Question about Dell Computers & Internet
I have a Dell Dimension 9150. When I turn the power on the Dell screen comes up and then it goes blank. There are no diagnostic lights on but the power is still on because I can hear the fan inside.
  • Dell Master
  • 27,725 Answers
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have secure dust free connections and are not faulty or just replace them they might be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electical extensions
even something as small as an electrical fan and its lead can cause you problems or just replace them they could be faulty a computer needs all electrical power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error
make sure your graphics card is securely seated with no dust built up or in the socket
if you remove your graphics check the socket to make sure its dust free
restart your computer then reinstall it this should activate found new hardware wizard
hope this helps you
Posted on Feb 14, 2012
  • 85 Answers
SOURCE: dell dimension 5100, power button has turned orange
If under warranty contact Dell? I had this same problem, a new motherboard and fan assembly fixed this problem. Bad capacitors on the motherbard.
Posted on Apr 12, 2008
pagebor
  • 2785 Answers
SOURCE: Dell Dimension 8300 flashing amber power light and dead pc
it seems *********** board is having problem plz send it for servicing
Posted on Aug 08, 2008
Maanita
  • 1142 Answers
SOURCE: dell dimension 8100 diagnostic lights
please refer to the below link...being dell support technician myself this link would give you the best possible help
http://support.dell.com/support/edocs/systems/dsleest/codemess.htm#diagnostic_codes
Posted on Oct 18, 2008
linktriscuit
  • 89 Answers
SOURCE: My screen goes blank immediately after initial DELL startup image
You can either try to reset the BIOS, or have the restore cd fix it for you. By the way, what does the message say?
Posted on Nov 27, 2008
  • 28 Answers
SOURCE: I have a Dell Dimension 4600 and it won't boot up.
i would have to disagree with jerry, while that seems reasonable if the motherboard fan isn't running at all then whether or not the video card is ok is somewhat irrelevant.
I would agree somewhat though, i think the PSU might be a good thing to check to see if it is functional.
when you power it on does the CPU fan start or shudder at least ? that would be my first guess for a problem if you had been having any problems recently
Posted on Apr 17, 2009
I have a Dell dimension 9150 with 2 hard drives. The PC wont start up so I want to copy the data on the drives using USB 2.0 To SATA IDE Cable but when it reads the drive Windows says it can not read the...
It sounds like your dimension 9150 desktop has a primary and secondary drive.now when you say it wont start up what are you referring too?does it not power on at all, do any of the fans or lights come on. and also sounds like you got an external hard drive. now I got confused when you explained when it reads the drive windows says it cant read the drive. My question is I thought the pc would not start up? can you explain little more in detail, so i can try and give you the right advice?
May 26, 2011 | Dell Dimension 9150 (DIM915MIN) PC Desktop
I want to restore my dell dimension 9150 to factory settings can u help
If you were using Windows Xp just press Ctrl + F11 when you turn on your computer.
Press F8 if you were using Windows Vista then select repair your computer from the list.
Then if you have any disk or any Operating System disk insert the disk then boot from CD and follow the on screen instructions.
Hope it helps you....:)
Sep 06, 2010 | Dell Dimension 9150 (DIM915MIN) PC Desktop
Dell Dimension 9150, flashing orange light on front power button. I noticed an orange light flashes on the ethernet port when plugging in the power cord, but it wont power up? Any suggestion, please help!
The power supply needs to be replaced, How old is the system, Can you provide the tag, i may be able to get you one for little or no cost. if your interested :)
Stephen.cscorp@gmail.com
Apr 14, 2010 | Dell Dimension 9150 (DIM915MIN) PC Desktop
My Dell Dimension 9150 is unstable. The Dell Diagnostic indicates memory failure in DIMM socket 3. I reversed the modules in the DIMM sockets and Dimm socket 3 failed again. Motherboard?? My motherboard...
Yes you can. Your best is to use the largest and best ram in the number one slot. I would remove ALL the ram and start with the 2 gig in the first slot - then add others until you get the error message - remove that one and keep the rest.
Mar 31, 2010 | Dell Dimension 9150 (DIM915MIN) PC Desktop
PNY GeForce 9500GT 512MB DDR2 PCIE 2.0 blank screen after install
Is the PCI Express Slot a 2.0 x16? that could be the issue not positive those cards will work without that specific slot Also check on the graphics card for a 6Pin plug usually they wont work well with out it hooked up to the power supply the plug should say PCI-Epress 1 or 2 good luck!
Jul 23, 2009 | Evga NVIDIA GeForce 9500GT,, PCI Express...
My Dell Dimension 9150 will not turn on
Use your CD to boot up the computer and recover your operating system
May 05, 2009 | Dell Dimension 9150 (DIM915MIN) PC Desktop
I have a Dell Dimension 4600 and it won't boot up. When I turn it on the green power light comes on and hard drive activity light flashes however no fans come on, the screen doesn't show the Dell logo or...
Apr 17, 2009 | Dell Dimension 4600 PC Desktop
Lights 3 &4 stay on.
Computer beeping at you is usually a problem with the video card or memory. Try re-seating both and see if you still have the same problem. If you do, individually remove each component and power on to test if the beeps persist.
Jan 06, 2009 | Dell Dimension 9150 (DIM915MIN) PC Desktop
Computers & Internet Logo
27 people viewed this question
Alun Cox
