Question about Montgomery Ward (R402JKFP) 1100 Watts Microwave Oven
Door latch the top latch on the door to my microwave will not release
Open door if latch is broken
And you can't just pull the door open? I know it's easier to push the open door button but both ways should work unless the safety switch bracket moved from it's intended position. I hesitate to offer this solution, but who wants decayed food smelling up the home? Let's assume it's a counter top oven, remove all cover screws and the cover. STAY AWAY FROM ALL WIRING and I should have said first unplug the power from the appliance. Locate the door latch area and lift up on the plastic/metal bar that has a spring attached to it and the door should be released. Pushing the door release button should lead you to the latch. Once you see how it works you may find the reason the latch is malfunctioning. If it's a over the range type you will have to remove a grill at the top of the oven to access the mounting screws that release the oven from the bracket but the latch reference above will apply to this type as well.
Dec 06, 2014 | Microwave Ovens
Viking Microwave door latch
Try pushing in on the door while pressing the door release latch;
Also, try pushing the door latch and reach under the front edge of the door and slightly pull as the latch is depressed.
Third option is use a suction cup, maybe from a GPS device on the glass portion of the door, pulling on it while you depress the door latch....let me know any problems or if I can help anymore.
Jul 27, 2014 | Viking VMOC205 Convection/Microwave Oven
How do you replace the handle
follow this steps and fix it. see the pictures attached. God bless you2f4dab72-f574-4367-8631-e2d40f813792.gif
Open Lever
If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Enter your model number to see parts for your microwave.
Help me find my model number
Door Spring
If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch
If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook
If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring
If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button
If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator
If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Jun 18, 2013 | KitchenAid KHMS147 Microwave Oven
I have a amana road range microwave and the door won't close . AMV3204VAB-0
proceed according . God bless you
Open Lever
Door Spring
Door Latch
Door Hook
Button Spring
Button
Handle Actuator
Apr 02, 2013 | Microwave Ovens
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Oct 15, 2012 | Samsung SMH9187 Microwave Oven
The micro wave door is warped so that the top right latch will not fully engage. How do I fix it?
If the door is warped, buy a new microwave but that is very unlikely.
Release the lower hinge screws and square the door up to the latches then tighten the fixing screws.
Hope that helps.
Jan 12, 2011 | LG LMV1630ST Microwave Oven
Microwave will not cook/start when start button is pressed.
You can get the latch itself from either partstore .com or repairclinic .com
Apr 19, 2010 | Emerson MW8168B Microwave Oven
Door will not open. Button release does not release the door latches.
The plastic lever release is more than likely broken. You can order the part from
http://www.repairclinic.com/Appliance-Parts?s=t-KCMS145JSS0-%3d%3dc226g5
It's about twenty dollars.
May 22, 2009 | KitchenAid KCMS145J Microwave Oven
Sharp Microwave model R-1850A door won't open
buy a boddle of WD-40 and try spray some in the raded spots.Im not a big specialist in microwaves.hope it helps
May 10, 2009 | Sharp R-930AK Convection/Microwave Oven
Hi ,there are two posibility to repair . 1. by ordering parts to the web site of sharp .
2. You may check from shop same type of part bring sample or in the appliances center near you.
Jan 14, 2008 | Sharp R-1850A Convection/Microwave Oven
Montgomery Ward (R402JKFP) 1100 Watts Microwave Oven Logo
Top Montgomery Ward Microwave Ovens Experts
William Miller
William Miller
Lawrence Oravetz
robert
Are you a Montgomery Ward Microwave Oven Expert? Answer questions, earn points and help others
