Question about Gateway M465-E Notebook
Freeze at startup
My gateway m465e freezes at start up screen. I have replaced the Heat Sinc, RAM, CPU, and CMOS battery. Any suggestions? Thanks.
  • 400 Answers
Hello
If you have an Nvidia or ATI graphics card then they are probably the problem and can only be replaced by replacing the motherboard.
Apart from that this seems to be a motherboard problem ,have you tried with only the battery and vice verca.
Good luck
Posted on Feb 13, 2012
Testimonial: "Yes, I have tried with only the battery. All the components I have replaced are good (from another machine). So replacing the mother board sounds like the only option here? Thanks for the solution."
Gateway m465e laptop will not turn on
When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Mar 13, 2013 | Gateway M465-E Notebook
Long continuous beep and freeze at "continue normally" screen
laptop or desktop
make sure that your RAM modules and Cmos battery sockets are clean and dust free and the ram modules are securely seated in some motherboards cmos batteries are soldered in
Test all leads that attach to your hard drive including electrical extensions
the leads from your ((motherboard to your hard drive)) SATA make sure they have secure dust free connections
and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty
make sure all devices and fans are working
hope it helps
Jun 14, 2012 | Gigabyte GA-P35-DS3L Motherboard
Why is my screen forever freezing up on me
That can result from a virus attack. The viruses are capable of filling up your memory and makes computer operations very slow and eventually freeze. Or it can be a result of a failing hard drive. I suggest that you install an antivirus software, update it and run a full system scan. Restart your computer
Dec 23, 2011 | Gateway Computers & Internet
My Gateway GT5404 Freezes
1. your hard drive may be at what is called the "end - of - life"
2. I suggest that you try to backup important files if you can get into the pc screen again.
3. PC freezing is sometimes due to a failing power supply, a failing hard drive, and or a depleted CMOS battery.
May 15, 2010 | Gateway GT5404 PC Desktop
Error 0X0000007A (0XC07C1AB0, 0XC000000E, 0XF8356642, 0X0A1F0860) When i switch on my PC i get this blue screen error report. i don't know what this error is. please give me the recovery suggestion. Thanks...
How To Fix This Error
Error Message:
Stop Error 0x0000007A (Kernel data inpage error) Translation:
This occurs due to a memory error from a faulty hardware device or virus. Solution:
If your system freezes during Operating System installation, make a note where the installation stopped. Often, you can narrow down your problem by knowing when the freeze occurs.
Frequently, installation freezes are caused by incorrect settings in the CMOS (complimentary metal-oxide semiconductor). The CMOS stores special configuration settings for your computer’s hardware and is used by the BIOS (Basic Input/Output System) when your machine boots. Your motherboard or system should have come with a manual that describes the CMOS settings. If you don’t have a manual, download one from your manufacturer’s Web page. To change the CMOS settings, press the keys as shown in your manual or on your PC’s startup screen (often DELETE, ESC, CTRL-ESC, or CTRL-ALT-ESC) immediately after you boot your computer. If you change any of the CMOS settings, write down your changes and keep them in a safe place. Then you can refer to the settings if you need to change them back or redo them if you reinstall or upgrade to a new version of Windows later on.
Incorrect CMOS settings for system cache memory and RAM may confuse the Windows installer and freeze the system. If your system freezes during setup, try disabling the system cache memory. If you are able to install the system after your CMOS changes, then you fixed the problem. If this doesn’t work, then try adding a wait state to (or slowing down the timing on) your RAM. (Wait states are periods where the CPU pauses while waiting for data from slower components.) Adding a wait state causes the computer to address the memory less quickly and often fixes unexpected freezing problems, black screens, or unprovoked reboots. After Windows is fully installed, use the new system for a while to make sure it is stable. Then, restart the system and change the CMOS settings back. If the system remains stable, keep the settings; otherwise return to the stable settings permanently.
Bad RAM chips or a boot sector virus can cause inexplicable freezes during installation. If you suspect your memory might be the trouble and you have extra RAM chips around, try the installation with the other chips instead. If you think you have a boot sector virus on your hard drive, then use a bootable CD-ROM or diskette to check and clean your hard drive using programs such as Norton AntiVirus (http://www.symantec.com) or McAfee VirusScan (http://www.mcafee.com).
Feb 11, 2010 | Toshiba Sattelite A105-S2051 Notebook
Gateway GT5228 Will NOT Startup
TAKE OUT YOUR MEMORY CHIPS,AND INSERT 1 AT A TIME AND TRY.
IT COULD BE YOUR RAM THAT IS FAULTY THATS WHY ITS DOING THIS
Jul 04, 2009 | Gateway GT5228 (7156) PC Desktop
MSI MS-7142 motherboard problem
try cleaning CMOS with cmos jumpers or just remove your battery of motherboard for 10 seconds (previously unplug power from PC.)
Jan 31, 2008 | MSI K8MM-V Motherboard
Home pc
hello,
try this,
click on start then run, type msconfig in command box,
system configuration window should show up. click on tab called startup. click disable all, then apply, then click ok, it should ask if u want to restart. please restart the computer.
what will it do? it will disable all startup applications.
if this resolves the issue, then you would know its one of the startup application causing your computer to freeze it.
also right click on bottom bar, then click task manager.
click on tab called processor.
average processor is 25-30.
in my laptop i have only 19 processor runnning.
if you have alot of processor running that definitly cause PC to slow/freeze.
hope this information help you
Dec 22, 2007 | Gateway 510H Pentium 2.4 GHz, 256MB RAM,...
Gateway M465-E Notebook Logo
154 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
