Question about Kodak ESP Office Equipment & Supplies
Kodak 3250 printer pulling multipule papers causing jam
  • 669 Answers
Most likely, the rollers are worn out. Since this is a consumer grade printer, you will be unable to replace the rollers. You might pull the paper tray and try to clean the rollers with rubbing alcohol. Sometimes this will work, but most the time the wear is enough that nothing will stop the printer from feeding multiple sheets.
Posted on Feb 13, 2012
SOURCE: kodak #G600 printer dock/roller won't pull paper through
I read this solution to a problem someone else was having which was similar to my problem. I wiped off the roller with a damp cloth, made sure it was dry and that's all it took to allow the roller to be able to start to pull the paper through. - thanks for the help!
Posted on May 28, 2009
ghassun
  • 499 Answers
SOURCE: Samsung ML 1510 LAser Printer
check the spring if it push the roller well or it's weak also check ur paper if its high quality to be rolled
Posted on Jun 12, 2009
Fame_Guru
  • 483 Answers
SOURCE: Paper jamming in printer. Pulling one side before
Answer:
Fixing a printer paper jam
When working with any printer it's inevitable that you'll encounter a paper jam. Below are the steps you'll want to follow when this occurs.
1.Turn off the printer.
2.Inspect the location or tray the printed paper ejects to. If the stuck paper is visible manually remove it.*
3.Remove all paper trays and any paper that may be stuck between the tray and the printer. If the stuck paper is visible manually remove it.*
4.Open the printer door that allows you access to the printer ink cartridges or toner and look for any stuck paper. If the stuck paper is visible manually remove it.*
5.Turn the printer back on. If you continue to receive a printer jam error try repeating the above steps again. If issue still persist and you see no paper that is stuck in the printer it's likely your printer is experiencing another hardware issue and we suggest contacting the printer manufacturer for additional assistance and/or repair.
* To manually remove paper pull on the paper with both hands being careful not to tear the paper while pulling it. If you're unable to get to an edge of the paper that allows you to pull it you may need to manually rotate the gears that feed the paper through the printer.
Preventing a printer paper jam
As mentioned earlier it is inevitable that you will encounter at least one paper jam during the life of your printer. However, if you're encountering frequent paper jams following the below steps can help prevent paper jams from occurring.
•If your printer has a paper tray do not fill the tray to capacity. If you're encountering frequent paper jams reduce the amount of paper you place in the tray each time it is filled.
•Make sure you or the tray feeding the paper into the printer is aligned properly and/or the slider used to hold the paper in place in the tray is snug with the paper. Many printers have sliders that allow different types and sizes of paper to be fed into the printer. If the slider is not properly positioned it can cause paper jams.
•Use standard office paper; folded paper, paper with labels, and specialty paper such as hard bound paper can often cause paper jams. If you're uncertain with what type of paper you should use with your printer your printer documentation will list the types of paper compatible with your printer.
•Do not mix the types of paper you're feeding into the printer at one time. If you need to change the type of paper or size of paper being used removed any other paper currently in the printer before inserting the new paper.
•Examine the printer for any previous stuck paper in the printer. Previous paper jams, torn paper, printing labels or other foreign objects in the printer can cause reoccurring printer jams.
Posted on Jun 24, 2009
SOURCE: canon mx300 printer feeder pulls unevenly causing paper jam
the left side of the printer pulls the paper causing the printer to jam when trying to print
Posted on Jul 10, 2009
  • 10406 Answers
SOURCE: paper is pulled into printer unevenly causing paper jam
Look closely at the "path" that the paper takes through the printer -- you probably have a small piece of paper stuck somewhere, that is causing the paper-feed to get "skewed".
Failing that, take the printer to a qualified technician.
Posted on May 27, 2010
How do you replce paper jam dor onkodak esp3250
Click on the link below to download the Kodak ESP 3250 user manual, inside this manual will explain how to reinstall the back panel
http://www.retrevo.com/support/Kodak-ESP-3250-Multifunction-Printers-manual/id/23553bh846/t/2/
Sep 07, 2014 | Office Equipment & Supplies
I have a Kodak ESP 3250. The printer keeps saying there is a paper jam. I have removed all paper I can see. If there is a small piece of paper in it I can't see it. Is there anyway to get to it to...
If everything is ok and printer is not printing it needs to be checked manually now. If you wish you can contact me at +1631-855-3940
or through IMO app +918510879267
Feb 17, 2018 | Kodak Esp 3250 Allinone Multifunction ( ...
I can't unjam the paper on my kodak printer
Just pull it slowly while pressing the button on the printer.
Oct 20, 2012 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak all in one printer taking in paper crooked and jamming every time!
look for a piece of paper blocking the path.
or a feed roller that's crooked.
something is catching the paper and making it go crooked.
Mar 29, 2011 | Kodak Esp 3250 Allinone Multifunction ( ...
Kodak ESP 3250. Error 3527. I put new ink cartridges in.It started to pull the paper thru then stopped. I had to remove the paper buy pulling it back out. It says Printhead cartridge jam. Open printer...
Contact Kodak. I think it's the batch of printers that were made around this time. I just contacted them (mine is the same age and I'm getting the same error), and they are sending me a new printer.
Feb 02, 2011 | Kodak Esp 3250 Allinone Multifunction ( ...
We have a sp 3250 all in one printer. We had a paper jam. We removed the paper jam and now the printer is telling us that there is still a paper jam. Please tell me what to do next. Thank you.
It is just sensing as if you haven't yet removed the jam. So, while switched on, keep pressing the load or toner or cancel buttons on top. Also make sure you cleared the printing queue that was instructed when the paper jammed.
Dec 04, 2010 | Kodak Esp 3250 Allinone Multifunction ( ...
There is a paper jam in my printer and i have removed to rear cover but there was no paper that was jammed.
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Nov 04, 2010 | Kodak Esp 3250 Allinone Multifunction ( ...
When i try to print with my esp 3250 it says error: paper jam remove rear access cover. clear all paper. attach cover. press OK to continue.. but it doesnt work???
on the back there is a gray cover on the back right side there is a tab u push in and pull it out but mine is doing the samething and there is no paper in it
Jun 22, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
52 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
