No power when switch on the power heater dose not work
  • 3 Answers
Have you checked the fuse?
Posted on Feb 13, 2012
I have a 2005 chevy avalanche and the heater ac dose not work changed the blower anad resistor still dont work any suggestions
The blower switch in the dash may be the problem here, remove the panel and check the switch for signs of overheating and discoloration.
Dec 09, 2016 | AC Cars & Trucks
I have a 1990 daihatsu applause. It has not power. The only thing that works is the hazard lights. Battery is good and all the fuses are good.
Have you run a fault code test to see if any thing shows up? You will need to know how to run an OBD1 test, it may require a special tool, not sure due to age of the vehicle
Jun 30, 2016 | Daihatsu Cars & Trucks
Could I put a toggle switch in my car instead of a ignition switch in a 2001 Chevy cavalier? What all dose a toggle switch require to work? What dose it all need to connect to?
On vehicles that have several control modules connected by serial data circuits, one module is the Power Mode Master, PMM. On this vehicle the PMM is the BCM. The PMM receives 2 signals from the ignition switch.
To determine the correct power mode the PMM uses the following circuits:
Accessory voltage
Ignition 1 voltage
Sep 29, 2015 | Cars & Trucks
I have a Deammaker hot tub. The tub works and pump is running. When I turn on the air valve the is no change in jets. The air vave is opening when turned.
I don't know this model but most hot tub have a micro switch on the valve that starts the compressor to confirm turn the power off then removing the access panel and take the wires of the switch and connect to gether then turn back on if the compressor is working then the switch needs replacing if it is not workin the the compressor is faulty
Jan 18, 2015 | Dream Maker Spas Pool & Spa
The heater dose not working in kia sorento 2006
Kia tends to have rather poor heater control switches and motors. If your car has manual dials, then check any cables and fixings on the back of the control panel. These cables can come loose and fail to push and pull the armature on the heater matrix valve. If the car has an electronic climate control, then check the electric motor on the heater matrix valve as it may have failed.
Oct 30, 2012 | 2006 Kia Sorento
My heater dose not appear to be powered on. power source is good but heater will not power up and engage.
You may have a blown fuse, transformer, or roll out switch in the heater. Do you get any lights or display at all?
Sep 20, 2011 | Pentair Pool & Spa
Heater problem
Check the heater valve on the engine firewall. If it doesn't open when you move the temperature switch to hot open the valve manually. If the heater blows hot air the cable from the switch has failed.
Jan 02, 2010 | 1995 Chevrolet K1500
My vw passat tdi 05 radiator fan dose not come
check fuses..came across a bora with much same problem..it turned out to be a coolent tempreture switch the heater gauge wasn't working and on diagnostics it was reading -41degrees celcius the fan was not running because it thought it was freezing outside also blew the fuse of the fan also
Jun 18, 2009 | 1999 Volkswagen Passat
Blower/heater speed control switch just spins=no heat or anything
I found your blower motor switch here for $24.33 plus Shipping and handling. Thank you, and don't for get to vote. http://www.audiporschevwparts.com/
Jan 29, 2009 | 1989 Audi 80
Heating & Cooling Logo
18 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
