Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
Posted on Oct 24, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Washer dryer not drying properly model WD440
MY WSHER DRYER NOT DRING PROPERLY EVEN AFTER ONE HOUR DRYER CYCLE. HOW CAN I CHECK THIS
Anonymous
Level 2:
Scholar:
  • Expert 155 Answers
  • Posted on Oct 26, 2008
Anonymous
Expert
Level 2:
Scholar:
Answers
155
Questions
Helped
57683
Points
374
Http://www.washerhelp.co.uk/washing-machine-usage.html
check out this link
aNd also this link for better help
www.applianceaid.com
goodluck
thanks
the heating element of you dryer broken already
Hello my dryer doesnt work properly it runs
The valve resistance is 1995 ohms and the ignitor is 185.
Inspect the dryer venting from the rear of the dryer to the outside vent hood of the home.
If there's a restriction in the vent--the clothing in the dryer takes longer to dry.
When the dryer is functioning normally---the time required to dry laundry is determined by the *Sensor* located on the drum side of the lint filter housing and by the main control board.
When laundry is near dry--any Time Remaining on the control panel that is *not* needed will be eliminated---except for the last 6 minutes.
The final 6 minutes of any automatic cycle is for cooling down the laundry before the dryer ends the cycle.
If a dryer *counts down* to the last 6 minutes but the laundry is still not dry--the computer will allow the dryer to run until the laundry has dried or defaults (not drying within the additional time allowed).
Dryer vents that are longer than 8 feet with more than (2) 90 degree turns--can affect drying performance.
Setting the DRY LEVEL selector to *Very Dry* will solve most dryability issues. In homes with abnormally long vents--even the longer run time in the *Very Dry* setting is usually not sufficient to dry laundry loads.
Reducing the length of the vent or starting a second cycle becomes necessary to fully dry the clothing.
If a second cycle was started---only the amount of time that is needed to dry laundry will be used before dropping to 6 minutes and then the cycle will end with dry laundry.
LG gas dryers are more sensitive to venting length and air flow resistance. The gas burner can cause a rapid increase in temperature compared to an electric burner.
Rapid temperature rise in a gas dryer leads to premature burner shutdown (longer time required to dry laundry).
The gradual temperature increase of an electric element is more "forgiving" in homes where the dryer venting is less than ideal.
Problem:
The dryer has an auto dry feature which never fully dries the clothes so we wind up manually setting the dry time to an hour
Solution:
LG gas dryers are VERY temperamental in long vent set-ups. If fabric softener sheets are used in the dryer--clean the two stainless steel strips of metal on the lint filter housing with a SCOTCHBRITE PAD--scrub back & forth several times to remove the waxy residue from the fabric softener sheets. Most,if not all manufacturers do *not* recommend using sheets in dryers that have a moisture sensor (electrodes).
However--using a SCOTCHBRITE pad keeps the wax off those sensors which can be seen if looking *into* the dryer drum and at the lint filter housing.
If only *liquid* fabric softener is used in the washer--clean the dryer sensors once a month. Liquid softener also contains wax which can slowly accumulate on the dryer sensors from the laundry washed in the washer.
LG dryer manual
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
2answers
We have a Kenmore 400 Series dryer. It heats up but our clothes is not getting dry. We have to cycle it twice to get our clothes dry on high heat. Any idea why it would take 2 cycles to dry?
This was the out vent of my dryer... If it gets this bad... open up the dryer housing and clean inside too. Also make sure the intake is free of lint.
Dryer not heating very hot. need to run two cycles to dry
Dryer is not drying properly, In order to resolve try following things.
  • Check the exhaust hood outside the house, does it open and close freely, Clean the lint filter and exhaust duct.
  • Do not overload, 1 wash load = 1 dryer load. Sort heavy items from lightweight items.
  • Large, bulky items like blankets or comforters may require repositioning to ensure even drying.
  • Check the washer to be sure it is draining properly to extract water from the load.
  • Clothes load is too small to tumble properly. Add a few towels.
I hope this will solve your problem.
Good luck and have a nice day.
2helpful
2answers
Hotpoint aquarius wd440. Flashing lights
press and hold on off button till the display panel lights up.Then press and hold the on/off button and the start /cancel button together.You will now reset the washing machine settings.And just pick your cycle again
Dryer capacity
Yes, a full size dryer as yours is easily capable of drying a full sized load from the washer you mentioned. The wash tubs in the new model washers and dryers still maintain a standard size. For example, the front loader dryer that I purchased to match my front loader washer is completely identical to earlier standard models without all the fancy packaging. I could have saved some money and purchased only the washer, but...the wife needed a matching pair.
Now, you will still have to properly sort items to ensure they dry efficiently. A copy of your dryer owner's manual will describe this to you. I'm not here to give you lessons in how to dry your clothes, but if you do not own a copy of your manual and would like to refer to it, you can obtain a copy at geappliances.com. Just look under the "Service and Support" section for "Use and Care Manuals". Just type in your model number and your owner's manual is availble in a downloadable .pdf format.
The point I'm attempting to make here is that although you can place a full load from your washer in the dryer, if you do not properly separate certain items, they will not dry properly. I did not want you to think this was a cause of the appliance.
In addition, make sure the dryer vent ducting is properly cleaned and not clogged anywhere. This can also contribute to longer dry times.
I know you were only asking a simple question. I just wanted to be thorough in case additional question may arise. I hope this information is helpful to you.
Nov 14, 2008 • Dryers
Not drying
the steam gets condensed back to water and pumped away so sometimes draining problems cause poor drying. is the machine plumbed in according to handbook?
also your dryer filter may be blocked but this is not accesable without the dryer box being stripped down.
Clothes wont dry but gets really hot
make sure your exhaust line is clear and not kinked
Hotpoint wd440 heating but not drying
yes, the dryer is pants im afraid. weve had ours going on 4 years & it has broke down every 6-10months - seriously! the dryer will leave clothes hot & steamy but when hung up for 1/4hr they r dry! _ Hotpoint advised us that he machine is esigned his way - but dont believe a word from their corporate b***hit mouths!
Top Hotpoint Washing Machines Experts
vince
Paul Carew
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
