Question about HP Pavilion a1720n PC Desktop
Hp pavilion a1720n won't turn on
The green light in the back is flashing but it won't turn on
  • HP Master
  • 27,725 Answers
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive boot up
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they could be faulty ?
even something as small as an electrical extension or a faulty fan lead can cause this problem
a computer needs all of the data and electrical current to travel through every working device and to have an end to be able work properly
motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail check all electrical extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
make sure the CPU central processing unit has thermal paste and dust free and is securely seated
make sure your computer ram modules are securely seated with no dust in sockets also Cmos battery has charge with no dust in the socket some motherboards cmos batteries are soldered in
hope this helps you
Posted on Feb 14, 2012
tcshack
  • 28 Answers
SOURCE: i got hp pavilion pc
if your network cable is plugged in it will flash green .....if it won't turn on pull the plug and wait 10 seconds or more then plug in again and see if it will start .....are the fans running and no signal to monitor?
Posted on Jan 07, 2009
nyilasrobert
  • 627 Answers
SOURCE: I have an HP Pavilion a384x. It will not turn on
verify on the power suply is a switch with 2 positions 0 and 1
It must be positioned to 1
If not, the power supply could be damaged. It must be replaced
Posted on Aug 03, 2009
Combchris
  • 64 Answers
SOURCE: HP Pavilion A520N will not power up. Green light
Which light?? the network light?? Do you get anything when you press the power button if not it is most likely the power supply since the motherborad is still showing power also may be cpu!
Posted on Nov 17, 2009
Papa Ray
  • 15 Answers
SOURCE: bestec model atx 250 12z flashes green
Try these suggestions:
<a href="http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph06788&cc=us&lc=en&dlc=en&product=427167&dlc=en&lang=en#bph06788_section_2" >Troubleshooting Power Supply Issues</a>
Posted on Nov 29, 2009
Cool Sam
  • 79 Answers
SOURCE: HP Pavilion a735w will not power up Green light
check the light at the rear panel of the tower ... if it is solid green then reseat the cables coming out of the smps and going to the motherboard and other device drives(Hard Drive and CD/DVD drive).... if there is no light smps might have gone bad
Posted on Feb 08, 2010
HP Pavilion a 1245c won't boot black screen no beeps constant running fan
sound to me like a video problem. no beep codes, you hear the fan going so it must be posting. could you try with other monitor and or cable? is there power to monitor? reseat cable at both ends( monitor+ pc)
Nov 02, 2012 | HP Pavilion a1720n PC Desktop
HP Pavilion a 1250n won't turn on. Green light is on under the plug in the back but noghting else.
If the monitor power light is on or flashing, but nothing displays, borrow a monitor from a friend. If that works, your monitor needs replaced.
Sep 22, 2012 | HP Pavilion a1250n (EG194AA) PC Desktop
Please try the following:
1.remove the power cable an plug it again
2.check is the power it's on at the back of the source.
3.if you hear some noises write them down and search for the error codes on the net.
My HP Pavilion dv5 1125nr laptop won't boot up. The screen never lights up when the power is turned on, the little hard drive light next to the power light doesn't flash at all (normally it flashes...
check by removing the battery then put it back again power it on, or without battery power it on directly then check, if still the same problem, the fault is in the motherboard of the laptop, better take it the service center or consult some technician in your area
Aug 02, 2011 | HP Pavilion dv5-1125nr Notebook
Hp pavilion a705w - blue power light flashing, won't turn on
On the back of the power supply there is a 120/220 V AC selector switch.
It's possible that switch got knock on the wrong voltage position.
Pull the power cable. Move the switch back and forth between the two position.
Make sure you leave the switch in the correct selection. 120v = USA
If you have time,open the case and inspect the RAM module(s) and card(s). They can be un-sitted.
plug in power cord and power on the pc.
Jul 29, 2011 | HP Pavilion a705w PC Desktop
Hp pavilion a1217n tower won't power up...the green light in the back is blinking rapidly....help!
it could be 3 things eigther the hard drive failed or power supply went out or mother board went bad you can take it to a reputable computer repair store and they will check these for free
Jul 08, 2011 | HP Pavilion a1217n Desktop PC
Suddenly my hp pavilion a1217n tower won't turn on...the green light is blinking rapidly...
are you referring to the light on the back? if so the power supply has most likely failed, mother board can also cause this issue.
HP Pavilion a1720n PC Desktop Logo
107 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
