Kenmore Elite Quiet Pak II Washer won't agitate
We've had this heavy duty king-sized washer several years, and once in a while it would do something quirky (not spin the clothes dry on one setting, then would on another). But after a load of large bath towels, it now will not agitate or spin. It did pump the water out of the load (that failed on the wash cycle), but only makes the humming noise instead of the same noise with agitation.
My husband has been able to fix appliances in the past, as long as he was able to diagnose the problem and get the parts. I have not been able to find a manual online (even on FixYa), except for a generic page that said no agitation is a worn drive belt, Worn agitator dog cam assembly or drive spindle, Bad internal timer contact, Open lid switch, Pressure switch not sensing water level and switching from fill to agitate cycle, Broken or worn drive belts, Worn direct drive coupler or Defective motor. Can you narrow it down or suggest where to start first? Thank you so much.
  • rmart88062 Dec 14, 2008
    My washer is the same. It will not agitate completely. I believe the dogs may be worn but can't get them out. There is no "nut" inside auto dispenser or some other way to get to it that I can't figure out. I am stumped. Help please.
  • larry_russel Jan 13, 2009
    I also have a Kenmore Elite Quiet Pack II top load which I have to manually rotate the drum to begin the spin cycle, then it seems to spin out ok.  No problem whatsoever on the agaiation.  I only have to rotate the drum a small amount until I get a bit of resistance, then restart the spin cycle and it spins. Motor sound is deceiving in that it sounds as though it is working properly on its on, but it simply won't spin until I manually rotate slightly.  Otherwise, it works great.  Any suggestions?
  • 10 Answers
SOURCE: washer wont agitate. fills, then a faint hum. it
If it stops filling when it is full, doubt if water level switch. Take clear hose off of side of tub and blow into it, if you hear a clicking noise, it is not the water switch. The capacitor can be checked by placing a test cord on both terminals and applying 110 volts for a second to it. Then using screwdriver, short across the two terminals, if it sparks, it is okay. (be careful to hold the screwdriver handle, it packs a pretty good punch). If that those check out, remove the motor and the rubber coupling. Spin the coupling on the transmission with a large socket both ways. One way should make it spin and the other should make it agitate. If it does not agitate doing this, it is the transmission. If it checks out, then probably in the timer. Good luck
Posted on May 05, 2009
ned_san_jose
  • 234 Answers
SOURCE: Kenmore 90 Series fills with water but would not agitate or spin
You have a problem with the motor coupling. Top-load washers use what's called a direct-drive system, meaning it does not use a belt but what's called a "motor coupling". I probably replace 5 a week because these little guys break because of 2 reasons that i've found.
1) The break mechanism is too dry and causing the basket to stop at a holt, which puts a lot of strain on the coupler.
2) They break because of over-loading. I don't think you're over-loading though because it was find for 5 straight years.
Good luck to you. The repair is kind of hard to do on your own for the first time, so I would call an authorized technician. It will run you anywhere between $90 to $120 at most.
Best of luck!
Posted on Jul 16, 2009
jumptrout51
  • 3361 Answers
SOURCE: Kenmore Washer 90 Series Super Capacity will not agitate or spin.
http://appliancejunk.com/forums/index.php?topic=3437.0
Yes, you have a direct drive coupling problem. Use this video to replace your part.
EZPZ.
Posted on Aug 13, 2009
Testimonial: "Thank You! The diagnosis confirmation and repair video helped. There were some differences between my Washer and the repair video, but figured it out"
jsrock516
  • 5911 Answers
SOURCE: series 80 won't agitate or spin will pump out water
If the washer will fill and drain, but won't agitate or spin, you may have a broken motor coupling. The noise of the motor engaging, lack of agitation and ability to still drain are the usual symptoms. This is a common fail item with this model washer through normal wear and tear. Newer versions of the coupler are more resilient and resist breaking. The following link explains how to replace one:
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
The motor coupling is located between the drive motor and the transmission and takes the place of a drive belt. They do wear out and can break. The replacement part number is included in the link I provided and is an improved upgraded coupling that is more resilient. It should last longer. If you have questions, or require additional assistance, please let me know. I hope this helps you.
A replacement coupler can be purchased on line at appliancepartspros.com for about $11. Just use the part number in the link and "Search by Part Number" for your search criteria.
If you still have questions, please let me know. If the suggestions I have listed do not match your washer symptoms, please post back and elaborate more on what the washer is/is not doing. That way I can provide you with better assistance. I hope this information is helpful to you
Posted on Aug 15, 2009
dmftrucker
  • 1922 Answers
SOURCE: My GE washer won't spin or agitate
check the motor capacitor if your motor doesn't turn when powered, otherwise the "wig-wag"coil could be faulty,these coils shift your transmission for different cycles
Posted on Aug 24, 2009
Motor on kenmore elite washer quiet pak ii heavy duty capacity king size wont engage, just hums. and ideas?
Sounds like you motor coupling is gone this happens when over fill washer or place carpets/ bed blankets
Feb 15, 2015 | Kenmore Washing Machines
No heat
I can be several things, but most common is a burned out heating element. This can be tested with an Ohm meter.
Mar 15, 2014 | Kenmore Dryers
I have a Kenmore Elite Heavy Duty King Size Capacity quiet pak 1 that is not heating up what could the problem be?
Jan 13, 2011 | Kenmore Dryers
22942 Top Load Washer: Our Kenmore Elite w/ Quiet Pak II Super Capacity t...
my kenmore washer elite11 leaks water in the rinse cycle on the floor.
May 17, 2010 | Kenmore 22942 Top Load Washer
Washer is a Kenmore Elite Heavy Duty King Size Quiet Pak 3 Spd Motor/6 Spd combination do not have model number about 9 years old problem is the system will not agitate corretly. It will operate for a few...
Hey Steve!
To answer your question, no. They usually don't have a Thermal fuse. They aren't that suseptable to overheating (most of the time). You most definately would want to have a technician service this unit. You REALLY have to be experienced to work on these front loaders. They are LOADED with electronics that monitor and control everything that happens with the unit.
Dec 14, 2009 | Kenmore Washing Machines
Kenmore washing machine
you need to replace the timer it is faulty let me know how you make out
Oct 30, 2006 | Kenmore 15944 Top Load Washer
Washine Machine
-Sounds like the timer is out. Check it out and replace it
Good luck
Mai
May 16, 2017 | Kenmore 22642 Top Load Washer
Washing Machines Logo
1,193 people viewed this question
Top Washing Machines Experts
