Maxim mx11-23 set-up - Computers & Internet
How to set the timing on a maxim x?
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
timing marks not correct on 1985 700 maxim please help
Maximum Maxim Resource for 1985 86 Yamaha 700 750 Maxim Models XJ700X and...
Yamaha XJ700N Service Manual
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-xj-owners-manuals
Aug 09, 2014 | 1985 Yamaha XJ 700 X Maxim
Tip
How to set Internet Explorer 8 to open in maximized window always?
I saw most of the people were asking for the option to maximize all Internet explorer windows size. There are some tricks which might work only for some windows but not for all the Internet Explorer windows. As I am working as a technical support, I found an option to set all Internet Explorer Windows maximized.
I will provide you the steps to set this potion, please try this and let me know if this worked for you.
1. Open Internet Explorer and press F12 to open Developers tools windows for Internet explorer.
2. Click on Tools and select Resize.
3. Select the maximum screen resolution size you have.
4. Close the Internet explorer and reopen it to get the maximized windows.
From now you will be able to open any Internet explorer windows in maximized size even though if you open a link right clicking on it and select "Open in a new window".
Ref: http://www.techiesspot.com/index.php/topic,312.0.html
on Mar 17, 2010 | Computers & Internet
Look for service manual
If you're looking for the service manual for an XJ700X, you should know that the factory manual a) has errors and b) doesn't distinguish between the 85 XJ700X and the 86 XJ700X... and there ARE differences. In any case, you're much better off visiting www.xjcd.org to order what's known as "The XJCD set". That set of CDs contains a lot of updates, clarifications and corrections that were unknown at the time of printing 28+ years ago. If you want to read more about the XJCD set, visit this link on the Maximum Maxim-X web site: http://www.maxim-x.com/notes.html#xjcd
Feb 12, 2014 | 1985 Yamaha XJ 700 X Maxim
Does a pit **** ever go bad or just cleaned?
I'm going to guess that "pit ####" meant petcock :-) and yes they do "go bad" in a number of ways. There is a diaphragm inside which can crack over time. There is also a diaphragm return spring which may break (I've seen only one like that though). But most often, the use of fuel with ethanol in it will cause the breakdown of the plunger seal. When that happens, the petcock "leaks".... not externally but internally. The Maxim-X has a vacuum operated petcock which is supposed to only provide fuel to the carbs when set to PRI (prime) or when set to ON while the engine is running. When the engine is off, there should be no flow of fuel. But the damaged plunger seal allows fuel to flow from the gas tank to the carbs at all times, even when the engine isn't running. When you combine that leak with a leaky float valve, the result is usually a crankcase full of gasoline - clearly not good. If you'd like to know all there is to know about the XJ700X / XJ750X petcock, visit the following page on the Maximum Maxim-X web site:
Maximum MAXIM Resource for 1985 86 Yamaha 700 750 Maxim Models XJ700X...
There are also some helpful tips for rebuilding the petcock here:
http://www.maxim-x.com/pix/petcock/maxim-x_petcock_repair_tricks.txt
...with supporting pictures here:
Index of pix petcock
Hope that helps.
Jan 15, 2014 | 1985 Yamaha XJ 700 X Maxim
Service manual
If you want a service manual for the Maxim-X, I recommend that you buy the XJCD set from XJCD.org. The PDF service manual on the XJCD contains many corrections and clarifications that the factory manual never had. Plus you get the Owners Manual too, as well as a bunch of other things that you can read more about here: http://www.maxim-x.com/notes.html#xjcd
The Maxim-X service manual on the XJCD has the benefit of 27 years of hindsight and observation.... and it costs a whole lot less than the factory manual.
Aug 10, 2013 | 1985 Yamaha XJ 700 X Maxim
Instuction for use of maxim talking alarm clock
i have got a maxim alarm clock and i don't know how to use it.I think i threw the instructions away would you be able to tell me how to set the time please.
Oct 19, 2012 | Audio Players & Recorders
Camshaft timing mark setting for yamaha maxim 400
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere zero $ you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Camshaft timing mark setting for yamaha maxim 400 Google Search
How do confirm cam timing is correct
Yamaha XS360 Service Manual
http://mybikemanuals.com/yamaha/yamaha-xs-owners-manuals
Feb 04, 2012 | 1983 Yamaha XS 400 L Maxim
1986 Yamaha XJ 700 X Maxim float setting
Hi, Stormy92 for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "Free" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
http://xjbikes.wikidot.com/carb-specs
http://www.xj4ever.com/setting%20fuel%20levels.pdf
Apr 15, 2011 | 1986 Yamaha XJ 700 X Maxim
Flaot setting for 81 yamaha 650 maxim (4 ea.)
# 1carb left 0.04+or-0.04 inches mm 1.0+or-1.0 # 2 carb right 0.08+or-0.04 2.0+or-1.0 hope this gets you there
May 30, 2009 | 1981 Yamaha XJ 650
Need to set floats on an xj 700
with the float bowl off and holding the carb level, adjust the float where it is level and the jet is up enough to seal. float should be set then.
May 03, 2009 | 1985 Yamaha XJ 700 S Maxim
Computers & Internet Logo
David Payne
David Payne
