Question about GE WVSR1060A Top Load Washer
The machine won't wash or spin... Motor pulley?
Two months ago I put a new belt on this machine and tightened it. The belt is still tight but it seems a little worn. When the machine enters the washing or spin cycle the motor starts. I can see the motor axis moving, but the pulley will not move. It is just the axis spinning inside it like crazy. If I move the big pulley under the drum manually both pulleys spin. I feel some resistance, but it is not hard to overcome. I dismounted the motor's pulley and found some sort of braking system inside. It looks worn (the machine has 8.5 years of use). I'd like to know what is the source of my problem and what may have originated it. As for the brake thingie: What is its name and function?
Take a look at the transmission if it has a whie tag or label bad transmision
Posted on Jun 11, 2008
Crunching sound at the commencement of spin cycle
hi
The drive belt (or belts) of a washing machine may become worn or damaged, causing noisy operation or stopping the washer entirely. A damaged drive belt is easy to replace. Remove the back panel of the washer to gain access to the belt. To remove the belt:
Step 1: Loosen the bolt on the motor bracket and move the motor to put slack in the belt.
Step 2: Remove the old belt and stretch a new one into place on the pulleys.
Step 3: To put tension on the new belt, use a hammer handle or a short pry bar to push the motor into position while you tighten the bolt in the adjustable bracket. The belt should have about 1/2 inch deflection when you press on it at the center point, midway between the pulleys. If the belt is too loose, it will slip on the pulleys, causing the machine to malfunction. If the belt is too tight, it will wear very quickly and will probably become so hot that it will start to smoke or smell.
Loose pulleys can also cause problems. Most pulleys are fastened to shafts with setscrews around the hub of the pulley. These screws must be tight or else the pulley or belt will slip. The resulting malfunction may seem to be caused by a faulty motor, but it can be corrected by tightening the pulleys and adjusting the belt. For this reason, always check the belts and pulleys before working on the motor.
Nov 28, 2008 | Bosch Washing Machines
Making scraping sound when spinning
hi The drive belt (or belts) of a washing machine may become worn or damaged, causing noisy operation or stopping the washer entirely. A damaged drive belt is easy to replace. Remove the back panel of the washer to gain access to the belt. To remove the belt:
Nov 06, 2008 | Zanussi Washing Machines
Both mounting studs for the auto washer motor show signs of excessive wear and will not hold tension on the drive belt pulley. Will you tell me the nearest center to fayetteville NC where they will...
HI DONT WORRY READ THIS
Oct 16, 2008 | Maytag Washing Machines
Samsung fully automatic washing machine
HI The drive belt (or belts) of a washing machine may become worn or damaged, causing noisy operation or stopping the washer entirely. A damaged drive belt is easy to replace. Remove the back panel of the washer to gain access to the belt. To remove the belt:
Oct 14, 2008 | Washing Machines
My LG washing machine
Oct 13, 2008 | LG WM-2077C Front Load Washer
Hoover 200 m unbalanced and noisy on spin cycle can't balance it
Sep 13, 2008 | Washing Machines
Hi,Ihave a hoover hnf 7167 washing machine that my 2 year old turned off then on again while on a 1600 spin(the washing machine,not the 2 year old!!).This caused a loud'pop'and everything went blank.The 13...
thank u................
Sep 12, 2008 | Hoover Washing Machines
MAYTAG WASHER DOES NOT SPIN AND DOES NOT DRAIN
Something may be stuck in the belt or inside of the machine.
The following may help.
Feb 14, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Hotpoint washing machine belt come off
u need to take the lid off and keep the small panel off now 2 ways u can do it 1)undue the botls on the motor just enough so u can move the motor now put the belt around the pulley wheel by placing your hand through the small panel once done put the belt around the motor wheel now last thing pull motor so it tightens the belt and tighten the bolts on the motor 2)place the belt around the wheel on the motor now with your other hand put the belt on 1 side of the big pulley wheel and hold it in place as u turn the pulley wheel it will slide on but with tension once on spin the pulley wheel and it will line up the belt
Dec 29, 2007 | Hotpoint First Edition FEW12 Front Load...
GE WVSR1060A Top Load Washer Logo
78 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
jimorris77
Sal De
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
