Question about HP DeskJet 890C Series
HOW TO CONNECT DESKJET 890C PRINTER TO VAIO LAPTOP
  • 639 Answers
Connect the USB cable to PC through which the printer is connected to the PC
Now switch ON the PC(only PC and not the printer)Login to windows and now switch on the printer.Now PC will ask for the Driver as new hardware found wizard. Here you need to install the Driver.
Please be informed that any hardware device needs a driver software to run within a PC, and the driver software depends on the Hardware Make/Model and the Operating System software you are using in your PC to operate it.You will get the Driver software of any hardware within the CD provided with the hardware part at the time of its purchase. The hardware may be an entire PC,Laptop,VGA card, sound card, LAN card,webcam,printers etc.
If you do not have the CD or misplaced it somewhere then you need to download the driver software to get going. Thus you need to know all the above information to get the exact software your PC needs. As you have not mentioned the Operating System you are using, i am unable to give you the direct download link.
However you can download the same by visiting the 'software downloads' section of the website of the hardware brand you have purchased. You just need to Google the name of the brand and visit their website and search for the download section.
If you feel that, my answers have helped you getting solution to your problems then please give a vote.
Posted on Feb 14, 2012
Installed HP deskjet 890c printer to new windows 7 laptop - purchased new usb printer cable - will not print from laptop but will print test page from printer
Before we conclude that cable is faulty, we have few things that need to be checked.
  • In the device manager check for "Other Devices" and expand it, you may see an device with exclamation sign on it. Right click and uninstall the device.
  • Disconnect the printer USB and reconnect it back.
  • Windows 7 detects the hardware and automatically installs the correct driver.
Note: When you connect the USB cable to the printer, and then to the computer, Windows 7 activates Windows Update. Windows Update searches online for the most recent product driver on the Windows Update site. If the online driver is more recent than the driver stored in Windows 7, the computer downloads and installs the updated driver.The Windows Update process takes place automatically. Therefore, you might not notice that the process is in progress.
If you dont see any notification on connecting the printer, try plugging to different USB port.
If non if these works, replace the cable.
Good Luck!!
Feb 07, 2012 | HP DeskJet 890c InkJet Printer
I am searching for a service manual for an HP 890C Deskjet.
you can download that on the net, just go to the website of HP and type the model of your printer. you may also visit any hp service center in your area.
Jun 28, 2011 | HP DeskJet 890c InkJet Printer
My HP 890C printer just refuses to print.
Your ink system is clogged. There is no way to clean it out as the caustic ink has eaten away the pump.
Dec 19, 2009 | HP DeskJet 890c InkJet Printer
The yellow flashing light flashes while power is on, and printer does not answer the print function.
One or both print cartridges are failed.Just replace first color cartridge, if not help then and black.
Nov 04, 2009 | HP DeskJet 890c InkJet Printer
How do i reset my deskjet 890c?
next to your power button there will be a reset button............if it is not available than u have to do it manually while u are connected to your system...........then go to connections there u select your printer type and reset it........
Oct 30, 2009 | HP DeskJet 890c InkJet Printer
Printer Problem
HI!. Most printers have a self test facility to do a test page without being connected to any PC. If you can find that out from the HP site, that's a first step. Also, check printers in Windows Control Panel to make sure it is the "Default" printer. Try to send a test page. e.g. right click on the icon for the printer, select 'properties' & look for "Print test page". If all these work then next you would open Windows notepad and just type in a couple of rows of text, then print. If that works, then you try your original application program to prove that it is the cause (somehow). Check all physical connections & re-load the s/w driver.
Also, you could take your printer to a friends place that has the same Windows OS and see if it installs OK. Try & test print etc.
Hope this helps you to narrow down the problem.
Jan 06, 2009 | HP DeskJet 890c InkJet Printer
Hp 890c will not turn on with power plugged in
The things it could be: 1. There may be a failure of the switchmode power supply inside or a fuse on the printed circuit board has blown.
2. The ON/OFF button is not making good contact. Again, this would need the cover off and clean any contacts - try to short the contacts. Find a electronic or computer technician to help you with this. Maybe buy another second-hand, working unit, and use the original for spares.
Aug 14, 2008 | HP DeskJet 890c InkJet Printer
Hewlett packard deskjet 890cprofessional series
They come in the box when purchased new Where did this one get to? If you do not have it, then the driver can be downloaded from the HP website and all the other software you can live without sourcing it elsewhere. If you need specific stuff come back with what you think you need
Jun 14, 2007 | HP DeskJet 890c InkJet Printer
Computers & Internet Logo
101 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
