Question about Canon PowerShot SD10 / IXUS I Digital Camera
Won't work in shoot mode
Canon Digital Ixusi 4mp - works in playback mode but as soon as I switch to shoot or video mode the lens only comes out halfway then stops and the camera switches off. Can only get lens back in by turning on & off in playback mode. Battery is fully charged & I can review pictures previously taken.
  • rhiaandmerv Jan 20, 2009
    Have you been able to solve your problem yet?
    If so, are you able to share with me what the solution was?
    Thanks
philipp
  • 217 Answers
SOURCE: Canon G5 Lens error message
Defective mechanism, a stucked mechanism is present. camcorder are smart it can detects error and shuts down itself for safety. earlier models dominoes the defect if the user is not quick enough to react when something goes wrong with the camera. You need professional service to fix it.
Posted on Nov 12, 2007
old marine
  • 2016 Answers
SOURCE: I have a Power Shot
Check this link.
Posted on Jul 21, 2008
t00nz
  • 4738 Answers
SOURCE: My Canon PowerShot SD1000 shoots completely black
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Posted on Nov 07, 2009
issy2
  • 460 Answers
SOURCE: my cannon a430 is blind!!!! i can't see anything
This means the lens sensor is spoiled due to over exposure to heat. One has to give it to cannon service centre.
Posted on Jan 21, 2010
Testimonial: "Hi, thanks for the advice..but just wondering cause i seldom use it..i noticed a small dent on the portion near the lens ..can this be the trouble?"
  • 67 Answers
SOURCE: I changed the batteries in
Hi, 1st you must use alkline bat or minimum 800 mhp bat....
and if problem is not solved then cheak the bat cap and connection clean with aomthing,,,,
If any thing else contact me
Khatricamera@gmail.com
Posted on Mar 27, 2011
Playback switch does not operate
PDF]Camera User Guide
gdlp01.c-wss.com/gds/7/0900011217/01/PSA520510CUG-EN.pdf
Switching between Shooting and Playback.....32 .... Please note that Canon digital cameras are intended for personal use and should never be used .... Do not operatethe flash with dirt, dust or other items stuck to its lens. ..... PowerShot A520:.
Repair tips for digital cameras that won't power on. 'Do It ...
camerarepair.blogspot.com/.../simple-fix-for-dead-cameras-that-wont.ht...
Nov 30, 2007 - It was a fix for a Canon A520, but am not sure if it would work for ..... I have a Canon Powershot A540 which will not turn on and lens is stuck out extended.... (even when they are new) in camera mode and not playback mode.
Digital Cameras - Canon PowerShot A520 Digital Camera ...
Dec 02, 2015 | Canon PowerShot A520 Digital Camera
My camera will turn on then go off and the lens will not go out how do i fix this?
The manual is a bit confusing. I do have a power shot, but is is a bit younger. My camera does have 2 On buttons. One to put it in shooting mode. And one to set it in display mode. If I press the display button (arrow right) the lens stays where it is and I only can see pictures I took. When I press the on off button the lens comes out.
I think you only have to switch the main dial to the camera logo (shooting Mode) and then press the Disp button, to shoot pictures and if you want to view pictures, you turn the dial to playback Mode (arrow to the right) and press the Disp button.
If it works, no fix, just knowledge about how the camera works. It is all in the manual.
Jan 14, 2014 | Canon PowerShot A520 Digital Camera
Canon powershot only boots in playback mode
You could try to help the lens coming out if you hear the motor trying to. Or hold the camera with the lens downwards to let gravity help as well. Hope that will help. Or the lens mechanism will be faulty and the whole lens needs to be replaced. But such a repair might not be worth it because of the costs and the value of the camera.
Jan 04, 2014 | Cameras
Hi, I have a Canon Powershot A700 digital camera and I am facing a problem with it. The 'Mode Switch' button, which changes the mode from Shoot/Record mode to Play/View mode is not working....
If you have the manual for this camera turn to page 15.
This tells you how to switch between Shooting Mode and Playback Mode.
This is achieved simply by pressing the DISP button.
This button is located below and to the left of the FUNC/SET button.
Pressing DISP repeatedly toggles between Shooting Mode and Playback Mode.
I would suggest you try these steps with your Mode Switch in both positions alternately.
May 20, 2011 | Canon PowerShot A700 Digital Camera
Shooting/playback mode switch
in the end it was my memory card which suddenly went faulty.after formatting it, (see above added comment) it worked for some pictures then i switched to playback and this time it said memory card error and shut down. well if it would have said this in the first place would have saved a lot of trouble i almost threw the thing away.(the camera) so i puts a new card inside and its working like new, all the playback i can handle. goes to show its not always as bad as it looks with a little patience.....merci
Feb 27, 2008 | Canon PowerShot A520 Digital Camera
My A75's not functioning
Hey your change over switch is faulty you nee dto replace it. Sangita
Jul 08, 2007 | Canon PowerShot A75 Digital Camera
Not Switching between Shooting and Playback
well depeneding where you live, you should call canon and find out where the nearest canon store and you can also ask them how costly the repairs will be... i doubt very much seeing as it is an internal problem... but ask just the same...:D
Aug 29, 2006 | Canon PowerShot A75 Digital Camera
Can't take pictures or videos
The lens block appears to be defective. If you need this pl.let us know further.
Aug 07, 2006 | Sony Cyber-Shot DSC-S40 Digital Camera
Canon PowerShot SD10 / IXUS I Digital Camera Logo
21 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
