Question about Hotpoint (HSM25IFTSA) Side by Side Refrigerator
Freezer Door wont shut
I have a Hot Point HSM25GFTSA item#111026 the freezer door won't shut. I came home and everything thawed out so I threw everything out and jammed the door shut with a chair wedged. Is there some kind of magnetic closure that is messed up or what?
  • 65 Answers
Two things i would check. first would be an obstruction in the freezer compartment. ice bin perhaps. second would be the black plastic door cams that are to help close the door. Each door has two and they are at the bottom. one on the actual hinge and one on the bottom of the door itself.
Posted on Jan 27, 2009
GE Profile Arctica PSS26MG freezer thawed fridge not cold sounds like running rubber on fridge door hot as where it closes between freezer & fridge
The door frame has a heater in it to stop condensation and the freezer door sticking shut with ice.
As both freezer and fridge have failed, you need to call a refrigeration engineer, as it either needs more refrigerant gas or a new thermostat, or (hopefully not), a new compressor.
Oct 23, 2015 | GE Refrigerators
Freezer will not freeze ice ceam
Before you go any further it is important that you check for freezer temps. Yes, you have frozen items but remember that water freezes at 32 degrees and many items will get hard at that temp. And also remember that the lower the temp the longer frozen items will keep.
But ice cream needs proper freezer temps close to zero degrees. Use a digital thermostat and check for your freezer temp - bet it it is no where near zero. I had the same problem and attributed it to the fact that I was not using a name brand ice cream!!!! I was wrong ! LOL.
Aug 31, 2015 | Refrigerators
Wont make ice and frozen water running down door
Your inlet tube that goes to the icemaker may be frozen. To Check: Shut off water supply to Fridge, disconnect the water line that goes to the icemaker at top back. Use a flexible item to insert in the water line connection. I used a zip tie. If the flexible item won't all the through to the ice maker, the line is frozen. Thaw out the tube from inside the freezer with a hair dryer. Re-connect everything, you now have ice . . . Solution #2: You may have to replace your "Water Inlet Valve" located at bottom right rear of Fridge. Easy to do, just follow the color codes, be sure and shut off the water.
Jun 06, 2010 | Whirlpool GS6NBEXR Side by Side...
Side by side Amana freezer/refrigerator thawing.
The doors not being shut can make it freeze up,Just thaw again and make sure the doors get shut each time and see what happens,just post back details if it doesn't work after thawing
Aug 05, 2009 | Amana ASD2625KE Side by Side Refrigerator
Our freezer has been running nonstop to refreeze everything and now it is blowing warm air. What do we do? Unplug for a break or just shut the door?
Have u checked the thermostat setting? Set it as u usually do and if indeed the door was left open, then try shutting it down for(unplug) 10-12 Hrs and see if behaves normally after wards(set the thermostat too).
If not then have the thermostat replaced.....sodeep
Jun 02, 2009 | Maytag MZD2766GES Side by Side...
Everything works but no water
Try turning down the freezer a little.
You can 'thaw' the water line in the door by hanging some towels in the freezer with the door open. Should thaw in a couple hours. At least this way you don't need to empty the freezer.
Dec 08, 2008 | Hotpoint HSS25GFP Side by Side...
Chest freezer lid
Vacuum is caused by contraction of air. If your temperatures are being maintained the difference in how easily the lid opens and closes is not a point to worry about. If the lid wont shut after it is opened you do have a problem. If the lid is staying open at one corner try, with the lid open give it a slight twist pulling on the corner that is not closing fully. This action should spring the lid back to its original sealing position.
Jun 12, 2008 | Freezers
Top of freezer thawing
Ice build-up in the area of the door could be causing the door gaskets to loose their seal. Shut the unit off and use a hair drier to melt the ice away from the door area. Return the control to run position and see if it makes a difference.
May 14, 2008 | Kenmore Freezers
Kitchen Aid Model KBLC36MHS01
The drain under the evaporator is frozen/plugged.  You can take the back panel inside the freezer off and run hot water down it to thaw it out completely and this will solve your problem.
Oct 17, 2007 | Refrigerators
Hotpoint (HSM25IFTSA) Side by Side Refrigerator Logo
97 people viewed this question
Top Hotpoint Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Gil Shultz
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
