Question about Sony FD Trinitron WEGA KV-20FS120 20" TV
I have trinitron Sony Television.. i got some problem with my TV, the Vertical screen size gone out of focus... I want to know about remote control Commander Codes from which i can resolve my problem and get reset my TV screen focus.. Thank you.
    President:
  • 3,130 Answers
I think what your asking is for an on screen service menu?? That wont fix your problem. It sounds like you have a vertical height problem where the screen doesnt fill the entire screen with the Picture. The adjustments wont go out like that for no reason and all by them selfs. The vertical sweep IC went bad and is going to have to be replaced. This is not a job for the end user. You should call an experienced tech to assist you with this repair. Good Luck
Posted on Aug 12, 2006
What is the code for a 2001 Sony Trinitron?
Search Results
    Sony eSupport - Remote Control Codes & Programming ...
    https://esupport.sony.com/.../select-system.pl?...RCOD...
    Sony CorporationFind the codes you need to program your remote control. ... Television - Accessories; Television - FD Trinitron® & WEGA™; Television - Internet TV & Players ...
    [PDF]Trinitron Color TV - Manuals, Specs & Warranty - Sony
    https://docs.sony.com/release/KV20FV12.PDF Sony CorporationRefer to section 54-300 of Canadian Electrical Code for Antenna Grounding. Lightning .... Congratulations on your purchase of the Sony Trinitron Color TV.
Dec 08, 2015 | Sony Televison & Video
Red light flashing 4 times
sounds like it's toast http://community.sony.com/t5/Television-Picture-Sound/Vertical-Lines-of-death-KDL-52W4100/td-p/29582
Mar 26, 2014 | Sony KD-27FS170 27-Inch FD Trinitron WEGA...
My 12 year old Sony Trinitron KV-32XBR200 still works pretty well except that it cuts off about 25 - 30 scan lines at the bottom of the screen when cold, then gradually improves somewhat to missing only 15...
No,tv have cold solders inside the tv like vertical IC or around the area.Have a soldering iron,a roll of solders,also know how to do basic soldering?Yes.Take the tv aparts,take a back plastic of the screw driver tabs all around the main pcb,will see the vertical changes,take out the a/c power sourced,resolders those area,will fix this problems.
Feb 10, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Trinitron Colour TV Stopped showing and switch light flicker
The vertical output IC has failed/Power to the vertical IC is out/ or there is bad solder on the pins of the vertical output IC.
Dec 01, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Stuck in standby
The 4 blinks indicate a vertical deflection problem. Either the connections on the legs of the vertical IC are bad or the IC is defective. If you can solder, you can fix this yourself. Let me know if you wish to attempt the repair and I'll provide more details and instructions.
Dan
Oct 02, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony triinitron tv out of focus
You have an option of Sharpness in TV Menu > Picture Control / Setting area.
Aug 16, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Half a screen
problems on the vertical section I can do it for $ 180
we need to replace the vertical integrated circuit and poblably some caps
Jul 31, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Picture broken and shrinking
You need to change your vertical IC, along with some capacitors around the vertical IC. Capacitor with value 220UF, 10uf, 470uf and finally 1000uf. Doing this will fix the set. Total cost under $40
Best regards
Circuitcity
Nov 29, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony FD Trinitron WEGA KV-20FS120 20" TV Logo
170 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
