Konica 7022 f28-1 error
Unit has been unused/in storage for about one year. It was previously networked.
In trying to start the unit up, it does its self-check, the normal screen comes up, it begins to warm up, then it defaults to a F-28-1 code. In process of doing a thorough breakdown and cleaning. I have experience with Docucenters, but not with this brand.
Is F-28 a power supply error?
Is this related to network settings?
What can I do at start-up to reconfigure?
What should I look for when doing the cleaning?
  • 145 Answers
Check for arcing or poor connection. Check HV1 (p/n 26NA84011) connections and ground of HV, developing unit and the right side door HV casing for any arcing. Check PRDB (p/n 26TA-9021), CN27-4 for 24V DC while in idle or in the 47 mode w/o input.
....you may need a tech to clean all of the above first.
you need to clean and reseat the charge unit in the drum section.and transfer unit on the right side door
hope that help
let me know how you make out
Posted on Oct 25, 2008
My konica 7022 display on the screen f28-1 just today...how to fix it tnx.
Visual check the Charging corona Unit rear & front block look for burned cousing F28-1, then replaced Charging corona U.
Feb 13, 2015 | Konica Office Equipment & Supplies
I have a konica 7020 machine, the first copy comes with horizontal black lines but not the others (when copying e.g more than one copy)
1 look to the drum surface for scratch if their is replaced it. 2 the write unit might already defective. Damage drum will cause sparks to charging unit and Horizontal lines produce.
Dec 02, 2014 | Konica Minolta Konica 7020 7022 7025 7030...
Konica 7022 error F35-1
F 35-1 pertains to Abnormal Low fixing temp TH1. Try to clean the thermistor and reset the code by entering mode 25, software switch 3-1, make it zero. If the problem occur again, try to replace thermistor. Make sure that AC supply from mains is okay.
Aug 27, 2014 | Konica Minolta 7020 7022 7025 Copier Drum...
Konica 7022 26-3
Yes I stated what I recommended to do in your last post!
Jul 12, 2014 | Konica Minolta 7020 7022 7025 Copier Drum...
Copy of konica 7135 is unclear while running. at first is copy is clear, later the copy is not clear... blurred
try to make some copies from your pc if the results is ok that simply means something with your scanner unit, for exaple the pnnel needs to be lubricated and the ccd unit needs to be cleaned.
Mar 20, 2014 | Konica Minolta Konica 7020 7022 7025 7030...
Konica 7040 trouble code 51-4
This 51-4 code is directly related to the write unit. It can either be a bad lazer index control board mounted externally to the side of the write unit or a bad M5 polygon motor. It is better to replace the whole write unit. Konica P# 26WA-6500.
On a side note, the 7020 write unit can be used in place of the 7022 write unit & is far less prone to failure then the 7022 write unit! 7020 write unit Konica P# 26NA-6500.
Nov 07, 2012 | Konica Minolta Copier Toner 7033/7040...
Konica 7022 copier at start up says call service and shows F-35-3
The thermistor TH1 on the fuser unit is coming up as faulty this will cause your f-35-3 error you can reset it in service mode 25 dip sw3 0 to 1 however i do not do this as there is an issue i would replace both thermistors and look at the fuser unit for wear if in bad shape replace the fuser unit assembly
Jan 22, 2011 | Konica Minolta Office Equipment & Supplies
Error code f-51-6
this is your WRITE UNIT CODE.''''PRIT HEAD''''
you chould try to reseat all connectors ,and especially the write unit ,how handy are you?????
let me know
Oct 23, 2008 | Konica Minolta Di1610 Copier
Konica 7030 F-34-1 code
try to change the thermistor, if u confirm both the heater lamps is working.
the fuser unit from 7022 is not compatible with the 7020 machine.
May 29, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
490 people viewed this question
k24674
