Had the same problem after overusing one of the bigger elements on my bellini induction stove / cooktop to boil copious amounts water. Element eventually stopped working and would just flash power level similar to when it cant recognise an induction pot, but also made a clicking noise over and over. My solution was to turn mains power off at meter box, and back on to reset the stove. When power came back on stove was working again! might have reset some sort of cutout sensor inside stove but cant be certain. Anyway, worked for me so give it a go and see if it helps. good luck.
SOURCE: Miele KM443. Elements switching on and off every 5 to 7 seconds.
as far i know it is normal if u put at high control after a sec,the sencor control is turn off then a sec again it open coz of the sensor, design the sensor for not overheating the hob.it is normal try to position the control in in not a max position.or the pot u use is exactly in the circle or bigger dont put a small one in the bigger hole of ur elctric hob.tnx
SOURCE: I have the 5 element induction cooktop with no
Call 1 800 442 1111 Its whirlpool they own kitchenaid. they can find a local tech for you
SOURCE: whirlpool induction ceramic cooktop error E6
my induction ceramic cooktop is showing an error code E6 on two of the elements...what is the problem and how do I get it fixed
SOURCE: 36" Wolf induction cooktop cannot get past show
Hello John..... Call the store and ask them what code is needed for this model. They put it in showroom mode and they should have taken it out of showroom mode before it left the store. Shame on them. Joe
THanks for choosing Fixya!
SOURCE: Maxtra Aikae induction cooktop, continuous
I do understand that there is very limited support for Maxtra Aikae induction cooktop currently. Specially when you are looking for support on wiring diagram or spare parts. I can suggest you one good place to call , email or look for. Click on the bellow link:
http://cgi.ebay.com.au/AIKAE-TOUCH-CONTROL-CERAMIC-INDUCTION-COOKTOP-COOKER-/180633551710
Thank You
