Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
I have a Lifmaster opener. I had to replace my wireless keypad. It worked fine but the garage would open by it self. I replaced the keypad 3 times but the garage still opens by it self and only when I have the battery in the wirless key pad.
  • Robert Rosales Feb 20, 2012
    I changed out the control board on the wired button on the garage door wall but garage door still opened by itself or someone in the neighborhood has the same frequency of my door.
    President:
  • 3,197 Answers
I would try a different source for the keypad.
Posted on Feb 20, 2012
TJBENGR
  • 121 Answers
SOURCE: Garage Door Key Pad
Assuming, from what I read, the remote works..The inside switch is just a doorbell switch which will wear out or have the contacts get bent or dirty. Take off wall, and change for new one or see if the contacts can be cleaned or adjusted. If the pad is electronic (coded) the wires may be bad or the control defective. Usually momentary contact of the two wires will cause the door to actuate.
Posted on Apr 21, 2008
SOURCE: garage door opener key pad not working
so i spent the better part of this morning trying to figure this same thing out... here's what I found.
You need to identify the serial number, which is found on the unit hanging from the ceiling... it will be like a 13953970. I found mine behind the lamp light protector thing. NOT the back with the stickers. 41A5021 is actually not the number that is important.
then go to www.managemyhome.com its a website ran by sears. you have to register, for free. then go look for manuals, in one of the tabs running across the top of the site is a choice for manuals. then search by Craftsman then enter the serial number.
then pull up the owners manual and check out the instructions.
** i found out that the old house i bought did not actually have the same keypad opener as came with the craftsman. so i had to closely inspect all sides of the internal keypad opener (not the one outside) and find another serial number. then i went and got the manual from www.managemyhome.com and realized i needed to add a new 9-V battery before I could proceed. So now i'm heading out to walmart to get that.
after a frusterating morning of service number and internet searches I hope after I get this damned battery the clouds will part and god will shine some luck on me.
goodluck to yourself!
Posted on Sep 29, 2008
Door Tech
  • 98 Answers
SOURCE: Liftmaster Key Pad
Yes, this is a common problem. I recommend the Domino GD-1. It is a wired keypad but the batteries are on the inside so they stay warm, plus you can use from 1 - 6 digits instead of just 4. It is harder to install but worth the effort.
It does not come with wire so you will have to get some bell wire.
Posted on Feb 07, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: craftsman outside keypad
On the back panel of the opener itself is a small pushbutton. Press the button and the indicator near it will light. While the indicator is lit, enter the new 4-digit code on your keypad and it will be set. (You are actually programming the receiver with the new code this way. The wireless keypad doesn't store a code.) The programming light goes off on its own.
Posted on Feb 13, 2009
  • 3197 Answers
SOURCE: My garage door openers and wireless entry key pad do not work.
The manufacturer changed the radio frequency and it will not work with older models.
Posted on Jun 10, 2009
Hi... I have a Sears Craftsman Garage door Opener Model# 139.53600 Outside garage door keypad which is hard wired (electric) isn't working. However the inside keypad and the car transmitter are both...
A wireless keypad will not work with your opener. Your opener is pretty old and the new models are much safer. You might consider replacing the entire thing.
Feb 22, 2011 | Sears Craftsman LiftMaster Chamberlain...
Craftsman 1/2 HP Model 139.53914 The wireless outdoor keypad will not open the garage door but it will close it. The two garage door openers work just fine and the indoor keypad works fine. Replaced the...
Sounds like it has lost signal strength and the door cuts it down to the point that the receiver never gets the signal when the door is in the way. If it did that before you replaced the battery then you will have to replace the keypad.
Dec 08, 2010 | Sears Craftsman LiftMaster Chamberlain...
The wireless keypad for my Craftsman 3/4 hp garage door opener does not work at all. I replaced the battery and it still no sign of life. Do I need to replace the keypad or can it be fixed? What is the...
Can't tell the life span for sure. They can fail at any time. You will need a new one. The model number should be on the back. Make sure you get the correct one as there are several.
Jun 19, 2010 | Sears Craftsman LiftMaster Chamberlain...
Wireless keypad closes door but won't open door. Just started this about a week ago. I replaced battery, still no luck. Car remotes work fine.
You keypad has lost signal strength. It has enough to work when the door is open but not enough to penetrate the door. A replacement is needed.
Oct 28, 2009 | Sears Craftsman LiftMaster Chamberlain...
Just replaced drive gear, door will move in open direction only
bet your working of a lifmaster chamberland or sears craftsman there all the same thing listen you have to limit controls on left side of operator if you looking at it from behind check the limit control in the middle of those to with cover off motor, also make sure both photo eyes are lit up soilid...
Apr 03, 2009 | Sears Craftsman LiftMaster Chamberlain...
Cant get wireless Keypad to Link to new Garage Door Opener
The radio frequency has changed and the old keypad will not work with the new opener.
Mar 10, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
49 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
