Question about Toshiba COPIERS E-STUDIO 600 Copier
Toshiba e600 copier f100: new Seagate 40gb,old one was WD,Formatted ready to go. Put in copier 08-690-2 waite then error. What do Ido next? Set copier for seagate? copy files to drive???
  • 1 more comment
  • ken vaughan Feb 13, 2012
    hold- clear 3 routine 3 initiialize error.
    Have repair manual A B C no information on HDD.
  • ken vaughan Feb 14, 2012
    The answer is to get a new hdd at the store any hdd will do install hdd completely!! and hold clear and 3 turn on and run 1-2-3 one at a time. Then use the 08 690 2. Its works.
    Problem Solver:
  • 8 Answers
How to fix the toshiba e600 error code c412
Posted on Dec 24, 2012
  • Toshiba Master
  • 653 Answers
AFter install new HDD, need to perform 3 Clear to create partition for the HDD, then follow by updating firmwares, perform 08-947, then 08-690.
Posted on Jul 11, 2012
  • 32 Answers
SOURCE: toshiba copier,6570, make double side copies
On the main touch screen there are 4 touch buttons. The bottom left on should say : Simplex 1-1. If you tap on it you will see duplex 1-2 , duplex 2-2, Split 1-2 and so on.
Hope this helps
Posted on Feb 04, 2008
  • 653 Answers
SOURCE: what steps to take after installing a hard drive on a toshiba 350
After replace new hdd, u need to performs following:
Update of HDD program data and UI data.
1) Create partitions. (In case of using the download jig, this is not necessary.)
While pressing [3] and [CLEAR] button, turn the power ON.
When "Firmware Version Up Mode" appears on the LCD, key in [3] and press the [START]
button.
2) Format the HDD. (Setting Mode (08-690: 2))
3) Update with the download jig or USB storage.
4) Format the HDD. (Setting Mode (08-690: 2))
* When the FAX unit (GD-1150) is installed.
Start up with the FAX Clearing Mode (1*)
Perform the 1*-100 (FAX Set Up), 1*-102 (Clearing the image data) of the FAX Clearing Mode.
Posted on Feb 13, 2009
rezazadeh
  • 328 Answers
SOURCE: error c01 toshiba copier
main motor problem or abnormal
Posted on Jun 01, 2010
  • 30 Answers
SOURCE: Toshiba 451c Color Copier experiencing error F105
Hi how are you this is jack my personal Id (jack_pak@hotamil.com)
Dear follow the procedure .....
Other service call
[F105] HDD other error
(1) Check if the connectors of the HDD are disconnected.
(2) Check if the connector pins are disconnected or the wires of harnesses are open circuited.
(3) Perform the bad sector check (08-694). If the check result is OK, recover the data in the HDD. If
the check result is failed, replace the HDD.
(4) Replace the SYS board.
Thanks
Best Regards,
Posted on Aug 14, 2010
muntejaya
  • 10421 Answers
SOURCE: I need a software of Toshiba estudio352 Firmware
Just download the driver here:
www.driverfiles.net/.../Toshiba/.../download/page,sh,19807,221,12,.html
Posted on Jan 13, 2011
MY TOSHIBA E STUDIO 451c HAS AN ERROR F100 CODE. WHAT DOES IT MEAN?
That code error meaning that you have a problem with HHD
1st you reboot your machine with push 0+8 than 690 start 2 set(interrupt).
If it don't wok you mast replace your HHD with a new one from Toshiba.
Aug 11, 2012 | Toshiba E-Studio 3511 Color Copier
How do i fix error code f100 1 for toshiba e studio 2040c?
F101 HDD failure,,08-9030..or update the firmware version.if not okey replace the HDD.
Jun 23, 2012 | Toshiba E-Studio 2040c Copier
How to fix Diagnostics error in seagate 40gb hard disk
what diagnostics error? you may want to use seatools to repair your disc you can download here http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=seatools-win&vgnextoid=552bd20cacdec010VgnVCM100000dd04090aRCRD
Feb 07, 2011 | Seagate HDD 40GB 7200RPM ATA100 2MB...
Service Required Error code F100. What do we need to do?
F100 indicatest HDD failure...
The best way to solve it is to replace a new HDD & update firmware~~~
Oct 07, 2010 | Toshiba e-Studio 350 Copier
How do I fix the Error F100 on my copier?
F100 indicates HDD error.
Try 08-690 to reformat the hdd. If still occur, then probably u need to change new HDD.
Jun 23, 2010 | Toshiba E-STUDIO 450 Copier
Error code F100
Your HDD is having issues. You can try formatting the HDD (make sure you backup templates and address book if you use them.) To format HDD hold 0 and 8 while turning on the copier, when the machine comes ready key in 690 and hit start. It will then display "2 2", hit start again. Wait for it to say please reboot the machine, turn it off and back on. Hopefully this will work but if not, your HDD will need replacing.
Nov 18, 2009 | Toshiba E-Studio 3511 Color Copier
MY TOSHIBA E STUDIO 4511 HAS AN ERROR F100 CODE. WHAT DOES IT MEAN?
format hard by power on+0+8 then 690 then start then2 then set then report the mashin or revision the logic may be there is a problem in it
Sep 21, 2009 | Toshiba E-Studio 3511 Color Copier
Dell Lattude D800 HDD change - doesn't boot
I suppose it can support upto 100GB , just get the BIOS updated to the latest release and check in the setup if the disk is accepted .
Dec 16, 2008 | Dell Latitude D800 Notebook
What steps to take after installing a hard drive on a toshiba 350
button.
Nov 26, 2008 | Toshiba e-Studio 350 Copier
366 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
