Question about Samsung Televison & Video
White direct tv remote looking for samsung pro vision remote codes
I am using the white Direct TV remote and looking for codes to operate the Samsung Pro Vision Television Mode# CT-5038VC
SOURCE: need code for direct tv remote
I have an insgnia tv and remote but I would like to have the code for my directv remote.
Posted on Dec 28, 2007
megatronix
  • 57 Answers
SOURCE: manual problems
User manual or repair manual?
Posted on Jan 18, 2008
ALL CVODES FOR DIRECTV RC23 REMOTE
Posted on Mar 13, 2008
IrishDruid
  • 2712 Answers
SOURCE: toshiba ct-90275 code for direct tv d10
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. - You can rate a solution with one of four ratings as explained under (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Posted on May 05, 2008
IrishDruid
  • 2712 Answers
SOURCE: help
Hope that helps!
IrishDruid
Remote with no code search button. TDE system # SKU#33201048 looking for the code for sanyo flat screen tv and direct tv cable box and Samsung blue ray player
If your Samsung remote does not offer some sort of code search capability you may only able to control your Samsung DVD player by pressing the DVD button to turn it on. It may be more practical to purchase an inexpensive universal remote and use it to control both your TV and your DVD player.
Dec 26, 2015 | Samsung Televison & Video
Direct tv remote programming to operate tv
call directv. they are very helpful with programming remotes.
1-800-247-3288
Mar 07, 2014 | Samsung Televison & Video
I have direct tv and want the remote to work
0568,0193,0182,0162,0155 are the codes to check. If you wish to get more setup codes, check this link. Setup code list to DirectTV remote control are given. Pull up older posts.
Mar 04, 2013 | Samsung AH5900092W Remote Control
How do you Program Codes in a Samsung Remote Control TM59 AA64-50236 KIE #1-4 for a Sharp TV
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Nov 27, 2012 | Televison & Video
I bought a used samsung t.v. and the remote don't work. its got new batteries but don't work it might be a samsung universal remote do i need to but my t.v. code in it. how do i do it and what is...
Hello
Three digit universal remote codes to check with Samsung tV are:
004/ 005/ 009/ 015/ 104/ 105/ 106/ 109/ 133/ 172
Four digit codes are:
0105 0077 0076 0109 0007 0009 0004 0005 0085 0172 0942 0358 0012 0015 0080 0104 0106
Direct Code Entry
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
Jul 26, 2011 | Samsung TV Remote Control
Needs a code to key in a universal remote control to be use on samsung tv model CT 3312J
Hello
Three digit universal remote codes for samsung are:-
Four digit universal remote code for samsung are:-
Direct Code Entry
Mar 19, 2011 | Samsung Televison & Video
I have a samsung le22c450c8w tv,i need a remote that will operate tv and dvd player off one remote.
a direct tv remote will do this there is a toggle switch at the top of these codes are online
Oct 19, 2010 | Samsung TV Remote Control
Samsung Blu ray code for direct tv remote
is there any remote that i can program tv,cable,direct tv,and blu-ray player all in 1
Apr 19, 2009 | Samsung BD-P1500 Blu-Ray Player
Program remote for direct tv receiver
Not a problem - here's a site that was built just for that problem. http://www.remotecodelist.com/remotes/
Simply scroll down through the list of remotes and locate the remote. Then click on the link to find a host of codes and procedures to program that remote for almost any device it's capable of operating.
Hope this helps!
Bill
Dec 04, 2008 | Frigidaire Control
Televison & Video Logo
20 people viewed this question
Henry  Thomas
Henry Thomas
