Question about Hotpoint Washing Machines
WT761 F08 PROBLEM - Hotpoint Washing Machines
F08 error code
F08 error code: Door open when program started
May 01, 2015 | Bosch Washing Machines
I have flashing lights on Hotpoint WT761 washing machine when I turn it on?
SOURCE: have a hotpoint wt761 washing
http://www.recommendedbuys.co.uk/household-appliances/washing-machines/hotpoint-wt761.htm
as you can read in these site that is a grate problem with the model allso the company tech is talking about to chage the machine insted repair so all I can say is that you have problem with the computer board of the machine,
Oct 05, 2014 | Washing Machines
What is F08 error means in Ariston washing Machine
You did not specify model!
F08 - Heater relay cannot be activated
  • Check wiring
  • Check pressure switch and connections
  • Tap relays as they can jam on new boards
  • Check electronic control PCB
  • Check heating element
Dado
Jun 21, 2014 | Ariston Technologies Washing Machines
Whirlpool f08
whirlpool f08
f08 e03 error codeF8E2 is DISPENSER SYSTEM ERROR - Dispenser motor is unable to reach the desired position. Possible causes: Check the mechanical linkage from the dispensor motor to top of dispenser. See TEST #12 (Dispensor Distribution System) on page 21. Someone else can post to contents of Page 21. Good luck.
Read more: http://forum.appliancepartspros.com/washer-repair/529426-f08-e02-error-codes.html#ixzz34yTou7Nz
Yes, it is a dispenser system error. The technician manual says to check the mechanical linkage from dispenser motor to top of dispenser.
However, in my case this page from whirlpool was helpful:
https://www.whirlpool.com/product-he...r-code/PH5260/
It says a common solution for this error (f8 e2) is:
The detergent drawer or detergent cartridge might be clogged with detergent. Clean out the detergent cartridge per Use and Care Instructions.
If cleaning the detergent cartridge did not correct the problem, please contact us.
For any additional questions, please call our Customer eXperience Center toll-free at 1-866-698-2538, Monday through Friday 8AM-8PM Eastern Standard Time.
You will be asked to provide the model and serial number which is found on the front door rim after opening the door.
So I washed out my dispenser and now it's working again.
Read more: http://forum.appliancepartspros.com/washer-repair/529426-f08-e02-error-codes.html#ixzz34yTzjNdt
May 15, 2014 | Whirlpool WFW94HEAW Duet Front Load Washer
Hotpoint wt761
Crash on progrmming
Apr 08, 2014 | Washing Machines
Have a hotpoint wt761 washing machine which is displaying a f-08 error code
as you can read in these site that is a grate problem with the model allso the company tech is talking about to chage the machine insted repair so all I can say is that you have problem with the computer board of the machine,,,,good luck and rate me
Jan 01, 2008 | Hotpoint Ultima WF860 Front Load Washer
F08
your heater relay is stuck check all wiring connections to and from heater
Sep 14, 2007 | Hotpoint Ultima WF840 Front Load Washer /...
Washing Machines Logo
27 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
freddyfox
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
