Tape recorder belt
I have a Sony TC-63 cassette recorder with a broken belt, Sony does not carry the part any more, it is about 1/16 sqare and 9.6 '' long,( I measured the lenght with a string around the pulleys). Where can I find one?
  • adolphe Dec 17, 2008
    A 3 inch by one sixteenth O ring did the trick.
    Thanks.
Use a durable rubber band. It works for a while!
Sudhir
Posted on Dec 15, 2008
I have an unused 9 year old one, do the belts perish and fail, is it a common problem?
Belts do not have an unlimited lifespan. You may be able to get replacement belts but they are hard to find.
May 04, 2016 | Sony TC-WE475 Dual Cassette Deck...
I need to know how I can hook up my Teac EQA 5 equalizer to my Sansui AUD 9 power amp.. I lost the manual to the E/Q
It is very easy, you don't need a manual for this. The EQ line in and Line out get hooked into the record out and Tape in of one of the tape loops on the Sansui amp. Record outs go to EQ in and the EQ out goes to tape play.
Oct 10, 2013 | Sony TC WE435 Stereo Dual Cassette Deck...
The rubber belts on my sony cassette deck(TC-W380) are worn out and i need replacements.Does anyone know where i can purchase them?
Ive used o-rings from home depot with no issues before....I did a little research and the part numbers match to
http://www.ebay.com/itm/SONY-TC-WR665-WR670-WR690-WR701ES-Double-Cassette-Belt-Kit-GTD-5-YEARS-/140828351357?pt=US_Home_Audio_Cassette_Decks&hash=item20ca061b7d
I would investigate on your own to make sure, but the parts cross referenced
Aug 20, 2012 | Sony Dual-Deck Cassette Player/Recorder...
Requestin replacementsize of belts for Sony TC WE305 cassette player, not a boombox
A Tv repair shop carries a large stock of belts, probably a good place to start. The other option is order from Sony online and ask for the Technical Department.
Feb 17, 2012 | Audio Players & Recorders
Sony TC-138SD cassette deck starts to play then stops after 3 secs. Same when trying to rewind/fast forward
It sounds like the belt is slipping or broken which monitors the speed of the tape movement. When you play or rewind the tape, it thinks the tape has reached the end of play and shuts off. You can try a different tape to make sure the tape does not have too much tension on it. If the second tape has the same result you will need to remove the top cover of the deck to inspect the tape drive mechanism. Make sure the belts and pulleys are clean and replace any belts which have glazing or cracks. If the belt is broken you will need to replace it with a compatible belt of the same length and width.
Aug 15, 2011 | Sony CASSETTE DECK Single Dual Cassette...
A cassette has jammed close the A door of my Sony TC WE675. How do I clear the jam? The tape is probably keeping the door closed.
Please click HERE so that you will be directed to the site where you can troubleshoot the issue.
I hope that this will work for you.
Aug 08, 2011 | Sony TC-WE675 Single Cassette Deck
NEED THE PART NUMBER FOR SONY TC-WE435 DUEL CASSETTE PLAYER BELTS
Flat belt part number is..
301657001.. BELT (CAPSTAN)
and square belt part number is...
302440501.. BELT (FR2)
Above said info are taken from TC-WE435 cassette player s/m.
Thanks.
Dec 25, 2009 | Sony TC WE435 Stereo Dual Cassette Deck...
Cassette Tape Deck Problem
Unit may have worn belts that are slipping. All cassette player belts are subject to deterioration even if recently installed. You may try ordering the belts yourself and have a service tech install them. The tech that installed belts 9 months ago may have used used belts. Although dishonest, it is common.
Jul 17, 2008 | Sony TC WE435 Stereo Dual Cassette Deck...
Cassette Tape stuck
Try pushing the eject button while pusshing the power button. Mine was doing the same and that is how I was able to eject the tape.
Good luck
sam
Jan 01, 2008 | Sony TC WE435 Stereo Dual Cassette Deck...
338 people viewed this question
 Grubhead
Grubhead
