Question about Korg SP170 SP-170 88 Key Digital Piano White with Stand
Korg SP-170 and Pedal Reverse (Yamaha FC4)
I bought yamaha FC4 today and when i started using it, it becomew reverse. i search over the google. but they didnt give me any proper answer so what can i do? btw, i lost my piano manual book. :p
2 Suggested Answers
  • 5603 Answers
SOURCE: i have around $100 to spend on a used digital
You will likely have to double that budget to get anything decent... but look for a Yamaha in the PSR series (61 keys minimum). To get a full 88 key, you might have to be up in the $400 range for anything really decent.
Posted on Jan 27, 2010
How to fix a corrupted display?
If everything else works fine then it likely just needs the display replaced.
Apr 24, 2014 | Yamaha FC4 Piano Style Sustain Pedal
My sustain pedal works in reverse
You bought the wrong model - e.g. Yamaha models work reverse.
Return for Exchange
Or try opening up and re-solder the cable to the micro switch if possible
Jan 31, 2014 | Casio Wk-200 Wk200 76-key Digital Personal...
Sustain pedal does not work
Yamaha FC4 and FC5 sustain pedals are normally closed, sorry Fred. Roland is opposite. I suspect the P120 just needs to be reinitialized. Hold down top white key (C) while turning on power. Wait 3 seconds and then release white key. Should now be reset to factory spec. Always plug the pedal in before you turn it on. If it still doesn't work check it with a meter.
Mar 17, 2012 | Yamaha CP300 Stage Digital Piano...
I have a Casio CDP 200R. I recently purchased a FC4 foot pedal but it works in the reverse way. I tried switching the piano off and then plugging it in and it still does not work. Can you please let me...
You should try having the pedal connected when you turn unit on. Some pedals can be rewired to act opposite... However I believe this pedal should work with the Casio. You can open the pedal and see if you can move one wire so it works opposite. Also verify that the jack is set to the "SUS" setting per your user manual... around page E14
Sep 07, 2011 | Yamaha FC4 Piano Style Sustain Pedal
I have a mo8 and the sustain pedal is reversed. What can I do to make sustain when pedal is depressed?
This is a common problem when one uses a Roland sustain pedal with other brands such as Yamaha. Frankly, I would just get a Yamaha pedal to use with the unit. Some Yamaha synths have a setting for pedal "polarity" but I could not find it in the mass information of the MO8 manual. The Yamaha Tyros synths have a setting that is easily found in the utility settings... I don't see that in this manual. SOMETIMES you can open a pedal and find that you can with a soldering iron transfer a wire to reverse the pedal... but not all pedals have both contacts available.
Jul 10, 2011 | Yamaha Music
Fc4 sustain pedal is in "sustain" mode at all times -- it won't release the sustained notes. I tried plugging the pedal in (to a roland ep-9) before powering up and had the same problem.
Sorry, but the Yamaha pedal has the opposite sense (it is a normally open contact) than what is REQUIRED by Roland equipment. Roland requires a Normally Closed contact. Unfortunately, one is confused because the Roland jack for the sustain shorts itself to no sustain when you unplug a pedal. SOMETIMES one can open a pedal and with soldering iron change a wire to reverse the pedal sense IF the particular pedal has both contacts available.
Jun 16, 2011 | Yamaha FC4 Piano Style Sustain Pedal
Sustain is in reverse yamaha p-85
I have the same problem, But I have been using the same pedal since new. Infact it came with this pedal. Then suddenly it started doing this. Could I have changed soem setting by accident?
Jul 08, 2009 | Music
I need a volume pedal for a SX KN6000 Technics keyboard
As there's no polarity switch on the FC7 the quick and dirty way is to cut the cable and swap the wires around.
Feb 18, 2009 | Music
Korg SP170 SP-170 88 Key Digital Piano White with Stand Logo
125 people viewed this question
Top Korg Music Experts
Vito Vacirca Jr.
J.D. Browning
J.D. Browning
Andrew Taylor
Andrew Taylor
Are you a Korg Music Expert? Answer questions, earn points and help others
