Question about Breadman TR2200C Ultimate Bread Maker
Help!!! Black dirt on paddle and metal insert on bottom of pan.
After every time i use the breadman, i get this black dirty film-like substance on the paddle and the metal spoke sticking out from the bottom of the pan and i have to literally scrub it off for hours on end. does anyone know where i can get a new pan from? i've called customer service and they can't help me, saying they don't make this model anymore. please help, as i make bread to help support the family. thanks!
  • tavena Nov 12, 2008
    Stuff inside the bread pan paddle seal has gone bad. Probably from getting water in there. You can take it apart and try to clean up inside the seal but it will never be like new.
    Take off retaining clip from the underside then the whole seal can be worked out from the inside of the pan. It is like a big rubber plug. It will rip easily though.
    I can't find a replacement pan for sale anywhere.
SOURCE: removing finished bread from pan
Before the baking cycle begins,remove the bread pan ,shake out the batter onto a piece of waxed paper,remove the paddle from the bread pan,place batter back into the pan,close lid.This way you only have a small hole in the finished loaf. I prefer the 1.5 pound rye bread,and set a kitchen timer for 2 hours 5 minutes-when the "shape" cycle finishes,we remove the paddle.
This is listed in my manual on page 76,item # 7;heading is METHOD.
Front of the manual lists the times for the cycles,just add them up.
(When you dump the batter back into the pan,try to pat down the rough edges,it looks better).
Posted on Oct 01, 2008
SOURCE: TR875 paddle for breadman
I lost the kneading paddle - called the customer service number and they told there are none available and they are no longer making them.  Guess I just throw the whole unit in the garbage since it is worthless without a kneading paddle!!
Posted on Oct 06, 2008
  • 204 Answers
SOURCE: Breadman replacement paddle no longer available.
I had great success in finding what I wanted for my breadmaker at http://breadmakerpartsemporium.ioffer.com/. They have manuals and parts for most breadmakers at very reasonable prices.
Posted on Jan 06, 2009
  • 204 Answers
SOURCE: worn out bread pan
  • 204 Answers
SOURCE: bread paddle for Breadman tr800
try http://breadmakerpartsemporium.ioffer.com/. They have manuals and parts for most breadmakers at very reasonable prices.
Posted on Jan 13, 2009
There is a thick sticky black substance leaking from my refrigerator for the past two weeks on the left front side. Frigidaire model p/n 241543966
Hello Melanie;
My name is Peter. I am a retired field service technician.
You do not have a refrigerant leak. Refrigerant is clear in color.
You have a water leak. The black sticky substance is either coming from your bottom condenser cooling coil or just general dirt under your refrigerator that accumulates over time. The coil under your refrigerator collects dirt as well.
You need to pull the refrigerator out so you can get behind it.
Unscrew the bottom back cover. Inspect for the water leak source. Your condensate drain pan may be leaking or dislodged.
The water line to your ice maker may be leaking.
Your water supply shut off valve to your refrigerator may be leaking.
Nov 01, 2014 | Refrigerators
Paddle axle fell out the bottom on the pan while washing.
I looked through the manual for this unit and you need a more comprehensive parts drawing showing the drive details. They do not have this kind of detail on line, my advice is to contact them directly by phone.
http://cart.russellhobbs.com/consumer-services/warranty.aspx?sid=BreadmanUS
Nov 10, 2013 | Breadman TR2200C Ultimate Bread Maker
The paddle keeps coming off during mixing and leaving a black stain in the dough
Hi, The sealed bearing located on the bottom of the bread pan has failed. This bearing is sealed with lubricant to allow the paddle shaft to spin easily. The black stain you see is the lubricating grease. You need a new bread pan. Hank
Jan 22, 2011 | Breadman TR2500BC Bread Maker
Does the breadman tr845 use a belt to turn the dough mechanism? if so where can i buy one?
Yes, the Breadman TR845 uses a belt to connect the knead paddle to the motor. I had a problem with my Breadman so I took it apart. It turned out for me that the belt was fine but it had slipped off the plastic gear. The belt was still around the shaft of the motor so it could only turn if the bread pan was empty. The belt is a timing belt with integral teeth. I needed a small space washer that would keep the black plastic gear from slipping on the shaft and allowing the belt to slip off the gear. There is a lip only on one side of the plastic gear so if it moves the belt can slip off. I created a spacer washer from the cap on a tube of toothpaste. I cut the cap in half and had to use a metal file to get it the right size. I needed it to be 1/4 tall and 3/4 inch in diameter. I cut the spacer so that I could slip it over the shaft of the motor. The spacer keeps the black plastic gear from sliding and it keeps the belt from slipping off the gear. After putting it all back together everything works fine. And the toothpaste tube was almost empty anyway.
P.S. There are losts of screws that hold it together and the belt and gears are at the bottom of the Breadman and you have to take the whole thing apart to get to the bottom. I was able to leave all the wires attached so that putting it back together went quickly compared to the work of taking it apart.
Jan 17, 2010 | Breadman TR845 Bread Maker
My Breadman bread maker is broken. The pan jumps
It is likely that, due to a poor design the contact between the paddle traction and the machine is worn out.. Check it and you will see that the bare metal is shiny there in the two bumps in the rotating plate in the machine.
I used a dremel-like rotary tool to grind the contacting part so that the contact between the machine and the paddle traction is orthogonal.
Worked fine for me.
Regards
Nov 16, 2009 | Breadman TR2200C Ultimate Bread Maker
My Regal breadmaker has begun to release a black greasy substance into my bread dough. Do I need to replace the pan?
The black substance is lubrication oil. The oil lubricates the bearing and shaft that the paddle spins on. Usually this bearing is sealed, but black greasy substance means that the seal is broken and is leaking. Just a matter of time until it fails all together. Time to replace.
Hank
Nov 05, 2009 | Regal Ware K6725 Kitchen Pro Bread Maker
I have a Breadman Model: TR845. It seems that the gear in the actual machine that turns the knead paddle is striped. It turns when the pan is empty ... so I know it is working, however with dough inside or...
I had the same problem with my Breadman TR845 that I bought used at Goodwill. I made my first loaf O.K. then could not get the knead paddle to turn except when the pan was empty. I took it apart and discovered that the timing belt (flat belt with integral teeth) had slipped off the black plastic gear attached to the shaft of the motor. The belt was still around the shaft of the motor which allowed it to move the paddle only when empty. I needed a small spacer washer that would keep the black plastic gear from sliding on the shaft and allowing the belt to slip off. There is a lip only on one side of the plastic gear so it if moves the belt can slip off. I created a spacing washer from the cap on a tube of toothpaste. I cut the cap in half and had to use a metal file to get it the right size. I needed to be 1/4 inch tall and 3/4 inch in diameter. I cut the spacer so that I could slip it over the shaft. After putting it all back together everything works fine. And the toothpaste tube was almost empty anyway.
P.S. There are lots of screws that hold it together and the belt and gears are at the bottom of the Breadman and you have to take the whole thing apart to get to the bottom. I was able to leave all the wires attached so that putting it back together went quickly compared to the work of taking it apart.
Steve S.
Apr 27, 2009 | Breadman TR845 Bread Maker
Removing finished bread from pan
Nov 04, 2007 | Breadman TR2500BC Bread Maker
My bread maker doesn't knead correctly (It is an Breadman TR845). If I added water, It can turn very slowly. However when I add the other ingredients. The KNEADING PADDLE stopped tunning. I only hear...
Sounds strange. Usually the paddle has a key (the shape of it is irregular and it fits into the sleeve on the spindle or shaft) Either the shape has worn and it no longer fits or the spindle or shaft is not turning with the motor which could mean that the connection with the armature of the motor is damaged.
You could contact the manufacturers or ask afriend to examine it for you which would need taking it apart.
Alleluia
PTL
Oct 17, 2007 | Breadman TR845 Bread Maker
Breadman TR2200C Ultimate Bread Maker Logo
54 people viewed this question
Top Breadman Kitchen Appliances - Others Experts
Dave Kristol
Level 1 Expert
Irene Tulloch
Are you a Breadman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
