Question about Olevia LT37HVS 37 in. LCD HDTV
Olevia 437-S11 stuck in standby mode
My classroom TV seems to be stuck in standby mode. Blue light is on but TV won't turn on either by push button or remote.
  • 3 more comments
  • shameem-a Nov 07, 2008
    Olevia TV set is on standby with blue light on.Unable to switch on by remore or switch
  • Anonymous Mar 13, 2014
    37 inch TV is stuck in standby mode
  • Anonymous Mar 19, 2014
    The blue standby light comes on TV and when I try to put TV on it goes off then goes back to standby mode any ideas anyone ?
  • Anonymous Mar 22, 2014
    turns off from standby mode
  • Anonymous Mar 26, 2014
    no power but have blue light
Posted on Nov 06, 2008
Saludos,tienen que bajar el firmware desde la pagina web de OLEVIA y seguir la instrucciones,esto se hace por medio de un cable USB conectado del PC al LCD,tambien hay de descargar el Driver del usb para que el pc reconozca el lcd.
Posted on Aug 21, 2009
    New Friend:
Hi I had the same problem with my Hitachi. Finally I found a solution that worked. I didn't have a remote. I held the channel up button on the TV itself. While holding the channel up I then held down the power button at the same time. Then the TV turned on. I hope that helps. :)
Posted on Aug 05, 2013
WHEN I PLUG IN MY OLEVIA 437-S11 TO ANTENNAE I GET NO SIGNAL WHEN I KNOW THAT I HAVE ANTENNAE SIGNAL? HOW TO FIX?
the input for the TV has to be set to antenna .usually in the main menu.and perhaps do a channel search .
Oct 04, 2015 | Olevia Televison & Video
Need olevia 437 S11 firmware
There is no firmware to this TV by internet. Contact the nearest authorized service center for help.
Aug 21, 2012 | Syntax Olevia 537H Television
Tv power light comes on when i turn on switch in back, but nothing happen when i press button in front Model # Olevia 237 -S11 37 in LCD TV
your on a safe mode energy saver they built then tvs like that for storm and lighting storms ok only push power button one then wait 15 min. then tv should come on.
Feb 14, 2011 | Olevia 237T 37 in. LCD TV
I have a olevia 37in model 437-s11.the power light is on but no pictures
I just bought one used and I plugged it in.. blue light on.. why iss it not working ? blue light off when tv on.. this work for this caveman.
Jan 23, 2011 | Olevia Televison & Video
Olevia 437-s11 is stuck in stand by mode, I tried the solution provided but I'm unable to find the firmware in the olevia page. do you have any idea where can I get it?
It's not a firmware update, you do have a problem with the main board giving the power supply an ON command. Please have it looked at by a qualified technician.
Nov 20, 2009 | Olevia LT37HVS 37 in. LCD HDTV
437-S11 Change Channel and Volume Mutes
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Jun 02, 2017 | Olevia LT37HVS 37 in. LCD HDTV
I have an Olevia tv model 437-S11 that won't power up.
Hi there
I solved my problem by downloading new software from I can't remember the website (it's been about 5 months) and loading it via USB cable. I can't believe it worked but it did. You should try Google search and look for troubleshooting tips for your tv. Include model and serial numbers. When you download new software make sure you have the correct software version and find and follow directions as to how to get it done. Let me know if it worked for yah...Good luck and a happy new year.
Dec 30, 2008 | Olevia LT23HVX 23 in. LCD Television
Olevia LT37HVS 37 in. LCD HDTV Logo
2,878 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
