Question about Konka K1938U 19" TV
Change the word sourdine to MUTE
When I hit the mute button it says Sourdine on the screen and does not go away until I change the channel. I would like it to display Mute instead. C;an you guide me on how to change the setting.
Phone mutes while I'm talking
Sometimes when phone is security locked and you answer a call your phone gives you access to call screen until you put it to your ear (and the phone blanks screen because it's at your ear). If you accidently hit the mute button with your face before the screen turns off you will mute yourself. This happens to me sometimes and when i pull the phone away from my ear the phone display lights up but the phone is on lock so i have to put in pin to unlock screen and unmute myself
Nov 07, 2016 | Cell Phones
How do I do an automatic code search on a ge unigersal remote control model 24993 - v4
1 manually turn on device(TV, VCR,ect. Be sure batteries are good in remote.
2 press and hold the CODE SEARCH button until the red indicator stays on,then release Code search button.
3 press and release mode button (TV, VCR, ect) the red indicator blinks,then stays lit.
4 press channel up( up to 300 times) until device changes channel. The red indicator blinks,then stays lit.
5 Press the Mute button release to lock in code
Tips if you go pass the code use channeldown when channel change hit the mute button and release it to install code.
Apr 12, 2015 | GE Televison & Video
I Lost picture. Went to press mute button on remote and pressed last button instead. Now i can't get picture back.
If you hit the "last" button again, it should take you back to the channel you were on before you hit the button. when you lost the picture, was the screen blue? black? If you hit the "menu" button, does the menu come up?
Jan 11, 2013 | Vizio VW37L 37 in. LCD HDTV
When I am on the phone the mute button keeps cutting off my conversations. I would like to completely eliminate the mute button...how do I do this?
You can't. You can't do anything to change the phone default software like that.
what you can try is when your on a call. chose to show the keypad then the mute button goes away.
Also make sure the phone is close enough to your face to activate the screen switch sensor. That shuts the screen off on the phone so you can't hit "buttons"
Aug 08, 2011 | Apple iPhone Smartphone
Channels 3, 4, 5, and 7 are mute. The mute button has no effect.
there should be an audio section of your tv
Go through each of your setting s and be sure nothing was changed. goto setup and reset to factory settings. your TV will do something funky and powercycle.
THAT should fix your problem.
if not, is your cable service through your VCR? if so, remove the vcr altogether and connect your cable services directly. All should now be a go.
Aug 26, 2009 | Element Electronics Televison & Video
Olevia 537 - wont select HD channels
I assume the control panel on the tv still works correctly? If so i would think you have a remote problem. If thats the case let me know I will send you a link to instructions to repair your remote.
lone99star
Jan 09, 2009 | Televison & Video
Thanks but i need more help
Don't be panic.
Check the batteries of your remotes control. FIRST
Be sure to aim the control to the sensor of your tv.
Usually you have one remote for your tv and the other to control the cable box or digital box.
You have to set the RMC10 again using the code of your tv Silvania (like the first time)
Then set your tv on channel 3
Another thing, be sure that you are hitting the right buttons.
The control doesn't work if you hit on the top any key instead of cable
What i mean?
The remote has on the top 4 key usually (tv, cable, vcr, aux, etc).
You must hit first cable to set the control to cable
1, Manually turn on the device(TV, VCR, etc.) to be controlled.
2. Press and hold the code search button until the red indicator stays on, then release the code search button.
3. Press and quickly release the desired mode button (TV, VCR, ect.). The red indicator blinks off once.
4. Press the Channel up button repeatedly(up to 300 times) until the device to be controlled changes channel. The red indicator blinks off with each button press. If you accidentally overshoot the code required, press channel down button to backtrack through the library until device changes channel. Pressing Channel up changes direction forward again.
5. Press and release Mute to install code.
Don't forget to rate my help!
Thank you for using FIXYA!
Have a great day!
Pablo :-)
Let me know how it is going!
Oct 18, 2008 | Electronics - Others
LG CU500 cell phone
hit the button on the side that you use to change your volume untill it goes to the section with the blue bars then hit the cingular guy button
Jun 08, 2008 | LG CU500 Cellular Phone
Need RCA univeral remote control code for Magnavox 27MS343S
Push in and hold code search button until it stays lit, then pushed the TV button, it flashes quickly. Then hit the number zero once, then hit channel up button until tv finally changes channel. Hit the mute button once to get it to store the code.
Feb 20, 2008 | Philips Magnavox 27MS343S 27" TV
Volumn not working
WHen I hit the mute button again to bring up the volumn the sound remains muted. I have tried all other channels, direct cable and even a dvd player connected. No sound. I unplugged all the boxes and tv and then plugged in again in a attempt to reset what might be wrong. Still no sound. solution 1 while operation mute button has got demaged or pressed more. 2 sound section might have gone defective in tv 3 no supply to sound section 4 or speaker defective or ic got demaged.
Aug 02, 2007 | RCA 27V520T 27" TV
Konka K1938U 19" TV Logo
190 people viewed this question
Top Konka Televison & Video Experts
Arnel
Arnel
Computer Repairing
Computer Repairing
Are you a Konka Televison and Video Expert? Answer questions, earn points and help others
