on because of a contact. Usually you can realize if the element is plugged. Problem concerns wiring, for this reason I mentioned even if element was replaced. I do not think that this is the problem.
Second common cause is a thermostat cutting too late, or completely shorted. Consequence will be overheating. Problem is different to find out by testing, as thermostat must be tested reading impedance at different temperatures. If thermostat is shorted it will never open.
Replace the thermostat, that will probably fix the problem.
Here part:THERMOSTAT (Hi-Limit Thermostat)
Thermostat is part 30 in diagram below, click on the picture to enlarge:
If you repute my solution helpful, then please take some times to accept the solution. Providing good repair tips requires time and skills, and your feedback is important for us.
Regards.
Ginko.
Whirlpool Point Voyager Dishwasher blows thermal fuse - pump motor draws 10A
Yes 10amp seems a lot of current being drawn by the pump motor. Not sure if it is safe to run dishwasher in this condition. One reason could be a leaky capacitor on the motor. Try to replace it. See item 26 on http://www.searspartsdirect.com/partsdirect/part-model/Whirlpool-Parts/Dishwasher-Parts/Model-GU1500XTLB0/1198/0130000/W0503069/00008
Apr 04, 2014 | Whirlpool Dishwashers
Why thermal fuse is blown
If you have no power to your machine and the power is on it is the thermal fuse. If the fuse is blown you will get no power at all. To my understanding after talking to many people the thermal fuse is likely the first thing to go bad on a whirlpool dishwasher. A power surge to your unit would cause the fuse to blow or the control board to go bad.
Jan 13, 2013 | Whirlpool 24 in. DU1100XTPS Built-in...
My dishwasher will not run. None of the lights are on. The D/W ran fine a few days ago. Nothing has occurred. Checked fuse box and there has been no disruption of power. The model # is GU 1500 XTL 83....
The most probable thing wrong is a THERMAL FUSE that is clipped to the control panel housing.
If your fairly mechinacally inclined and want to check that,remove the screws from all around the inside of the door when its opened,seperatae the inner/outer door panels and remove the cover off the control board and check for contunuty on the thermal fuse. THe first thing to do before taking apart the door is TURN OFF POWER TO DISHWASHER AT THE FUSE PANEL.
the part number for the thermal fuse is 8193762 it could be purcahsed at your local appliance parts store or online at;
repairclinic.com
apwagner.com
apdepot.com
partselect.com
Gene
Aug 26, 2011 | Whirlpool Dishwashers
No front panel lights Whirlpool GU2500XTPB1. Power to dishwash is good.
what most likely is going to be the problem is a blown thermal fuse that attaches to the control panel housing. gain access to the control panel and use should see the thermal fuse,the housing for the control board is grey and this part is white.Remove the wires to it and check for contininity on it (ZERO OHMS) using a ohm meter set to a low ohms setting. If it turns out to be good the next thing to check is the switch(s) on the latch asm using the same method to check them as the fuse.BEFORE CHECKING EITHER OF THOSE BE SURE TO DISCONNECT POWER TO THE DISHWASHER
Aug 07, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool DU1055XTSS dishwasher is totally dead as if it were unplugged. No response from front lights. Only 3 years old. Another post for an different Whirlpool model says it's the thermal fuse, but I...
If you have power going to the dishwasher, meaning the breaker, switches, wiring and fuses in the home are okay, the most common cause for your symptoms is the thermal fuse.
The thermal fuse is a small disk shaped device that is behind the control panel on the right side it is snapped on to the electronic module. The part number for your model is W10258275
Jul 24, 2010 | Whirlpool DU1055XTS Built-in Dishwasher
No power going to front panel on whirlpool dishwasher gu2455xtsso
If the model number you listed this question under is correct, there is a thermal fuse (also known as a bi-metal) located inside the control panel of the dishwasher. The part number for the thermal fuse replacement is W10258275.
If you type in your model number you can utilize the exploded view parts diagrams at pcappliancerepair.com, appliancepartspros.com or searspartdirect.com to assist you in locating the part. The fuse is listed as item 6 under the "Control Panel Parts" section.
To replace the fuse, follow these steps:
1. Make sure the dishwasher is unplugged or the breaker is turned off.
2. Open the door and remove only the top screws directly behind the control panel.
3. Remove the protective cover from back of the control panel to expose the main control board.
The thermal fuse should be mounted to the control board. If you remove it and take a resistance check, it should read close to 0 ohms, if good. If bad, replace as necessary.
If you have any questions about this repair, or require additional assistance, please let me know. I hope this helps you.
Apr 23, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher not starting
There is a thermal fuse located in the control panel that is probably blown out.
Open the control panel by removing the 6 screws around the top inside of the door. The thermal fuse is located on the top right side. Remove the wires from the fuse. Use a volt neter set for continuity to test the fuse. No reading is a bad fuse.
This link will show the fuse.
http://www.appliancepartspros.com/part_details.aspx?part_id=3115186&rdr=%2fpartsearch%2fmodel.aspx%3fmodel_id%3d5162747%26diagram_id%3d914101
Jan 03, 2010 | Whirlpool 24 in. DU930PWP Built-in...
Whirlpool dishwaster quiet partner I - 5 years old
it could be bad thermal fuse or loose wires in jbox at bottom .to chkd therm fuse remove the screws the on top of the door holding the control panel.then pull out the panel and u should see cntrol board on the rhs of the panel.the thermal fuse is mounted on rhs corner of the control board.remove wires from fuse and chk for continuity.if open replace.if ok remove toe panel at the bottom and remove the screw of j box at rhs bottom corner.chk for loose or burnt wires.do not forgot to unplug the unit from power before doing all this.good luck
Aug 18, 2009 | Dishwashers
Whirlpool Dishwasher Not Working
Change the thermal fuse in the control and door switches. The thermal fuse is designed to fail if there is a problem with the switches.
May 17, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
Top Dishwashers Experts
