Question about RCA Universal Remote Control
What is code for rca universal remote to operate a sanyo TV
I entered it once, and it worked for about a week, then now it will not work at all, not even to turn on powerThe pr
    Problem Solver:
  • 17 Answers
Go to remotefinder.rca.com/default.aspx?site=rca
Posted on Oct 30, 2008
Total Control Universal Remote. URC 4140. What is the 4 digit code to operate the above TV
Search Results
    [PDF]Total Control URC-4140 - Universal Remote Control Codes
    www.remotecodelist.com/remotes/URC_4140_B00_and_B01.pdf
    UNIVERSAL. Remote control. URC - 4140 ... Your TOTAL CONTROL can operate four devices: a Television, ... The TV, VCR/DVD, SAT and AUX keys select the device.... 4. Enter your four-digit code using the number keys. The red light will blink twice.... To set up your other devices, follow the same instructions above, only.
    Codes and links for a number of universal remote controls, including Sony, RCA, ... GE Remote Codes, General instructions for GE Universal 3 and 4 digit remote controls. ... This manual may work for a number of Philips-Magnavox remotes. ... Total Control URC-4140, PDF Instruction Manual (remote also known as Crest .
Jan 13, 2016 | Sanyo 42 in. LCD TV
Hello I have a universal remote control for tv sanyo but I lossing de manual instruction and Iand ree program my tv. only I need how cam progarm my remote control pleaswed thanks.
Here is the steps on how you can reprogram your RCA tv remote control:
1. Turn the television on by pressing the "Power" or "On" button that is located on the set.
2. Press and hold down the "Code Search" button located on the RCA TV remote. 3. Press the "TV" button on the RCA TV remote. Once you press this button, you can release the "Code Search" button
4. Start pressing the "On/Off" or "Power" button that is located on the RCA TV remote. Keep pressing the button until the television shuts off. 5. Press "Enter" on the RCA TV remote to save the code on the remote. The remote will then control the television.
Apr 07, 2011 | RCA Universal Remote Control
I have an RCA universal remote and a Sanyo TV. I
Take out the batteries,leave the remote to be unpower about an hour.Let all old memory codes erase it self.Put in new batteries to the remote.Enter the codes again.Should work now.
Jun 06, 2010 | RCA Universal Remote Control
Can you switch from tv to video input on sanyo ds31520 tv without a remote
no you require the remote or a universal remote or sometimes a cable remote that has been programmed to work the volume on the tv set will have an input button .
Sep 29, 2009 | Sanyo DS31520 31" TV
Need to know how to program rca universial remote to sanyo 27inch
First off. What kind of RCA remote. and second 1.Turn on the TV 2. Press and hold the TV button 3. Enter the 4 digit code *1004,1048,1049,1050,1080,1107,1108,1162,1169,1180
4. Press the on off button (may need to press twice) 5. if nothing works try entering another code.
Note: your remote may only need a 3 number code. but most require 4
Mar 10, 2009 | Sanyo DS27510 27" TV
Help
Hi
The code for Sanyo TV from a Phillips Universal Remote is 0181.
If 0181 doesn't work,try 0506. I have a Sanyo tv and hopefully that'll work for you.
Try one of these
017,021,039,056,057,058,
0154, 1907
Check this website also
http://www.remotecodelist.com/remotes/ge/RM24912_codes.pdf
Sep 19, 2008 | RCA 3-Device Universal Remote
Hello; I bought a RCA replacement remote at Walmart last night. It is model RCR312W I have a Sanyo 15" TV that is connected directly to cable I tried programming the code into the remote and it...
The universal code for most is 049 for a Sanyo TV. With your universal remote you press the code search key until it illuminates and then you press and release the TV key. Next enter the three digit code (3 digit remote code page) and the indicator light turns off.
If you enter in the wrong code the light will flash rapidly. Aim the remote at your tv and press the on/off key. If your tv turns off then you have found the right code!
Try these codes for your Sanyo TV also: 054, 069, 023, 025. If those do not work then also try: 004, 013, 049, 108, 110, 180, 209
http://codesforuniversalremotes.com/universal-remote-control-codes-sanyo-tvs
The best solution is to buy a replacement remote for the make and model television that you actually have.
https://www.replacementremotes.com/SANYO/Remote-Controls
Feb 10, 2018 | Televison & Video
I programmed an rca universal remote by:
TURN ONTHE TV
HOLDING DOWN THE TV ANDTHEON/OFF BUTTON ATTHE SAME TIME.UNTILTHEON/OFF BUTTON STAYED ILLUMINATED.
PRESS THE PLAYBUTTON IT WILL BLINK,IF TV DOES NOT GO OFF PRESS PLAY EVERY 5 SECONDS UNTIL TV GOES OFF.
ONCE TV TURNS OFF HIT THE REVERSE BUTTON THE TV WILL COME BACK ON.
HIT THE STOP BUTTON TO SAVE THE CODE.
REPEAT THIS BUT HOLD THE OTHER DESIRED DEVICE INSTEAD OF THE TV.
HOPE IT WORKS
Igotthisinfo from google....then typed in rca universal remote...there was a sight for programming remote.
Jul 26, 2008 | Sanyo DS24425 24" TV
Need code for sanyo tv
Welcome to FixYa.
SANYO TV Codes: 0154, 0159
Please be informed that the codes vary with different make and model of the universal remote that you have. If none of the codes above work, please post back with make and model of your universal remote included.
Thank you for using FixYa.
Jas247
Sep 01, 2007 | Sanyo DS31590 31" TV
Televison & Video Logo
29 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
