Question about Lands Phones
Panasonic kx-tg6700 2 line phone, how do i turn the ringer off of the main base thingy
SOURCE: phone ringer
You can download the manual for a very similar phone, the KX-TG2302 at http://service.us.panasonic.com/OperMan/findmanual.aspx?cat=TEL and you can figure out all the features of a KX-TG2303. The simple answer is: while you are not using the phone, press the up or down volume button and it should turn the ringer back on. To turn the ringer back off, press and hold the down volume button until you hear two beeps. You can adjust the volume while the phone is ringing. The manual will tell you how to change your ringer tones, etc.
Posted on May 22, 2007
SOURCE: ringer
1. Press Menu button
2. Press multibutton "down" repeatedly to display "settings BS", then press multibutton "right" {>}
3. Press {2} two times
4. Select the desired setting by pressing {1} for low, {2} for medium, {3} for high or {0} for off.
5. Press multibutton {>}, then press on/off button
Thats it....
Have fun
Posted on Jun 24, 2008
SOURCE: My Panasonic kx tg-2620 shows "ringer off". How do I turn it on?
To solve it, I pressed Menu then the silver down arrow to access the Ringer Settings. For some reason, I was trying to use the black buttons beside the Menu button to navigate.
Thanks anyway!
Posted on Feb 01, 2010
  • 1417 Answers
SOURCE: the line 2 ringer is off (it displayes message
Please kindly visit this site to get the proper recommendation on how to fix up the problem .
please visit http://www.panasonic.com/phonehelpand the probem will be sole the is free.
Good luck and thanks for using fixya.
Posted on Jan 20, 2011
  • 1340 Answers
Here is a link to your manual.You do not have to sign up for anything and there is no junk after.Click download,then enter the 5 digit code and press download again.It will open a menu.If you want to save it permananetly click save.It will most likely save to your documents folder.For 1 time use click run.You may want to save this site for future reference also.It is excellent and has a wide variety of electronics.There is mention of turning off the ringer on page 23.At the end of the manual on page 59,it mentions for a problem with BOTH ringers not working to refer to pages 23,and/or 38.Page 23 does mention the ringer volume is separate for both I believe,that may be all.Try it out and if that doesn't work try as follows.I don't have a Panasonic,but most phones have the settings available by pressing the menu button,while the phone is off,no dial tone.Pick it up and press menu.Listen in the earpiece and you should hear the menu open.To cycle through the options,obviously it will start at the top so press the directional pad down.When you get to what you want,press right once.To set the ringer,one press right should turn it on,another press right should turn it off again.For other menu options such as setting the answer machine rings before it answers,press right and it should cycle throughall of it's options and repeat after no more are available.When you have all of your options set up,I believe just turning it off will be okay.When you are setting the ringer,it should prompt you to set a certain button to save what you have set.Different manufacturers have different ways,but the basic principles of programs are usually somewhat similar.If you have any questions or need more help,just comment here and I will get an autolink to your post and reply ASAP.I really encourage responses so I can follow up properly as I know where you stand and asking someone else restarts all the explaining because we cannot see other 'Expert's' responses.Good luck,Greg
Just my kind of luck too.The manual has how to set up everything EXCEPT 1 unit's ringer.The manual says colume,ring tone and everything but.If this does not get your issue solved,please let me know.
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Posted on Jan 23, 2011
How do I turn off the ringer on my Panasonic Telephone base?
It would help if you add a comment with the model number of your phone. For the KX-TG6572R, to set the ringer to off on the base, press and hold the Down button on the base until the phone beeps when the phone is in standby mode. Note: if the phone has an intercom mode, the ringer for the intercom is never silenced.
I hope this helps. If this procedure doesn't work for your phone, please add a comment with your phone's model number. Then, I will try to find additional information about the ringer volume control for you. (I know some phones have a physical switch on the base for the ringer volume.)
Jul 08, 2015 | Panasonic Lands Phones
I cannot get my Panasonic base KX-TG5583 to register 8th handsets - only seven
It has to do with the electrical load that each ringer imposes on the line. Each set has a limit on how many handsets you can register with it. If you look on the bottom of the base you will see on the identification plate a data item called Ringer Equivalence Number or REN.
In telecommunication, a ringer equivalence number (REN) is a somewhat arbitrary number which denotes the electrical load a telephone ringer has on the line.
Dec 05, 2013 | Panasonic KX-TG5583 Trio Cordless Phone
The ringer on the phone is off. So, when the phone is off the base unit, I cannot hear it ring. How do I turn the ringer on? KX-TG2730
Hi! Most phones have a double function for the "#" key. Press and hold this button "#" and the silent mode will turn off/on.
I hope this will help you! Have a nice day!
*please don't forget to rate my services :)
Sep 03, 2011 | Panasonic KX TG2730 Cordless Phone...
My 2nd phone will ring bt the main one I can't seem to turn ringer on..Help Please
If this is the model I think it is, your phone line cord is pluged into the base of the main handset. So let me see if I'm understanding your problem...You have a single line phone with two handsets, and your remote handset rings, but the main handset at the base unit does not. Since your second handset rings when called,your line is working, and your unit's base is working, as well, or the other handset would not ring. Therefore your problem is within the handset itself. I will assume you've made sure the ringer is turned ON and the volume turned UP. Use the Menu button on the handset to find these variables and make sure the ringer is ON and turned UP. Place the handset on the charging cradle. Press the ON button WHILE the phone is on the cradle. You might have to use the speakerphone button to do this. This will resync your handet with its base.
Feb 01, 2011 | Panasonic KX-TG2631 Cordless Phone
The line 2 ringer is off (it displayes message "ringer off line 2" on the number 2 remote phone panasonic kx-tg6700 & I cannot figure out how to turn it back on
Please try this first (Reset the phone which requires the ringer to operate again with the main base) Some Panasonic cordless phones come with up to five handsets each will need to be properly adjusted. You may need to set the main handset to synchronize with the base unit plugged into the telephone wall jack and assign special configuration numbers to the other handsets in order to properly identify each one within a specified location. One handset left in the turned on mode may make it impossible to place calls with the any of the other handsets. This will continue until either the battery dies or fails on the handset or the phone is switched off and replaced in its charger for charging again. Synchronize the main handset by pressing the MENU button on the handset, then pressing the down button IN order to select the number you wish to assign to that handset. Repeating this process if you have already done so will greatly decrease the level of errors experienced with panasonic phone
Jan 20, 2011 | Panasonic Lands Phones
Some Panasonic cordless phones come with up to five handsets each will need to be properly adjusted. You may need to set the main handset to synchronize with the base unit plugged into the telephone wall jack and assign special configuration numbers to the other handsets in order to properly identify each one within a specified location. One handset left in the turned on mode may make it impossible to place calls with the any of the other handsets. This will continue until either the battery dies or fails on the handset or the phone is switched off and replaced in its charger for charging again. Synchronize the main handset by pressing the MENU button on the handset, then pressing the down button IN order to select the number you wish to assign to that handset. Repeating this process if you have already done so will greatly decrease the level of errors experienced with panasonic phones.
Jan 20, 2011 | Panasonic KX-TG6700 Phone
How do i turn the base ringer off on my KX TG6500 phone
It's in p.25 of the manual: press Line Select until the line you want is displayed (can't do both at once). Press the down arrow (on the volume button) until two beeps sound. That's it!
Dec 21, 2010 | Panasonic KX-TG6500 Cordless Phone
Ringer off displayed on base. How do I turn it back on? Just called myself from my cell phone and phone actually did ring.
Thanks for giving me the opportunity to help with your problem.
The "ringer off' message on the base display is referring to the ringer on the "base" unit not the phone ringers. Your phone handset(s) will still ring even when the base ringer turned off.
To turn the ringer on the base back on press and hold push the ^ symbol on the base until it beeps two times, To turn the base ringer off, press and hold the v symbol until the unit beeps.
If my information has proven to be of help, please give me good rating. Thanks for using FixYa!
Jan 27, 2009 | Panasonic KX-TG5632 Phone
Ringer
Hold the Low volume key on the base unit for sometime. A beep will sound that means the ringer of the base unit is off.
Feb 18, 2008 | Panasonic KX-TG5632 Phone
Lands Phones Logo
124 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
