Question about ASUS P4P800 SE (890552603657) Motherboard
Login I am using sata disk 80gb iwth dual boot-98se + xp pro Latly I added an 20gb ide disk and now its the only hard disk on login sequense I have to select my boot disk by F8 How to make all disks to be on the login sequene ato choose the correct one?
  • Moshe Zik Aug 12, 2006
    No, problem is that the sata disk doesnt show in the login sequense, but it is recognized bacause I can choose it from the f8 login list
  • 29 Answers
You Mean You Want to be prompted on which drive you want to boot, you need a bootloader to do that (there is a way to do it with start>run>msconfig, but its been a while since ive done it, and i dont want to try to explain it, and just confuse you.
Posted on Aug 12, 2006
Asus laptop will not boot up after install of new hard drive
If your ASUS laptop uses a SATA hard drive -
SATA HARD DRIVE - XP INSTALLATION
The problem is that XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS and disable the SATA drive (enable IDE emulation), this will make XP think it is a IDE/PATA hard disk. Then you can install XP normally. When Windows has been installed then install all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
Feb 27, 2013 | ASUS Computers & Internet
Bios reconizes new hd drive but xp pro does not
Aug 25, 2012 | Hitachi Ultrastar A7K1000 HUA721010KLA330...
Is it possible to use ID harddisk and SATA harddisk at the same time?
You can indeed mix IDE & SATA drives on a computer. If installing the OS (Operating System) to the IDE HD, you will only need to instruct the BIOS to boot the IDE HD drive first.
If you decide to install an OS on & boot the SATA drive first; you will need to instruct the BIOS to boot the SATA drive first and may need to provide a driver for the SATA controller - if the OS install does not recognize the SATA drive. The driver should have been included on a disk or diskette with the controller (or on the motherboard driver disk if a built-in type controller). You should see a prompt asking "If you need to install a driver.... press F6" (or similar). Press the F6 key and supply the driver disk - and follow the prompts.
Nov 24, 2011 | ASUS K8V-MX Motherboard
I can't install win xp pro. on my G41MT-S2P..i always get "a disk error has occured" prompt
This model motherboard does not use IDE/PATA hard drives.
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive. http://www.fixya.com/support/r4335035-installing_windows_xp_sata_hard_drive
Sep 08, 2011 | Gigabyte Giga Byte Technology Ultra...
I have a Compaq Presario Desktop Computer SR1150NX. I've added a new WD SATA 1 Terabite HD. but the system does not recognize it. I updated the Bio's but see no way to activate the SATA ports. The...
Aug 11, 2011 | Computers & Internet
I have a 250gb seagate sata but when i put my 80gb IDE hdd it only detects in booting and in bios but after that if i open my computer i cant see my 80gb IDE Hdd and even in device manager my hard disk was...
there was wrong in the set up of jumper in your 80gb hdd. Look closely to the 80gb harddrive, in between the ide cable terminal and the power supply connector you will see 8pin terminals paired together and a jumper use to short the paired terminals. It is most likely that the jumper was configure to detect your hdd as master. If the ide cable you use for the 80gb hdd was also use for the dvd/cdrom drive then it will conflict with it if both jumper setting was set to master. See the description of jumper settings in the sticker of the hdd. Position the jumper to slave.
Reboot your system again and see if the 80gb finally appear in your system. When system boot upon detection of hdd, the primary master should be 250gb while your primary/secondary slave will be read your 80gb hard disk.
Jan 24, 2011 | Seagate 80GB 7200 rpm SATA/150 8MB Serial...
Vista Crashed does not recover (Can't install XP or 98SE either)
if you want to recover vista then download vista recovery disk here is the link
http://rapidshare.com/files/145731926/WVRD_www.warezspark.com.part1.rar
http://rapidshare.com/files/145698726/WVRD_www.warezspark.com.part2.rar
password : www.warezspark.com
burn the ISO disc and boot from cd rom and get it repair it automatically.
if you want to installed windows XP or 98;the reason why your hard disk could not be detected is your hard drive is SATA. disable any sata setting in your BIOS IDE configuration( if setting is not available then download SATA driver and Nlite ;make a bootable windows xp disc  with SATA driver pre installed .
this is solve your problem
here is the link for lastet SATA driver
http://download.cnet.com/SATA-Driver-Intel-Ver-7-0-0-1020-zip/3000-2122_4-162224.html
here si the link for lastest nlite software
http://home.midmaine.com/~nlite/nlite/nLite-1.4.9.1.installer.exe
regarding how to make a bootable cd with nlite with sata driver check out this link
http://www.windowsreference.com/free-utilities/nlite-slipstream-servicepackshotfixespatches-create-bootable-windows-cd/
let me know if it's helpful to you
Dec 09, 2009 | HP Pavilion dv6000z Notebook
Seagate Barracuda 7200.9 SATA driver problem
If the laptop is also XP, the drive should be recognized without problems. Sometimes this may not happen if the disk is unusually partitioned (could happen if you manually dual-booted it with Linux, for example). Verify the enclosure is working properly and has enough power supplied to, and that it appears in Device Manager. If all this applies, the enclosure must be considered working and the problem might be in the partitioning or disk access.
In XP Pro, do Start > Run Command > DISKMGMT.MSC and press OK. See whether the disk appears (if it doesn't, it's the enclosure, or its drivers - or the disk was dying and is now dead, but that's not very likely), select the NTFS or FAT32 partition - ignore any others - right click and mount the unit as drive, say, G.
If it doesn't work but the partition is found, you may need a more powerful tool such as Paragon Partition Manager.
See also here:
http://support.microsoft.com/?scid=kb%3Ben-us%3B307889&x=12&y=12
Nov 25, 2009 | Seagate 80GB Barracuda 7200.9 SATA s - 8MB...
ASUS P4P800 SE (890552603657) Motherboard Logo
65 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Marvin
Marvin
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
