Need thermostat wiring on pa5548aka6 heil no dia. inside unit
2 Suggested Answers
  • 4088 Answers
SOURCE: Need connector wires inside wand. Electrolux
Go to a store like Lowe's and look in their electrical department. You need wire the same gauge size (stranded or solid) and comparable insulation. Hope this helps!
Posted on Jan 10, 2010
Heil epm36f19a1 runs but no heat
Fan relay is stuck among other things. The thermostat turns on the combustion air fan and puts power to the spark unit. If the burner comes on after the temperature in the heat exchanger rises the indoor fan will then come on. After the thermostat comes to temperature the power to the gas valve which shuts off the burner. Then after the heat exchanger cools a bit the indoor fan will stop. That's the sequence of events. look at the switches that control the fans. There is a wiring diagram somewhere on one of the panels that access the unit for service.
Mar 06, 2013 | Electronics - Others
How long is the compressor in my heil max pro 10 waranty good for
Not sure which model number the Heil Max Pro 10 warranty uses. Heil will usally place the model number on the side of the outside unit or inside the cabinet for thee Inside unit. Click here for a direct link to=> Heil HVAC
Use care when reading any warranty because the wording is mostly written so you do not understand.
To help you decide which Heil product and warranty protection is best for you, select from the following at-a-glance comparisons.
Please let me know If I can help you with other question, Thank You, Sea Breeze
Aug 31, 2011 | Heating & Cooling
PR20 mic has three colored cables inside.. red black and yellow. the yellow has lost its solder. despite this it still works. what does the yellow cable do, and which prong inside should i re-solder it to?
Two of the wires are signal (1 is + the other is -). The third wire is ground. The two signal wires will go to either side of the mic diaphragm. (looks like a miniature speaker). The ground wire will usually go to the mic body. The colors could be proprietary to Heil so I'm not sure what they are based solely on color. If it's an "active" mic with an internal circuit board then there is no telling.
Typically the red and yellow would be the signal wires, the black would be the ground, however, as previously stated, this can not be guaranteed if Heil uses a proprietary setup.
Aug 23, 2011 | Heil Sound PR20 Professional Microphone
Hi - I have a Heil outside airconditioner unit - I had pulled out two wires from it and was wondering what those wires do and how to reconnect them - it was a thin black wire that had two wires coming out...
They probably come from the thermostat inside and go to the low voltage connections on the contactor in the outside unit. Those will be the connections for the coil in the contactor. Let me know if you have any questions.
Jun 20, 2010 | Heating & Cooling
I need to know how to rewire my heil air conditioner 6 wires are lose?? they are red white orange black red and purple!!!! Model number ph5036akb4
the wires at the thermostat????...this can be very tricky because the colors could mean nothing...every installer can wire it differently...if they used one continuous thermostat wire it's not too bad....you have to go down to your furnace and look in the fan compartment or wherever the thermostat wires enter the furnasce....generally a brown wire with 5 wires colored inside....find the wires where they connect to the furnace circuit board , terminal strip or fan centre and write down all wires and their corresponding terminals...for example...Red wire is on "R"white wire is on "W" and they may not match their color....thats ok.....then connect them at the thermostat accordingly////if you only have 4 wires you will require the jumper wire between RH & RC ...if you have 5 wires...remove the jumper or ignore that....good luck :)
Oct 31, 2009 | Heating & Cooling
I have an older sears and roebuck gas pack A/C unit that the electric co. put a energy cycler on. Since then the heat doesn't work and I need a wiring diagram to check the control wiring and get the heat...
This could be hard to find as Sears used other brands to put their name on. It could be a Heil unit. If the wiring diagram is not glued to the inside of the removable panel you could try taking the serial number to Sears and find out who made the unit and then download it drom the manufacturer
Oct 21, 2009 | Heating & Cooling
I need wiring manual for goodman mini split.
outside unit L1 and L2 are load (input 240vac)
then you have control voltage, usually yellow and blue (24vac) this connects to some 18/2 thermostat wire which goes inside as white and red.
note: this unit may only need 24v control which is 2 wires from the inside unit and also 3 wires 2 hot 1 ground for line voltage.
STANDARD WIRING
on the inside unit you have green, white, blue and red control wires.
on your thermostat you have white, red, yellow and green
you run the wire from the outside unit to the inside unit. then run a 18/4 wire to the thermostat if wired and join the following wires.
inside unit thermostat outside unit
green------------------------green
white-------------------------white
red----------------------------red
blue-------------------------------------------------------blue
yellow--------------------yellow
Oct 08, 2009 | Heating & Cooling
The outside unit is not working on my Heil Air conditioner
The attic fan is not a part of your a/c system, and you should not run it while you are running the a/c. If you are currently using the attic fan, it is possible that someone wired it so that the a/c won't turn on while the attic fan is on. Otherwise if the thermostat is set below room temp, and says it is calling for cool, then the problem is most likely coming from an issue at the outside unit itself. Make sure to check your fuses, at the fuse panel and outside breaker. Hope this helps
FYI.. the only part of the system that might use batteries is the thermostat.
Jul 28, 2009 | Heating & Cooling
I Am looking for heil NPA HC36 AKOL air conditioner wire diagram
You will need to contact a Heil distributor to get a wiring diagram. Or you can try a dealer but they probably won't help you fix your own unit. That would be taking money out of their own pockets.
Mar 10, 2009 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
