Question about Sharp AR-5316 Advanced Digital Imager Copier
RE:INQUIRY Hello,greetings to you all,how do i go to service mode for sharp AR-5316 Copier to set the developer,and useage parameters,pliz help me,Thanks and i really appreciate your unceasing support to us,God bless Danniel from Uganda, NB;My email address is
  • Tim Babcock
    Tim Babcock May 11, 2010
    Can you explain which parameters you want to reset?
    There isn't a factory default parameter on that copier for good reason.
    An expert who has written 3 tips or uploaded 2 video tips.
  • 115 Answers
The North american machines use simulation 25-2 to set the deverloper.
Posted on Oct 27, 2008
  • Mike S
    Mike S Oct 27, 2008
    useage parameters?
    are you asking about account control?
How to clear u2-40 error for sharp ar m276
This is error for Error in MCU-CRUM chip communication. Probably because of developer unit has bad contact.
Try to reconnect developing unit and then turn on the copier. If problem persist call service!
Hope that helps!
Sep 06, 2011 | Sharp AR-5316 Advanced Digital Imager...
Ar-5316 showing error ch
CH steady means cover is open. Close either front or right cover well.
CH blinking means developer unit or toner cartridge not installed. Remove and return well and firmly.
Nov 22, 2009 | Sharp AR-5316 Advanced Digital Imager...
Installer of sharp AR-5316
Remove the screws marked and all tapes around the copier, open the tray and remove the screw supporting it. Open the front cover and unscrew the green screw holding developer unit and pullout the unit. Open the 3 screws and pour the developer evenly and return it back. Remove the seals on the toner cartridge and insert it. Power on the copier and make a copy.
Nov 17, 2009 | Sharp AR-5316 Advanced Digital Imager...
How to put developer(black) into copier how to enter thes functions please... i must enter in expert mode before entering codes...
Hello sir; This model copier, the developer come with toner cartridge, you don't have developer replacement problem.
May 26, 2009 | Sharp AR-5316 Advanced Digital Imager...
To reset maintenance codes requires going into service mode. This should only be done by an authorized trained technician as changing or adjusting something in this mode could create all sorts of problems you dont want to deal with.
Mar 17, 2009 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5316 will not print
check the toner. it still have a tape covering the opening . look for a yelow or red tab at the either side of the cartidge.
good luck
if this answer your problem, please rate it
Oct 16, 2008 | Sharp AR-5316 Advanced Digital Imager...
Developer sign
The developer doesn't need to be reset on AR series machines. Toner and developer are in one cartridge. There is a drum reset. That is service code 24-07.
Did you replace the drum as well?
Aug 11, 2008 | Sharp AR-5316 Advanced Digital Imager...
Add developer in sharp AR-5316
That model uses a TD cartridge so when you replace the toner the developer is included. The crum chip on the TD cartridge will reset the counters and sets the developer.
Dec 30, 2007 | Sharp AR-5316 Advanced Digital Imager...
Error code
Hi Sorry cant send manual U have to buy like every one else.But here are the codes you require It is service code 24 sub code 04 to reset PM counter and sub code 07 to rest drum sub code 09 to reset print count and sub code 11 to reset developer. Hope this helps
Aug 18, 2007 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5316 Advanced Digital Imager Copier Logo
88 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
