Question about Samsung Televison & Video
Samsung surround ht-tx25 flashes up protective mode then turns off
5 Suggested Answers
nikeananth
  • 267 Answers
SOURCE: i have a samsung model ht-tz215/xeu dvd i switch
HI,
With regards to your recent query, when you
get a 'Protection' message on your unit it usually means the unit is
overheating. Please make sure there is nothing blocking the air vents on
the unit, nothing is sitting on top of the unit and that it is not near
any hot items like radiators. Please also check the cables that connect
the speakers, disconnect them all, reconnect, turn the unit off and back
on. If you have checked all of the above and the same thing still
happens, try resetting the unit, full instructions can be found in the
troubleshooting part of the user guide. Where did you purchase the
product?
ELSE
DO THIS
Pressing the STOP button on the front panel andholding it for 5 seconds". The power indicator flashes once and thesystem resets! wink.gif
Posted on Sep 27, 2009
SOURCE: samsung dvd home theater HT d5610
I am looking for and to purchase an antenna for my HT D5610. Thank you for any help you can provide me with.
Posted on Feb 01, 2009
  • 336 Answers
SOURCE: sony ht-ddw750 protect mode on don't know why
Sorry for the bad news. It probably needs an output ic replaced.
Posted on Feb 23, 2009
smarthome2
  • 1114 Answers
SOURCE: My HT-TX75 DVD flashes a message
First thing to do is disconnect all your speakers at the back of the receiver, then turn it back on. If it does not go into protection, post a comment and I can walk you thru troubleshooting. If it still goes into protection, your unit needs to be serviced. Hope this helps
Posted on Jun 24, 2009
  • 56 Answers
SOURCE: powering off for protection samsung HT-WX70
the fan is broken on your unit, this is a feature to keep the unit from over heating
check if there is anything blocking the fan from moving/rotating
try to contact your manufacturer
Posted on Jul 02, 2009
Samsung dvd player switches itself onto protect!
hi,i can't connect my audio tv to cinema theater dvd
Apr 02, 2010 | Televison & Video
No surround sound with Prima HT-TW57P DVD System
I realize this may sound silly but it could be the disc your are playing. Some DVDs are not mixed for surround sound and thoes that are produce very little sound from the rears.
Rear speakers were meant for effect, not meant to distract you from the picture.
Give this a try, get a movie playing that is 5.1 surround sound. Check that the home theatre is not set to stereo mode, if it is change the surround mode on the unit. Now that you are in the middle of an action scene disconnect the front speakers and see if there is background noise comming out of the rears.
If its still dead let me know more details about the system and I will work on a solution.
Cheers,
Jan 06, 2010 | Televison & Video
I have a samsung model ht-tz215/xeu dvd i switch it on and it says samsung protect and turns itself of any ideas
HI,
product?
ELSE
DO THIS
Sep 27, 2009 | Samsung Televison & Video
Region codes for Samsung ht z110
Try this
1. Disconnect your player from its main power source for 30seconds
2.Reconnect your player to its power source
3.Press the power on button on your remote control
4.Press the Enter button on your remote control
5.Press 8,4,2,6 and 9
6.Press Enter on remote control and the your player will place itself on standby mode
7.press the power on button on remote control.
your player is multi region.
Apr 25, 2009 | Televison & Video
My Samsung HT-40 home theater system throws itself into protection mode and shuts down. I put a new fan motor in but it insists on shutting down anywhere from 10 to 60 minutes of operation. No dust...
The fan is going bad and if you have replaced it try to open the case and remove the cover over all the capaciters and what not and replace that fan in the back then cut a hole in the top of the metal case directly about the cap's that warm up and install a aditional fan to act as a chimney a little noisy but i did this and the player had been runing in aux and radio mode for a few days stright now no problems at all it's alot of work and skill but for 2 5-15 dolar fans sure beats the 160 for repair or buying a new recever! make sure u turn on the recever for 10 min if the fan is not turning by then its still not good
Dec 18, 2008 | Samsung Televison & Video
Samsung dvd home theater HT d5610
This sounds like a short circut (check speaker and other conections to make sure none are touching each other or a metal contact!
That should fix ya!
Dec 18, 2008 | Samsung DVD-R155
I have a samsung DVD Home Theater System HT-WX70. My son put a cd copy in the DVD player and PROTECTION flashed on the player and it turned off. I turned the player back on and took the cd out. ...
If it is, the protection message usually meant either a speaker had blown, or more commonly a wire to a speaker had come disconnected or broken/shorted.
Try unplugging the speakers one at a time, and if you have a set of speakers of the same rating to try, try plugging them in as you remove the originals (obviously doesn't need to be done in the setup positions in the room, just have them beside the player to check it works.)
This might then identify which speaker or cable is the problem one for you to replace or repair.
If this is the speaker overload/short mesaage as I think it is and the above doesn't cure it, it would appear the amplifier board has a short somewhere and that's an electronics engineer job time
Hope it helps!
Nov 18, 2008 | Samsung Televison & Video
My home theatre system (sAmsung DVD home theatre system HT-Tx75)shuts down automatically after 10 minutes of listening to the radio...it says 'protection', then shuts off. i checked to see if it was on...
Protection mode on a Samsung player most likely means that the unit is overheating due to a non or low functioning fan. Before taking it somewhere to be serviced turn the unit on and see if the fan in the back is functioning (it should be on whenever the unit is on). If it is not you can try gently blowing it out with a can of compressed air.
I am sure that you can have it serviced but it might be cheaper to purchase a new player.
Good luck and take Care,
-WN
May 06, 2008 | Televison & Video
Televison & Video Logo
124 people viewed this question
Jerry Greenberg
Jerry Greenberg
