Question about Saws
How to take off saw blade on cordless circle saw
2 Suggested Answers
rowdy45176
  • 2176 Answers
SOURCE: How do u put on a saw blade for a cordless
First remove the battery, next make sure of the blade rotation and remove the hex bolt and OUTER flange lift the guard and put the blade on the spindle. Reinstall the outer flange and tighten the hex bolt, generally newer saws have a spindle lock to hold spindle to tighten the blade. If this is a Porter Cable like in the header you can go to dewaltservicenet.com and with your model and type number find an operators manual. Let me know if you need more assistance.
Posted on Mar 12, 2012
Do you have a better pruner?
Ryobi P4360/P4361 Cordless 18v ONE+ System Pole Saw ...
? 13:42
www.youtube.com/watch?v=PFANQ0JgpZk
Jun 12, 2013 - Uploaded by 8digitPDX The Ryobi 18v Power pruning saw - surprisingly good performance for the money from a ... Ryobi P4360/P4361 Cordless 18v ONE+ System Pole Saw Tree Pruning Saw .... Lithium-ionPole Saw - Unboxing and Review!
Oct 08, 2015 | Garden
Cannot get saw blade off a makita 5090d saw.
Lift the guard and clamp the blade in a vice using a pair of soft jaws and then undo the bolt.
Jun 10, 2012 | Makita 5090d 96v Cordless Trim Circular...
How to remove broken blade stub from cordless ryobi reciprocating saw
Try spraying the clamp assy with WD40 and then gently bang the front down against the work surface whilst holding open the clamp lever.
May 16, 2012 | Ryobi 18 V Cordless Reciprocating Saw
How do i change blade on dewalt dw303 reciprocating saw
Open the yellow tab on the side of the blade guard and lift the blade out. Install a new on and close the tab. If the blade has been damaged, it may need to be pried off the locating pin at the attachment point.
Aug 08, 2011 | Dewalt DC385B 18v. Cordless Bare...
How to remove the blade
If the saw doesn't have a locking blade button, you need to insert a ( most likely) 14mm thin wrench between the blade and the body of the saw, on the axle, to hold the axle. Unscrew the bolt of the axle and the blade is out. After you place a new one, the procedure is exactly the opposite. Keep the power cable unplugged during the entire time of the blade change. Safety first.
Sep 08, 2010 | Skil 18v Circular Saw saw 18 Volt 5995...
Installing the blade
There will be a small lever on the side, up front, where the blade goes. You should be able to lift the handle up and slide the blade into the slot at the head of the saw. Once you lower the lever, it will lock into place. Make sure you also have the right saw blades as some do not fit right. Hope this helps.
Jul 11, 2010 | Dewalt DC385B 18v. Cordless Bare...
Problem guiding the direction of cut with a jigsaw.
check that surface plate is square with the blade.don't push too hard,or force the saw,let it cut at it's own speed,guide rather than force.a scroll saw or band saw is more accurate as you control the work piece instead of the tool.
Oct 11, 2009 | Festool Jig Saw Circle Cutter - 490118
How do I replace my mitre saw blade?
It should still easily fit a 5/8" blade. The arbor shape shouldnt have any effect on the type of arbor hole needed on the saw blade (only round arbor holes are made on saw blades. You will probably find the arbor securing nut has a shape that fits into the flat gaps between the saw blade and the arbor when fixed. So grab a 5/8" round arbor saw blade and give it a go. It should work fine.
It is the arbor nut that secures the blade onto the arbor via friction which holds it on.
Please rate this solution on FixYa!
May 29, 2009 | Ryobi ZRTS1342L Factory-Reconditioned 14...
Saws Logo
24 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
