Question about HP Computers & Internet
Monitor gos black turn off then back on video stays on 15 sec then off again
I have a acer LED monitor on a HP E9180F The monitor go black I can turn off and back on get video for 15 sec then back to black What could be causing that
  • Richard Young Feb 13, 2012
    supply Blub in monitor going bad Had to replace Monitor
  • 400 Answers
Hello
It could be a bad monitor or videocard ,the only way to test this is by connecting another monitor to that PC or your monitor to another PC.
Good Luck
Posted on Feb 13, 2012
  • 4 Answers
SOURCE: HP PAVILION 760n
tell me if there is something i need to know like: what were the things that you've doing with your computer before the problem happened?? are there any recent hardware/software changes?? tell also your OS- is it XP or Vista...
first, let's try to check if the problem is with the monitor or not,okey? try unplugging the monitor blue connector at the back of the tower.and make sure that your monitor is turned-on.If you can see a colored bars displayed.you monitor is okey.if not, try a known good monitor...if it woks the problem is with the old monitor.(resolved)
2 (if not)
Now, complelely turn off your computer and try reseating all the cables, and your hardware components such as memory,video card,IDE cable and so on. but before doing so, unplug the power cable and then push the power button to drain the power.after reseating everything, plug back the power cable and turn on computer.try listening to the tower,tell me if you can hear some beeps also.
if no video issue is still there, try putting a known good video card if you have any.if a known good video card works then the problem is with the old one..
if the problem is still there after everything that you've done try calling the manufacturer. this is lead to a motherboard problem but try to call them first.
Posted on Jan 17, 2008
  • 13433 Answers
SOURCE: Replacing monitor on a Dell 4600C w/ Acer monitor X183hb
Hey,
Yes, if the connector does not fit then you need a DVI to VGA adapter.
like this
http://www.thebidfloor.com/images/video_cards/DVI_VGA_ADAPTER.jpg
and it will work.
Let me know if you need anything else.
Thanks,
Ekse
Posted on Feb 18, 2009
  • 199 Answers
SOURCE: acer aspire ase380 power switch problem
do you get the self test screen on the monitor. is so it is not communicating with comp. bad video port most likely
Posted on Jun 27, 2009
gvctts
  • 103 Answers
SOURCE: S-video input from Panasonic MD830 S-vhs to
It seems the the monitor is not supporting the resolution you have selected in display settings of operating system. therefore please minimize the resolution of display then check your monitor. hopefully it will work
Posted on Sep 03, 2009
byteguy
  • 2229 Answers
SOURCE: Acer desktop mouse,keyboard not functioning, monitor also not wor
If there is no display on the monitor, then your computer is not sending a video signal to the monitor.
This could be caused by a bad video card or some other hardware problem. I would open the case and disconnect all the devices (hard drive, CD, etc. Leave only the CPU, memory, and video connected. You could leave the keyboard and mouse connected too.
If your computer then starts, you can start to add devices (after turning the computer off) one at a time.
If this doesn't work, then you are looking at replacing the motherboard or just the video card if that is possible.
Posted on Nov 05, 2009
Computer screen keeps going black,,turn the monitor off and on,,screen come up for a bit,,the d sub appairs then gos black again
Hello there
You dont say which machine you have but a common problem is they are set for the WRONG input,
Have you checked using the 'onscreen' menu,of the monitor that you are looking at the right INPUT ???? D-sub is the 15 pin video cable input from your computer to the monitor. .It will go dark if you are not supplying a signal on that input.
Sep 24, 2014 | Computers & Internet
HP Pavilion F1503 only displays a split second?
well, its a 2003 LDC 13 years old ,
its bad
the monitor itself of the power pack to it is bad.
you can test it on any PC< or laptop made
if its dead on all , then its dead.
what more needs saying,
older LCD monitors had old CCFL, lamps. that love to fail
newer are LED back lights that last for ever. it seems
so up grade?
seems your back light is dead
ever do the flash light trick
shine it at the dead screen see good data
yes, then the CCFL is DEAD< (or its power supply ,deep inside)
fixed may but would never do a 2003, not now.
lots of used good LED for sale,
Mar 09, 2017 | HP Pavilion F1503 15" LCD Flat Panel...
My monitor won't stay on it will go black after a sec. If you turn it off then on the monitor will work for a second the it goes off again. I have unplugged cords and it still does it. I have a hp f2105
It is "normal" for a monitor to "go black" when it is NOT connected to a computer.
Connect it to a different computer, to see if the video-card on your computer has failed, and to see if the LCD monitor works at all.
Dec 15, 2010 | HP f2105 21" LCD Monitor
Acer monitor swtiches itseolf off in i9n about 15
After much ado and waiting for tech support from Acer, remembered that some years ago something similar happened with a printer so I downloaded a new driver from acer for the monitor onto another computer, copied it to cd and then with much fiddling installed this on the acer, as it was installing monitor started to flicker and finally lit up again normally. Now working perfectly! When tech support phones, will tell them!!!!!!
Nov 20, 2009 | ViewSonic VX2235wm LCD Monitor
Recently, I purchased an Acer H233H LCD Monitor with the HP e9180f Desktop. However, the built-in stereo speakers in the monitor are not working. The sound card in the desktop is fine, as headphones and my...
Try installing the Acer Monitor software and disabling the the desktop sound card under 'My Computer'. 'Properties','Hardware Devices'.
Let me know if you need help doing this, or need more help.
Jul 25, 2009 | Acer H233H bmid Monitor
Screen goes black
It could be a bad backlight bulb.
Sep 08, 2008 | HP vs15 15"LCD Flat Panel Monitor
LCD Monitor
is it connected to a PC? is the power source good 110v or 220v?
Mar 30, 2008 | Computers & Internet
Power button stay on for 2 seconds, black screen,no picture
hi there, yes, you do have a broken monitor, bring it to qualified service personel how can repair the monitor. or you can just simply replace it. TY
Nov 29, 2007 | HP vs15 15"LCD Flat Panel Monitor
Monitor going black
My HP f1703 is almost 3 years old and started having this same problem. My fix got the display to stay on. Don't know how long this fix will work. I set the monitor brightness to 51 and contrast to 41. You may have to adjust to your levels to your appropriate enviroment. Levels may determine how long the monitor stay operational. Do NOT set your monitor brightness to factory levels it will just start to recreate the problem again. Solution: The monitor should be on with the blue button lighted. If the screen is acting up (you turn it on and the display lights up and then it turns off within 2 to 5 seconds) Try decreasing the brightness level down as much as possible. Wait 15 to 30 seconds and see if the display comes back to life. If not, turn the monitor off and on again and try the procedure again, if necessary. Cause: I believe the monitor brightness level, set at 100 by the factory setting, is over driving the display and causing the protection circuit to cut off the flouresent lamps that light the display. HP had an issue with this display, and had a notice to replace them if the problem occurred during the warranty period. They extended the warranty period from Jun 04 to Feb 06. Check with HP Technical Support to determine if your monitor is cover.
Oct 10, 2006 | HP Pavilion F1703 17" LCD Monitor
Computers & Internet Logo
57 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
