Question about Crosley CR78CD-P CD Shelf System
CD PLAYER WILL NOT SLIDE OPEN - Crosley CR78CD-P CD Shelf System
DVD stuck in DVD player
Does it have a door or is it an open end where one can slide the dvd in (kind of like a car cd player). Either way you will need a card. Door method: slide card in over top and try to maneuver dvd to original spot, try eject in-between tries. Open end method: like car cd players or Sony's PS3 system then you will need to slid card into drive above dvd/game/cd and press pressure on top of disk and the automatic rollers should catch the disk.
Sep 17, 2012 | Alba Televison & Video
When I press "open" for the cd player to open on
Hi, if you know which way the door opens somtimes it is possible to gently slide the door in the direction it needs to go in. If not you may have to disassemble to reattach the rubber band that drives the door ( which is more than likely what the noise your hearing is.) I hope this provides some help. feel free to ask again for help disassembing, maybe provide model number and such. So good luck and thanks for asking FixYa. Prodzilla
Apr 13, 2011 | RCA Alarm Clock w/CD Player, AM/FM Stereo...
Where do you insert the battery on the D-EJ011 Sony walkman portable CD player
Slide OPEN to open the player lid and open the battery compartment lid inside the CD player.
Feb 19, 2011 | Radio Communications
I have a kenwood dp-r99 cd player and the cd is stuck inside with an ee message. How do I open the CD player?
6 or 7 phillips head screws. 2 or 3 across the back and two on each side. Slide the top towards the back then up. You will be able to get to all CD's with the top off. Hope this helps
Nov 07, 2009 | Kenwood CD-206 5-Disc CD Changer
Cd cover doesn't open
Fiddled with it, looked at hinges to figure direction should open and pulled it slowly open. Button doesn't work but I can open/close unit. Just flips up from the front edge, doens't slide back or anything.
May 13, 2009 | Sharper Image GM402 CD Shelf System
Door to load cd's wont open or close without help.
hello i have had the same problem with my 5 cd changer,i way i solved this was to turn the player top slide down then do this care fully ,shake it gently and see if a cd came out of it, groove sit in the player.if you hear a rattle than there is a stray cd in the device. you have got to shake the cd to the front of the cd dawer to take it out with a thin ruler or a butter knife but be care ful with the knife preess on the open button wale trying to slide the butter knife between the stuck cd and the inside of the cd sit cation be care.
Apr 25, 2009 | Audio Players & Recorders
Cd player wont open
Grab a paperclip straiten it out and carefully slide it into a small hole on the front of the cd-rom drive until it pops out.
If I'm being too literal then I suggest opening windows media player and playing the cd with that. I think after Windows XP Micro$oft got rid of the cd player or buried it in the windows system folders
Post back with more Data if not successful.
Sep 27, 2008 | Computers & Internet
Old CD player (25 years!) is stuffed. But can't retrieve CD in drive. Open/close button works but no reaction. Can I force it mechanically?
usually in the front face of cd player drawer is a small hole
a straightened paper clip pushed in the hole will unlock the drawer and let it slide forwarw manually to remove the cd
May 03, 2008 | Televison & Video
My 6 disk CD player is in the eject mode(front open no disk in 1 slot but won't load)
Get a boyfriend - they know how to fix this stuff. Especially an Hispanic. It may be that there is a disk already in it. If not, the motor on the CD player is bust or the laster is trashed. Either way, it needs repair if there is someting stuck in it. Cellphones with MP3 and in ear headphones have good sound to get you thru work traffic and home again
Apr 11, 2008 | JVC KD-G230 CD Player
Tray won't open
there is probably something stuck in there like another cd that is causing it not to open
Aug 08, 2007 | Philips DVD793CH Multi-disc DVD Player
Crosley CR78CD-P CD Shelf System Logo
62 people viewed this question
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
Sam Palermo
Sam Palermo
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
