Question about Garden
KARCHER B403 PRESSURE WASHER
PARTS DIAGRAM
4 Suggested Answers
  • 3 Answers
SOURCE: Karcher Power Washer Problem
I had same problem won't build pressure. go to http://www.wmpcs.com/index.php?main_page=page&id=14 and see diagram. I pulled white plastic cover off top of pump (2 torx screws), remove main pump from gas motor otherwise you wont be able to get at the valve below. The important part is the valve below the the white plastic piece, it has a raised slot and mine was stuck in there. I used needle nose pinched together with pliers to lift it straight up. After wd40 and cleaning the hole and valve it should pop in and out easy. Put everything back mine worked like a charm after that. So at least I know what the problem is. Great powerwasher-I use for house painting part time and love it.
Posted on Jun 20, 2008
SOURCE: my karcher pressure washer has lost its water power
I have the same problem. With mine I have to remove the tip that I am using then pull the trigger and then replace the tip and pull and pressure should return. I believe that one of my valves is sticking causing me to reprime the pump frequently. I am trying to clean or replace my valves to fix the problem.
I hope this helps.
Posted on Apr 25, 2009
SOURCE: Unloader Valve - Karcher Pressure Washer
where is the unloader valve locaed on a Briggs Stratton pressure washer?
Posted on Oct 03, 2009
I have a karcher k2.65m pressure washer which is leaking from inside after removing the outside covers i could not see how to separate the black plastic case to get into the pump etc any ideas ??
A picture might help.
You could always find the part and number here http://www.ereplacementparts.com/karcher-226m-16016020-pressure-washer-parts-c-33388_33389_33977.html Karcher 2 26M 16016020 Pressure Washer Parts
Aug 11, 2015 | Karcher Garden
Pressure off and on every few seconds with my karcher 3000BH
hi there rjcomer2
here is web site for parts
http://www.ereplacementparts.com/karcher-2500-11944010-pressure-washer-parts-c-33388_33389_33973.html
sounds like you have a unloader valve problem or a crack in the pressure manifold housing between pressure outlet and unloader valve assy allowing unloader to cycle on/ off
or some dirt trapped in the unloader valve seat , make sure you have good supply of water - ie good flow from tap to pump
try cleaning unloader 1st and fitting in line tap filter
hope it helps
pauly46
May 20, 2011 | Karcher 2500 PSI Pressure Washer
I need to replace the high pressure outlet on a k2-26m elecreic
if you contact Karcher they will tell you where your nearest supplier is located. try this link.
http://www.karcher.com/int/contact.htm
Sep 19, 2009 | Karcher K2.26 Electric Power Washer
Can't get the spray gun onto the hose from the washer...no manual
Your posting is incomplete, so I'm not quite sure what we're dealing with here.  I understand the machine and the high-pressure hose are Karcher - right?  Is the gun also a Karcher part?  If all are Karcher parts, they should fit unless the screw threads have been damaged.  If they are not all Karcher parts, they will not fit because Karcher connectors are different from almost all others.
Please post again if this doesn't help, giving as much detail as possible, and I'll see what else I can offer.
Apr 04, 2009 | Karcher PSI Electric Pressure Washer
Garden Logo
422 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
