Question about Philips 42FD9954 42 in. Plasma HDTV
Magnavox phiips 42MF23
Is this a Samsung: S42AX-YD01 PDP utilized in both above Models Magnavox 42MF23 & also 42FD9954 by philips?
Appreciate knowing for parts that are required.
Kind regards
William
techman
  • 3130 Answers
SOURCE: need to find manual for remot
I tryed to look this up for you and I did find the remote on the web site but when I tryed to view the documentation on the remote a note came up and said that there was no on-line documetation for this remote, but I could contact Phililps for it at: 1-888-PHILIPS (1-888-744-5477) Good Luck
Posted on Apr 27, 2007
ctf1800
  • 4402 Answers
SOURCE: 60" Philips Magnavox Projection TV Red Screen
You can also check to see if you have bad fluid problems, by looking down in your crt's with a flashlight when you unplug your set and see if you can notice any particles that should not be there. Look at all three and see if there is a difference. It should be clear, if not then you need to change fluid and clean.
It sounds as if one of the picture elements (there are probably 3 for R-red G-green B-blue) has gone bad and it is most likely the green one. Sad to say it will probably cost you more to have it fixed than it would to buy a new TV. Most places will not even look at a TV for less than $85 or so, then they will add parts and labor... if they can even find parts.
Posted on Dec 17, 2007
I bought a crappy old magnavox and rebuilt it. I had both of these issues.
Since your tv is old, the blur problem is probably caused by old coolant in one or more of the CRT lens couplers. Hopefully, the lenses are simply out of alignment, but no one has ever worked on the tv, then this is unlikely.
First, unscrew the back panel of the tv console (should be a bunch of 1/4" hex head screws). There will then be a large white panel at a 45 degree angle held in place by two tabs or maybe even screws. Remove it to see the CRTs. A quick check for the blurry problem is to look directly into the CRTs while the tv is off. DO NOT do it while they are on if you can help it, as it is not good for your eyes.
Shine a white LED flashlight down into each of the CRT's top lenses. Avoid classic incandescent light in this case, since you will be looking for the difference between white and yellow. I you see a white plate inside, good. If the inside looks yellow, and has floating things in it, then the coolant fluid inside is old and bad. You can replace this, but it is a VERY delicate task and MUST be done in certain steps to avoid ruining the electronic boards anywhere within splash zone or drip reach of the lens couplers. The coolant is a special blend available at most tv repair shops, but it's basically clear antifreeze (which you wont likely find in an automotive store).
For the color being off, it is most likely the gain on each CRT being out of whack. First, change all of the user settings (in the on screen menu) for image, color, sharpness, etc to the middle or default.
With the back panel off, somewhere near the bottom of the inside there will be a small black plastic box with wires coming out the sides. This box should have 6 knobs on the front of it (the face facing the rear of the tv); 2 rows of red, green, and blue knobs. These are the screen controls for FOCUS and GAIN. And they should already have some sort of label telling you so.
I placed a mirror in front of my tv so I could see the screen as I adjusted, but you might be able to see it somewhat by hanging a sheet over the front of the screen and looking at it from the inside.
There's a much more in depth method to do this that is described in the service manual (which you are likely to have seen by now; they are usually either stapled to the back of the tv or hanging somewhere inside and easy to see)
But basically, just turn the knobs gently around until the picture looks about right to you. (Remember, if you turn them all up super bright, the CRT will not last very long. Try to keep the knobs near the middle of their turn ability)
If you want to do a full out overhaul of the screen, you'll have to make a lot of adjustments with a bunch of little knobs (variable resistors, really) on the computer board inside. The service manual will tell you what each one corresponds to, but most of them will have a subtle label on the board.
Email me if you need any help
Posted on Mar 23, 2008
pizzaguy3274
  • 4 Answers
SOURCE: 42fd9954
Not a fix, but it got my tv on.
I removed the back and tried the power switch.
I located the relay that was clicking.
I have two blue relays in the middle of my power board.
I placed a hair dryer over the relay for a few minutes.
After four tries of the power switch and it stays on!!!!!
Heat keeps the relay from just clicking off.
I don't know why.
This will at least get the tv on though.
Posted on Apr 12, 2008
SOURCE: Philips magnavox won't turn off and stay in demontration mode
Hold both volume buttons at the same time for 6-10 seconds and that will reverse it. This has been proven to work!!!! YEAH
Posted on Jun 22, 2008
Magnavox 19 in lcd manual guide
Here is the link to the manual of Magnavox 19MD359B (19 inch LCD TV)
Magnavox 19MD359B
If that is not the model of your TV (there are many models of 19" magnavox TV) please indicate it so I can look it up for you.
You can rate my answer if you appreciate my work for looking for the manual of your TV.
Thanks.
-damneddle
Oct 06, 2011 | Magnavox 19MD359B F7 19 in. HDTV
Need to find out a part # for my philips 52PFL7403/f7 for the ir sensor
Join Date: Nov 2011 I have a Philips 47PFL3603D/F7 with the same problem. It was the IR sensor board causing the problem. You can search online to find the board, which almost everyone will most likely not have in stock, and cant be ordered. The part you need is this: 313926859181 IR Remote Sensor.
Models it will fit are as follows: Substitute Parts 313926859182
Known Models
MAGNAVOX 42MF438B/27
MAGNAVOX 42MF438B/F7
MAGNAVOX 52MF438B/27
MAGNAVOX 52MF438B/F7
PHILIPS 32PFL3403D/85
PHILIPS 42PFL3403D/27
PHILIPS 42PFL3403D/F7
PHILIPS 42PFL3603D/27
PHILIPS 42PFL3603D/F7
PHILIPS 47PFL3603D/27
PHILIPS 47PFL3603D/F7
PHILIPS 52PFL3603D/27
PHILIPS 52PFL3603D/F7
If you can find the board, great! A replacement board costs about $12.00. If you can't... we'll there is something you can try ; )
Either way, if you know it's the board, what's the harm in trying?
Remove the back from the TV. You can actually leave it on your stand to do this if you can spin it around to gain access to the back of it. Be sure to unplug everything first!!!
Looking at the back of the tv, the board will be located in the lower left side by the speaker. It will have 2 cables attached to it. Remove them, and take out the screw or two that holds it in place. There will be a plastic tab that keeps it in place also.
Take your fingernail and bend the tab back, and the board should come free. After that you should be holding the board in your hands. The side of the board with the connectors on it is the side you want to manipulate. There will be a tiny surface mounted capacitor beside one of the wire connection sockets. Take a utility knife and scrape it off/ you could use a soldering iron but it should come off very easy with a knife.
Plug it back in, and give it a try! If it works... great! If not, find a replacement board, and try that.
May 30, 2011 | Philips 52PFL7403D 52 in. LCD HDTV
Vscan for philips 42 in plasma
i would recommend replacing y main and y upper and lower buffer boards based off your troubleshooting as they complete circuit. these samsung boards have an lj92 number on them that will cross to part number. if you find an lj41 number that number is vendor number for circuit board prior to components being placed on board. hope this helps. dan
Aug 18, 2008 | Televison & Video
Cl034 magnavox remote versus samsung directv reciever
Go to http://www.urc.philips.com/. The Magnavox CL034 is under another name, US2-PM435, the Phillips version. Drop down menu to left of screen.Pick United States URC models. Then pick My remote is...US2-PM435. These codes really work and being the official samsung site they have many more than one recieves with the remote at time of purchase. Also note that the CL034 is the Magnavox remote (it does not have Phillips insignia)
Jul 25, 2008 | Philips Magnavox Learning Universal Remote
Half the screen has gone black
Ok first lets start with the half screen and no lit screen . Samsung plasma panels (S42AX-YD01) HD V4. are really bad about the Y-board (upper,lower) buffers are really bad about getting hot and burining up. If u remove the back cover of TV u will see on the left side the Y-board (it will be marked in small letters) if u look and the rows of IC's with heatsinks on the buffers will be a dark yellow. Majority of the time if u remove the buffers. and look underneath them u will see the solder has melted from the board. U can replace the Y-board and buffers and the TV will work fine.
Next part if u have vertical lines in the panel. There is not much u can do as a repair. Only thing u can do is get panel replaced. because there is and IC that is burned up on the panel, and trust me there isn't anything u can do to fix it. If u want to see for yourself. After removing the back cover, remove SSB, and brackets holding PDP in place. at the bottom of TV there is a row of buffers marked E,F,G, ( i think) there is a long heat sink covering the IC's at the bottom connected to the bottom of PDP. As u can see without a $70k machine to change this there is not much u can do with it. Hope this helps.
Dec 22, 2007 | Philips 42PF7320A 42 in. Plasma HDTV
Philips 42FD9954 42 in. Plasma HDTV Logo
197 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
