Question about Kenmore Sewing Machines
How do you unfreeze a machine that has seized up? I have a Kenmore model17921 sewing machine that usually works great. I have been sewing a large project over the last several days and the machine developed a sweaking noise then froze. I can't turn the hand wheel at all. Any suggestions as to what the problem is?
  • 19 Answers
SOURCE: Bernette 800D seized up
Please don't use WD40 on your sewing machine, WD40 is an alcohol based cleaner and will do the opposite of lubricate. Take your machine to a certified Bernina Repair shop, they will have a look at the timing and lubricate all of your gears. Lubricant will dry out over time, grease turns to putty and oils turn to varnish after several years of non-service. Lint is attracted to moisture, moisture being those key areas of any machine. Lint acts like an oil wick and will draw out your lubricant from key areas. It then begins to attract dust and other nasty things over the years to become grit. Your motor begins to burn out due to stress trying to move all of these clocked gears, cams and shafts. Take your machine in!
Posted on Dec 10, 2008
MNfisherman
  • 11896 Answers
SOURCE: hand wheel won't turn and machine won't work
  • Sewing machine has been run at a low speed for an extended period of time.
  • To prevent overheating, motor power is automatically turned off.
Turn power off and wait about 20 minutes. Safety device will reset, and machine will be ready to operate, If this by chance doesn't work, Here is a diagram of a typical sewing machine. This fuse should be in the back next to the power box or motor564d4f7.gif
Posted on Jan 20, 2009
  • 323 Answers
SOURCE: can't tighten clutch on Kenmore zig zag sewing machine.
The clutch has fallen off the shaft. Remove the very small screw in the clutch release screw to remove the clutch release. Place the clutch(round thing with ears on it) back on the shaft with the center ears pointing towards the outside. Put the clutch release screw back on. Tighten it to make sure it works
properly. Put the small screw back in the clutch release screw and test it again. If it will not tighten or release properly, remove the clutch ,rotate it180 degrees and try it again.This should solve your problem.
sewman7
Posted on Feb 16, 2009
  • 323 Answers
SOURCE: Sewing machine motor may have seized up
The oil and grease in your machine has turned into a very sticky, syrupy mess and needs to be chemically removed . My guess is that even if you were able to get the machine to turn freely it wouldn't zigzag . I really recommend that you take the machine to be professionally serviced again and do not let it sit idle.
Once it is serviced,test it before you bring it home again. These things are kind of tricky sometimes.
sewman7
Posted on Apr 06, 2009
  • 96 Answers
SOURCE: Hand wheel wont turn on my Kenmore sewing machine
it sounds like the belt to turn the wheel broke
Posted on Dec 13, 2009
Should I oil the motor on a kenmore sewing machine model 158.905?
Do NOT oil the motor unless the manual instructs you to do so. (Sears carries manuals for most of their machines.)
Your machine appears to be an older mechanical machine. As such, oiling would be necessary for the moving metal parts. The following may be helpful to keep your mechanical machine happily operating. (Although the following is for machines that have seized due to lack of oil, following the procedure is helpful in preventing the machine from seizing.)
Wheel on right side that controls the needle up and down is very tight...
May 06, 2017 | Kenmore Sewing Machines
I have an old Kenmore Convertible 1785 machine. It is working fine except it won't pull fabric thru. Any suggestions on what could be wrong?
Are the feed dogs in the up position? Is your fabric very slippery or silky? If it is you need to use a tear away for the feed dogs to grab on to I order to move the fabric forward.
Nov 26, 2016 | Kenmore Sewing Machines
Kenmore sewing maching model 17922 seizing up. I have oiled it and cleaned it but it still will not work. Suggestions? It was working fine, then just stopped.
Depends with what and where it was oiled. Use only fresh good quality sewing machine oil--NOT 3-in-1, WD-40, cooking oil, or grandma's old stinky brown sewing machine oil.
When a machine has seized, I prefer using liquid Tri-Flow Synthetic Lube (hardware store or bike shop). Open the top, side over the needle bar, and the bobbin area. Gently wiggle the handwheel and apply 1-2 drops each place where metal rubs on metal. Do NOT oil belts, synthetic gears, cams. Then direct hot air from a handheld hairdryer into the internal mechanisam. Get the metal parts hot. If it still doesn't move freely, repeat. Avoid over oiling as the result is you will be spending a lot of time mopping up the excess.
In the future, oil the shuttle/hook every 8 hours of sewing, do a light all-over oiling (as described above) every 40 hours of sewing, or every six months if the machine is in storage or not in regular use.
Oct 23, 2016 | Kenmore Sewing Machines
My sewing machine has stopped working, it was working ok , just a bit noisier than usual but now the needle wont move at all, even if i try to turn the wheel by hand
the machine may need oiling, check in your sewing machine manual to see about oiling it, it's also possible that the machine could have a damaged or broken part inside,,
Mar 17, 2016 | Singer Inspiration 4210 Mechanical Sewing...
My kenmore sewing machine is stuck in the reverse mode
The feed assembly is starting to seize. You will have to take it in to be serviced
Jan 04, 2015 | Kenmore Sewing Machines
Hand wheel seizedhandw
Is the hand wheel seized and you can't free motion to wind bobbin?
If so it's usually simply done up too tight. Or is it and the machine seized?
Feb 18, 2014 | Kenmore 12912
I have a singer inspiration 4228. When I tried to
If you have pushed the winder over and it is not turning either the winder rubber has worn down one side, or there is residue on the winder rubber, or the bwinder has seized through lack of oil which is quite common, with the winder in the off position see if you can spin it by hand, if you can't then chances are it has seized, put some WD40 oil on the top of the spindle and leave it overnight, then put an electric drill over the top of the spindle and switch on slowly, that usually works.
Mar 05, 2010 | Kenmore 11101 Mechanical Sewing Machine
Mechanical sewing machine binding
Usually what we see with these machines is that the hook drive gear behind the bobbin case seizes up check here first and lubricate this area .
Jan 13, 2009 | Brother XL-3510 Mechanical Sewing Machine
Kenmore sewing machine 15343
I had this problem but have resolved it (for the most part) by lowering the needle down into the fabric before beginning to sew.
Aug 12, 2008 | Kenmore 15343
Sewing Machines Logo
46 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
SewTechWayne
SewTechWayne
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
