Question about CDA Refrigerators
How do you adjust a cda fw320 fridge door
FW320 integrated fridge serial no. 853910015422. The outer wooden door has slipped. How do you adjust it?
4 Suggested Answers
Sea Breeze
  • 4654 Answers
SOURCE: I have a CDA integrated fridge/freezer, the fridge is working but
OK then have a look at the back wall of freezer is frost building up on rear panel?
Posted on Jan 25, 2010
SOURCE: The top hinge of my neff integrated fridge freezer has broken.
The top hinge of my Neff integrated fridge freezer has broken so the door won't open and shut properly. As a temporary repair I intend to swop the hinges around -replacing the top hinge with the middle one but can't see how to remove the hinges. Can anyone help?
Posted on Jun 12, 2010
  • 114 Answers
SOURCE: please can you tell me
yes you have to screw into the door. usually you will see indents in the door where screws should be located. to make it easier use a fine drill bit and drill into the door first
Posted on Nov 13, 2010
Integrated fridge door keeps springing open. what is causing this?
the magnetic seal along the door may have gone bad. or bad worn out door seals not keeping or creating the pressure needed to cling door shut
Feb 19, 2015 | Whirlpool Refrigerators
Top door will not close by itself on fridge
Sounds like the floor of the house.. might be your problem..Try moving the fridge out of its position and build a small flat platform in that place and level it, then place your fridge on top of it..just in case u may need a little final adjustment get those small wooden wedge shims when you get your wood..they sell them at lowes or Most lumber yards....that should take care of the leveling..good luck..good luck
Nov 28, 2014 | Electrolux Refrigerators
How do I get the dimensions for a fridge freezer?
Looks like they are the same outer dimensions.
Old:
New:
  • Width of cavity: 560 mm
  • Height of cavity: 1772-1776 mm
  • Depth of cavity: 550 mm
http://www.appliancesdirect.co.uk/p/ckbc3150euk/candy-ckbc3150euk-integrated-fridge-freezer#maindesc
Oct 06, 2014 | Refrigerators
What are the serial numbers of the faulty Beko fridge freezers that is a on going problem with the defrost timers.
CA 5411 FFS/FFW/FFX
CA 7014 FFX
CA 7015 FFW/FFS/FFX
CDA 539 FS/FW/FX
CDA 543 FS/FW/FX
CDA 645 FW
CDA 647 FS/FW
CDA 648 FS/FW
CDA 653 FS/FW/FX
CDA 659 FS
CDA 751 FS/FX
CDA 752 FS/FW/FX
CS 460 FF/FFS/FFW/FFSD
CS 461 FFW/FFS
CSA 4706 FFX
CSB 4606 FFSD/FFS/FFW
Hope this helps.
Jul 08, 2011 | Beko Refrigerators
Apparently there is a problem with Beko refrigeration manufactured between 2000/2006. Please confirm model number in question.
From Beko:-
"The BEKO frost free fridge freezer models affected were manufactured between January 2000 and October 2006. These have a serial number that begins with either 00, 01, 02, 03, 04, 05 or 06. and this information can be found on a label inside the fridge. Beko is making a free of charge modification to all affected models, this modification takes approximately 30mins.
Other Beko branded models and all Beko frost free fridge freezers manufactured after this date are unaffected.
Affected model numbers:
    • CA 5411 FFS/FFW/FFX
    • CA 7014 FFX
    • CA 7015 FFW/FFS/FFX
    • CDA 539 FS/FW/FX
    • CDA 543 FS/FW/FX
    • CDA 645 FW
    • CDA 647 FS/FW
    • CDA 648 FS/FW
    • CDA 653 FS/FW/FX
    • CDA 659 FS
    • CDA 751 FS/FX
    • CDA 752 FS/FW/FX
    • CS 460 FF/FFS/FFW/FFSD
    • CS 461 FFW/FFS
    • CSA 4706 FFX
    • CSB 4606 FFSD/FFS/FFW"
If you find that your model is listed above and is in the correct model year range then you need to click here for further guidance. There is also a freephone number, but it's swamped by callers. Even if you get through you will receive exactly the same advice as you would from the website links.
If you want to know more about what the actual problem is, then click here.
Please take a moment to rate my answer.
Jul 06, 2011 | Washing Machines
Please can you tell me if is it necessary to screw into the fridge/ freezer door skin to fit the brackets that are attached to the sliders on the outer wooden door
Nov 13, 2010 | Refrigerators
Jan 25, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge freezer controls
TURN THE FRIG. TEMP CONTROL TO COLDER THIS WILL OPEN THE FREEZER FLAP MORE AND LET MORE AIR IN FRIG.ALSO THE TEMP CONTROL COULD BE BAD,TURN ALL THE WAY OFF AN TURN ON SLOW AND LISTEN FOR A CLICK IF NO CLICK THE CONTROL IS BAD,THANKS-MIKE
May 25, 2008 | Freezers
The top hinge of my Neff integrated fridge freezer has broken so the door won't open and shut properly. Neff are sending replacement hinges but as a temporary repair I intend to swop the hinges around...
May 02, 2008 | Refrigerators
Refrigerators Logo
64 people viewed this question
Top CDA Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a CDA Refrigerator Expert? Answer questions, earn points and help others
