Question about JVC THS55 System
JVC TH-S55 - CONNECTOR
CONNECTOR FROM DVD TO YHE POWEED SUBWOOFER
Nightdiver
  • 116 Answers
SOURCE: Subwoofer JVC TH-M606
What system are you using it with, how do you have it connected, when you say the system does not work as a result, does it mean that the system does not power up, or no sound?
Posted on May 19, 2006
s4u311
  • 813 Answers
SOURCE: JVC TH-A9
1st u need to covert stereo cable with stereo conversion pin which avelieible in electronic consumer store after u got this cable u able to connect ur speakers directly to play station or a tv
Posted on Feb 19, 2008
SOURCE: JVC TH M505 Subwoofer not working
i need to find the wire that connects from the subwoofer it has like little spikes inside the medal part and the spikes broke off
Posted on Apr 10, 2008
SOURCE: jvc th-c6 subwoofer won't turn on
Check the little prongs inside of the cord, they are very fragile and if they get pushed in wrong, bent and broken off - you would never see one on the floor. These should all be straight and be able to make contact. Hope this helps!
Posted on Mar 16, 2009
SOURCE: Tray locked
Dear friends,
I have solve the problem.power off the player and press and hold STOP+OPEN,CLOSE button.and than power on the player than display shows unlocked.the problem solved.and enjoy
Posted on Mar 25, 2009
Where do i find a connector cord for my powered subwoofer model no. sp-pwm606
There are a few on eBay. Search for "JVC THM505 cable" and check the 'include description box'.
If you need the manual...
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/JVC-TH-M505J-Home-Theater-Systems-manual/id/318dj491/t/2/
Mar 16, 2011 | JVC SP-PW100 Subwoofer
Pplug it in and it lights up for a few seconds then dies. sound like capacitor charging up
a very common problem with this unit is the connector on the subwoofer that accepts the round plug joining it to the dvd player is worn...if its bad the sub will pop when its jiggled
Aug 30, 2010 | JVC TH-C60 System
Digital Optical port to 8-pin din
Optical digital cables can't be magically wired to copper inputs. NO digital signal can be magically connected to an analog interface and work.
Even if you could do what you propose, how would you control volume?
Why don't you just connect the BluRay to the JVC system and let IT handle the audio to the sub and satellites?
Run an optical cable to the JVC TH-C60's Optical In port. Make sure there are no tight bends in the optical cable as that will degrade its ability to transmit a signal.
Jan 30, 2010 | Audio Players & Recorders
JVC Home Theater System M505 The subwoofer will not come on and it appears that the system (speakers) will not work at all until it runs thru the subwoofer system.
Wiggle on the long round cable connected to the Sub woofer. If the SW turns on, open it and solder the connector or change the connector
Jan 18, 2010 | JVC TH-M505 System
Tray locked
Dear friends,
Dec 30, 2008 | JVC THS55 System
Locked jvc dvd cinema system th-s55
With the machine turned off (not off at the mains mind you) press and hold the stop button and then while still holding the stop button, press the eject button. Turn it back on and hey presto! This method will unlock it when its locked and vice versa. p.s its in the manual
Nov 05, 2008 | JVC DR-M1 DVD Recorder
JVC TH-A9
Feb 19, 2008 | JVC TH-A9 System
Jvc th-c5 dvd theater system
Probably have a bad center unit to subwoofer cable. Sometimes the pins inside the cable bend or break. I paid 33.00 for a new one on the JVC website.
Dec 25, 2007 | JVC TH-C5 System
Subwoofer shuts down
Check the connection in the back of the sub,where your wire plugs in from the DVD unit, the connector is loose in the unit itself. Had mine replaced and is doing the same thing again
Nov 24, 2007 | JVC TH-M505 System
JVC THS55 System Logo
65 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Henry  Thomas
Henry Thomas
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
