Question about Sport & Outdoor - Others
C84e champion elliptical E-2 code ,what does it mean?
E-2 code on screen,can't do anything.how to fix?
3 Suggested Answers
SOURCE: I am looking for an owner's manual for the Champion Elliptical
Did you find a manual? I have the same problem.
Thanks.
Posted on Oct 28, 2009
SOURCE: I have misplaced the powercord
You can try searching the brand of the machine online they may sell replacement parts, or you can try ebay.
Posted on Jul 21, 2011
What voltage does this model run on,24volts?
The details regarding volts current etc should be in the back of your manual
Jun 17, 2014 | Exercise & Fitness
My NordicTrack E5.7 Elliptical is making a grinding sound
Hi Liz,
The only way to assess is to take the covers off. There are a few reasons for this type of problem.
Nov 07, 2012 | Nordic Track NordicTrack E5.7 Elliptical
What do these codes mean?
Per Google search:
P0301 - Cylinder #1 misfire
P0300 - Random cylinder misfire
Could be spark plugs, wires, etc. I'd start with the spark plugs if you know they haven't been changed in a while. Get some Champion spark plugs from your local auto parts store (the copper plugs are OEM per Chrysler) and should be about $3 per plug.
Aug 23, 2012 | 1996 Chrysler Cirrus
Nordictrack auidostridder 800 elliptical screen dead
Chad Gilbert--
I'm having the same problem with my Audiostrider 800. Fan works, screen and soft buttons do nothing.
I dont mean to sound dumb, but where are these motor brushes? Are they attached to the resistance motor or somewhere else? What exactly am I looking for?
Any help would be greatly appreciated!!
Aug 11, 2012 | Nordic Track Nordictrack Audiostrider 800...
Just got used champion c84e...how does computer work..should there be an electrical cord?
There is no electrical cord for this elliptical. It is powered by the runners motion. If the computer doesn't turn on when you start running, check the connections underneath it. If they are tight, you may need to replace the fuse. If after replacing the fuse and it still doesn't work, the computer may be broken.
Mar 06, 2011 | Computers & Internet
Tunturi elliptical cross trainer error e-2
Most E 2 code means communication problem upper and lower boards you will need to check connector. for further info go to http://accellfitnessna.com or Email a.parker@accellfitness.com they will help you they Tunturi Distributor of North America
Apr 02, 2010 | Exercise & Fitness
Error code 2 on schiwnn upright bike
Console displays “E2” error code
Solution: A. Check data cable integrity. All wires in cable should be intact. If any are crimped or cut, replace cable. B. Check data cable connections/orientation. Insure cable is connected securely and oriented properly. Small latch on connector should line up and snap into place. If the above tests reveal no problems, replace the DC Motor.
• TECHNICAL/CUSTOMER SERVICE Nautilus, Inc. World Headquarters 16400 SE Nautilus Drive Vancouver, Washington, USA 98683 Phone: 800-NAUTILUS (800-628- 8458) Fax: 877-686-6466 • CORPORATE HEADQUARTERS
Apr 01, 2010 | Schwinn 430 Elliptical Trainer
Thanks.
Aug 22, 2009 | Exercise & Fitness
The console does not work. E-2 shows up on the console.
We had this problem after assembly as well, it turned out to be a bent pin inside the connector to the flywheel housing (where the wires connect inside the lower part of the main mast). It was so bent that it never actually made contact with the connector.
We straightened the pin, carefully reconnected the wires, and everything worked just fine.
This says to us that the "E-2" error message means the console is missing at least one connection from the system. This could be caused by a bent pin, a torn/cut/frayed wire, etc -- anything that might make it lose signal.
So check the lower connection for bent pins, check the upper connection for bent pins, and check all along the wires for any kind of damage.
Hope this helps!
Jan 04, 2009 | Schwinn 430 Elliptical Trainer
Sport & Outdoor - Others Logo
43 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
