Question about Toshiba Televison & Video
Toshiba DS-1107A combo
After a local lightning strike, the power supply malfunctions. I need the circuit diagram to fix it.
  • John Crabtree Feb 13, 2012
    Oops! Sorry - wrong model number! It should be: SD-37VSR
  • 375 Answers
SOURCE: Samsung SP43w6HD circuit diagrams
servicemanuals.net
Posted on Mar 28, 2008
Ajkill
  • 2035 Answers
SOURCE: RD-XS24SB HD/DVD player / Recorder
Please check if the fuse is blown out in the player and like to perform DIY on the DVD you will need a service manual to guide :
Please use this link to get one :
http://www.user-manuals.com/advanced_search_result.php?keywords=Toshiba+RD-XS24SB+service+manual&forward=plist
Good luck..
Posted on Jul 31, 2008
rtrahan
  • 741 Answers
SOURCE: ds-1107a inverter/power supply no power or comes on &LCDflickers
Classic sign of bad inverter. Since it is inside the LCD not something you can fix yourself unless you work with electronics. Needs to go to the repair shop.
Posted on Jan 01, 2009
  • 5 Answers
SOURCE: warfedale dvd
I don't have a service manual, but IC2 is a 1200P60, datasheet can be found at http://pdf1.alldatasheet.com/datasheet-pdf/view/115078/ONSEMI/NCP1200P60G.html
Posted on Aug 24, 2009
  • 157 Answers
SOURCE: Model TDC2075A Sansui Had lightning storm, lost
you mite try replacing the ac fuse 1 time-if it blows again there is a short in the power supply-i would then check rectifiers in the primary of the power supply-then check the fet-if any of them are shorted replace them
Posted on Sep 04, 2009
When and How Should a Surge Protector Be Used on a Fixed Switch?
Common Causes of Lightning Strikes
  • Outdoor network cables or power cables are routed overhead.
  • A switch is deployed outdoors but is not properly grounded.
Damages of Lightning Strikes
  • If power cables of a switch are routed overhead in an outdoor environment, lightning strikes may burn the power supplies.
  • If network cables of a switch are routed overhead in an outdoor environment, lightning strikes may burn interfaces of the switch.
When a switch undergoes lightning strikes, overvoltage is induced by lightning on network cables and transmitted to interior of the chassis. The surge protection measures, such as lightning rod and chassis grounding cannot prevent the damage. Therefore, surge protectors or surge protection circuits are recommended.
Surge Protector Use Precautions Take the following precautions to protect a switch from lightning:
  • Ensure that the ground cable is connected to a ground bar or a ground point on the cabinet.
  • Avoid routing cables overhead in an outdoor environment. Bury cables underground or route them in steel tubes.
  • To protect network interfaces against lightning, use 8-line surge protectors (or Huawei certified 4-line surge protectors).
  • When installing a network interface surge protector, connect the IN end to terminals and the OUT end to network interfaces of the switch.
If a fixed switch is installed in a network box, follow these instructions:
  • Connect the ground cables of the switch and surge protectors to the ground bar in the network box.
  • The maximum length of a ground cable cannot exceed 40 cm, and a length of smaller than 15 cm is recommended.
  • If the network box is located outdoors and power cables are routed aerially over a long distance (more than 300 m) to the network box, it is recommended that you install a power supply surge protector in the network box. The decoupled power cable must be at least 3 m long
S2300 Switch Thunder link com
Dec 08, 2016 | Office Equipment & Supplies
How do I fix a 50 Plasma TV that seems was struck by lightning
Your probably have power supply damage, but lightning strikes can do major damage in all circuits.
Aug 07, 2015 | Panasonic VIERA TC-P50U50 50-Inch 1080p...
Where can I find a new part N575924055457PW?
Those other numbers are a little more useful but I cannot find an exact match
is the ebay item below similar?
http://www.ebay.co.uk/itm/TOSHIBA-26LV610U-POWER-SUPPLY-BOARD-CEH441A-DS-1107A-PD42-/260859978702?pt=LH_DefaultDomain_0&hash=item3cbc7763ce
If this is similar then you may find your TV shares its DNA with other makes like toshiba. The numbers you gave have relations with Benq (sony) too.
What was the original problem with the TV. Most TV fail because of capacitors and changing a few here or there often fixes the fault
Nov 14, 2011 | Televison & Video
We took a lightning strike and my RCA 20f510td has no indication of power. Is there a fuse that needs to be replaced?
Hello
The faults occurs during lightning strike is not predictable. At present, the power supply inverter section of your RCA ahs damaged. A thorough chekup must be done to detect whether there is any other faults also occured or not during this time. OK.
Apr 10, 2011 | RCA 20F510TD 20 in. TV/DVD Combo
Lightning strike, blows internal fuse (6.3v 125/250) on plug in.
sounds like the lightning strike took out at least the power supply if not more. sorry to be bearer of bad news.
Oct 31, 2010 | Toshiba 24AF41 24" TV
Model TDC2075A Sansui Had lightning storm, lost power no close lightning strike. TV will not power up, don't know if it has internal protection or is power supply went out
Sep 04, 2009 | Sansui CDVD1900 19" TV/DVD Combo
Ds-1107a inverter/power supply no power or comes on &LCDflickers
Jan 01, 2009 | Dell E173FPb 17" TFT LCD Monitor
Color messed up on tv since lightning strike
your tv may have ben magnetized by the lightning strike.
tv's have an automatic degaussing circuit that demagnetizes
the pix tube when the set is turned on. this degaussing circuit
may not be working or magnetism may have been too strong for
the internal degaussing to correct.
contact local tv repair shop in your area see if they can manually
degauss your set , it should be a min. service charge around $25.
roland
Mar 22, 2008 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
Televison & Video Logo
113 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
