Question about Vehicle Parts & Accessories
Pcm module in 2001 pathfinder
Price for pcm and location inside car
  • Maqbool ahmed Feb 13, 2012
    Thank you I will check it to me you are right I want to double check it before I was not sure
    Problem Solver:
  • 5 Answers
I don't see a "PCM" listed, but there is an ECM (Engine Control Module) under the dash just to the left of center on the vehicle. Price? Check with your local parts store or search on Ebay.
Posted on Feb 13, 2012
Location of ignition control module 2001 cadilac deville
Ignition Coils/Modules
The electronic ignition system uses an individual ignition coil for each cylinder. There are two separate ignition module assemblies located in the camshaft cover of each cylinder bank. Each ignition module assembly contains an ignition control module and four ignition coils. Each ignition coil connects directly to a spark plug using a boot. This arrangement eliminates the need for secondary ignition wires. The ignition module assemblies receive power from a fused ignition feed. Both ignition module assemblies connect to chassis ground. A Reference Low and four ignition control (IC) circuits connect each ignition module assembly to the PCM. The PCM uses the individual IC circuits to control coil sequencing and spark timing for each ignition coil. The IC circuits transmit timing pulses from the PCM to the ignition control module to trigger the ignition coil and fire the spark plug. The PCM controls ignition system sequencing and timing events
Dec 05, 2015 | 2001 Cadillac DeVille
Where is the automatic transmission modular located on 2001 buic centry
Do you mean the transmission control module ? It is incorporated into the engine control module . PCM - powertrain control module .
Powertrain Control Module (PCM) (L36/L67)
Left front of the engine compartment, inside the air cleaner assembly
Engine Controls Component Views in Engine Controls - 3.8L
Powertrain Control Module Connector End Views in Engine Controls - 3.8L
Powertrain Control Module (PCM) (LG8)
Oct 04, 2015 | Cars & Trucks
My 2001 Nissan pathfinder heater will not turn off. A/c worked fine and did come on one time when tryed but the heats up now at any setting and is extremely hot.
There are three culprits that may cause this.
1:Many people have great luck with replacing the resistor unit for the blower motor. While I cannot guarantee this is the issue you have, it is the most common. (Approx $45. )
eBay link.. http://www.ebay.com/itm/Heater-Blower-Motor-Resistor-For-Nissan-Pathfinder-Xterra-Titan-Pickup-Truck-/131110853460?hash=item1e86d0db54&vxp=mtr
2: Others have luck when replacing the actual Plastic switch inside. This runs about $50
3: Then there is the blower motor amplifier.. (approx $110)
http://www.ebay.com/itm/NISSAN-PATHFINDER-BLOWER-MOTOR-AMPLIFIER-POWER-MODULE-1996-2004-/231422243697?pt=Motors_Car_Truck_Parts_Accessories&hash=item35e1d73371&vxp=mtr
Your service manual will show location of these items or a quick search online for schematic for your model will produce results to assist you from here.
Hope this helps.
Apr 04, 2015 | 2001 Nissan Pathfinder
Cannot locate the pcm on 2001 saturn l series
Passenger side , under dash close to the kick panel just below the abs control module.
Sep 10, 2012 | 2001 Saturn L-Series
Computer
It is under the hood with the body of the module (called the PCM) sticking inside the passenger compartment, it come out from under the hood. See picture below. The PCM (computer) is circled in Red.11_25_2011_6_04_49_pm.jpg
Nov 25, 2011 | 2001 Ford Explorer
I need a new PCM computer. I have a 2001 Pontiac Bonneville SSEi. Can you tell me where the PCM is located?
Powertrain control module is inside air cleaner housing in left side of engine compartment, )
Nov 23, 2010 | 2001 Pontiac Bonneville
Location of ecm on f150 2001
Powertrain Control Module (PCM) Removal and Installation
  1. Disconnect the battery ground cable.
  1. Disconnect the powertrain control module (PCM) electrical connector.
Remove the right front door scuff plate.
  • Remove the right cowl side trim panel.
  • Remove the clip and remove the PCM.
  • To install, reverse the removal procedure
  • Hope this helps ya.. :-)
  • Jul 21, 2010 | 2001 Ford F150 Styleside SuperCrew
    Location of powertrain control module on 01 PT Cruiser?
    The PCM attaches to a bracket welded on the dash panel
    Oct 31, 2009 | 2001 Chrysler PT Cruiser
    ECM Location
    For one i dont need your vin its a z24 which means it has a 2.4l engine it does not have an ECM it has a PCM powertrain control module, which is located for your car in the right rear corner topside of your engine bay, in 1995-2001 it is located inside the right front fender. I hope this info helps...
    Apr 07, 2009 | 2002 Chevrolet Cavalier Coupe
    PCM module, ECM module 1996 Chevy Suburban K model
    Powertrain Control Module = under right side of dash, near blower motor.
    Engine Control Module = same as above
    Vehicle Control Module = same as above
    All Suburban vehicles are equipped with only one of these choices. Good luck.
    Oct 04, 2008 | 1996 Chevrolet Suburban
    Vehicle Parts & Accessories Logo
    256 people viewed this question
    Top Vehicle Parts & Accessories Experts
    Thomas Perkins
    Thomas Perkins
    Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
