Question about HP PhotoSmart 7350 InkJet Printer
Print cartridge cradle cannot move error 7350
I have unplugged, cleared jam, which there was none, several times, Rebooted, replugged, rotated wheels from behind...
SOURCE:
SOURCE: cartridge cradle is stuck
I have had this problem with my 7550 for a while now and I finally found this on the HP website and it seems to have fixed my problem, I also replaced all of the cartridges:
Issue While printing from an HP Photosmart printer, the printer screen displays Print cartridge cradle is stuck / clear jam and then press OK . The printer may also make grinding sounds. This can occur after a paper jam when another printer part blocks the cradle. Solution Follow these instructions to adjust the clutch on the printer.
  1. Disconnect the USB cable.
  2. Press the printer power button to turn off the printer.
  3. Disconnect the power cord from the back of the printer.
  4. Open the top cover of the printer.
  5. Remove the print cartridges from the printer.
  6. Slide the cradle to the right side of the printer.
  7. Locate the clutch on the left side of the printer.
    NOTE: The clutch is a flat, white, plastic component that rests just above the white roller gear wheel. In the HP Photosmart P1000 and P1100 printers, the clutch is black metal. Figure 1: Printer clutch c00020494.jpg
  8. Remove the rear access door from the back of the printer.
  9. Press the clutch firmly towards the back of the printer, while rolling the wheels in the back of the printer upward two full rotations.
  10. Release the clutch and roll the wheels up two more rotations.
  11. Reinstall the rear access door.
  12. Reinstall the print cartridges and secure the latches in place.
  13. Close the top cover and reconnect the power cord.
  14. Turn on the printer.
  15. Print a test page.
Posted on Dec 31, 2007
SOURCE: printer cartridge cradle is stuck-hp photosmart 7350
I just had the same problem...and this is what I did to get it working...
Turn off your printer. Open the top. Push the cartridge thingie off to the side (if possible) and then take QTips and cleaned the silver bar the cartridge moves on. Got a lot of ink off of it.
Should run after that.
Posted on Jul 12, 2008
SOURCE: print cartridge cradle stuck
Hi, I have a HP Photosmart 8050. Runs good till Now. 1, ONE Sheet of paper Jamed. THe RED Light Keeps Blinking Like crazzzy. I unhooked it to re-boot. It says Print Cartridge Cradle is stuck. Clear Jam & press OK. Iv'e [email protected]@KED 4 anything. Nothing in way. I took the ONE sheet out. Still Nothing. It's Like my X-wife. 1 item wrong and a Bunch of ****. New Ink. Got Milk. Oh wrong Commercial. Got Fix. Retired Handi-capped sanior, Ron
Posted on Dec 30, 2008
  • 3 Answers
SOURCE: Paper cartrige cradle is stuck.
print cartrige cradle is stuck clear jam then press ok in hpphotosmart 7550
Posted on Oct 09, 2009
MUKHTAR
  • 2022 Answers
SOURCE: print cartridge cradle is stuck.hoe can I clear
It is require servicing if you can open the cover and apply some lubricant oil on the steel rod it will fix the problem otherwise show it service center.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Posted on Feb 19, 2010
Cartridge cradle is stuck
Hi KHphoto, you can see this steps to fix your printer jam,
original post*
If you are still having problems let me know.
Jan 03, 2008 | HP PhotoSmart 7550 InkJet Printer
My printer keeps saying print cartridge cradle is stuck clear jam then press ok, but there is no paper jam
Because it's NOT a paper jam, but a cartridge cradle jam, I suppose it's an ink jet printer??? if so, check for debrie arround the cradle shaft that could prevent the printing cradle to move from left to wright... you could also lubricate the shaft by rubbing a little bit of grease on it with the tip of your finger (verry thin layer), as ink sometimes gets on it and tends to become sticky with time...
Aug 10, 2011 | HP Office Equipment & Supplies
HP PSC 1500 series print cartidge cradel cannot move?
Does is look/sound like the cradle is attempting to move? Make a loud popping sound? There is small belt that is used to guide cradle across the platen. Take a closer look to see if anything is obstructing that belt. It's rubber and looks like it has gear teeth on it and fits around white gear wheels on side of cradle.
If it doesnt' move at all, a hard reset might clear it. You'll have contact HP support for that as each printer model is different. Some you just hold the power button in for a certain number of seconds.
A soft reset can be tried by unplugging power cord from printer and waiting 15 seconds then reattach power.
Oct 05, 2009 | HP PSC 1510 All-In-One InkJet Printer
Sep 08, 2009 | HP Photosmart 8150 InkJet Printer
Will not print
Try moving the cartridges with the power cord unplugged. Your problem sounds fatal.
Jan 16, 2009 | HP DeskJet 6840 InkJet Printer
HP8250 printer
Try this: Remove both ink cartridges. Unplug the printer for a few minutes. Plug it back in and re-install the cartridges.
Jun 26, 2008 | Office Equipment & Supplies
Print cartridge cradle is stuck ican't find where it is jammed
This might help . . . Mine finished printing one doc & then made a terrible noise & sent a message to my screen that "print cartridge cradle is stuck." When i opened door, i could see it was stuck off to the left side so left cartridge was obscured. I could not get it to budge, although i kept turning it off, gently pushing & turning it back on. Finally, i got my hand inside & determined that the little door to the left-side cartridge had popped open & was causing it to remain stuck. After some struggles (turn off printer first!) i was able to maneuver it around & close it tight. Now, all is well . . .
Apr 16, 2008 | HP Office Equipment & Supplies
Printer cartridge cradle is stuck-hp photosmart 7350
Dec 01, 2007 | HP PhotoSmart 7350 InkJet Printer
Nov 27, 2007 | HP PhotoSmart 7550 InkJet Printer
HP PhotoSmart 7350 InkJet Printer Logo
71 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
