Question about Samsung Refrigerators
I have a samsung RS2530BB twin x flow freezer side working fine but refrigeration isn't get cool or working igeraton isn't cool or working
  • 148 Answers
SOURCE: Refrigerator side not cooling. Freezer side okay.
call that company server
Posted on Apr 05, 2010
SparkGap
  • 363 Answers
SOURCE: Samsung RS2577BB Refrigerator/Freezer Will not Cool
Chances are you need to get the refrigerant recharged. This can only really be done by a professional due to the equipment needed. He will also find where the gas is leaking from.
Posted on Oct 13, 2007
Maanita
  • 1142 Answers
SOURCE: refrigerator not cooling
see if the compressor motor is running
The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, we recommend contacting a qualified appliance repair technician for further help.
If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
  • The compressor
  • The Thermostat
  • The overload, relay, or capacitor
  • The defrost timer
  • The condenser fan motor
Posted on Aug 07, 2008
SOURCE: maytag refrigerator side-by-side model MSD2756GE
remove the baskets and shelves in the freezer and remove the rear panels after shutting the fridge down. If you see heavy frost on the coils then the defrost model needs replaced. If not, check the that the fans runs, and then that the thermostat works and then that the damper that allows the air to the fridge compartment is opening correctly.
Posted on Sep 05, 2008
  • 119 Answers
SOURCE: Samsung RS267LBBP 26.1 Cu. Ft. icemaker won't stop making ice
UP.
Posted on Aug 07, 2009
How to fix the rs 2555 refrigerator is not cooling, but the freezer is fine
1) Twin Cooling System
┬ĚThe refrigerator and the freezer have two
evaporators.
Given this independent system, the
freezer and the refrigerator are cooled individually as
required and are, therefore, more efficient. Food
odor from the refrigerator does not affect food in the
freezer due to separate air flow circulation.
The Evaporator unit for the fridge may need servicing.
if you handy with tools you can fix it yourself the manual link is below
http://vdmeulen.net/handleiding/Samsung%20SR-S24%20FTBS/samsung%20rs2555sl%20service%20manual.pdf
Aug 16, 2014 | Refrigerators
Refrierator side is not cooling- Freezer side is fine
Twin Cooling System
evaporators. Given this independent system, the
Because of the dual system one of your evaporators may need servicing.
Refrigerator not cooling FRS22WNC
the damper vent door between the freezer and refrigerator isn't opening to let cold air into the refrigerator compartment from the freezer side,its in the upper left corner in the refrigerator behind a grille,if its closed you wont feel cold air flowing in from the freezer sometimes you can shine a light in this area and look in the other compartment and if no light then the doors shut and this is why its not cooling the refrigerator
Sep 29, 2012 | Frigidaire FRS23H7C Side by Side...
Hi, I have a Samsung refrigerator and the top part isn't cold enough and the freezer is working perfectly fine. I need help fixing the fan.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 03, 2011 | Samsung Refrigerators
We have a Kitchenaid superba side by side. The freezer is working fine, but the refrigerator isn't cold. I have vacuumed the coils at the top of the model, but didn't solve the problem. I can...
The cooling normally comes from the freezer side, through cooling tubes. There should be a fan either blowing or sucking the air through these cooling tubes. So the first thing you should do is verify that the evaporator fan is turning and then see if you feel air flow in both compartments. If you have air flow in the freezer but not the refrigerator side, then the cooling tube must be blocked.
Most of the time the blockage is ice or frost, and you will need to open up the inner back panel of the freezer to get to the cooling tube. Look for an opening under the evaporator. Suggest a hair dryer to defrost the tube.
Jul 15, 2011 | KitchenAid Refrigerators
I have a side by side ref/frez Amana ars266zbw the freezer works fine but the refridgerator isn't coolig
heatman101
Jul 12, 2011 | Amana ARS266ZBS Side by Side Refrigerator
Hi the fridge side of my side by side isn't working. The freezer side is still working. Any ideas?
heatman101
May 14, 2011 | Maytag MZD2766GES Side by Side...
Not Cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
gfad
Jun 13, 2010 | Samsung RS267LBBP 26.1 Cu. Ft. Side by...
Refrigerators Logo
174 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
