Question about Lexmark E250dn Laser Printer
Noise from tray and then paper stuck
Hi I have many lexmark printers (e250,e353,e450) in my company , i manage to repair a lot of them but now i m having a problem i can't solve The problem is that after 5-10 pages i hear a noise from tray like smt stuck-unstuck . I hear the noise 2-3 times and then 2 papers stucks both front and back side. Sometimes i print more pages before i hear the noise for first time but when i hear it then it will surely stuck. The rollers seems to work fine Thnx
  • 4 more comments
  • ditroy Feb 14, 2012
    Today I printed 40 pages before the problem occurs. And i was wrong it doesn't always stuck front and back side, it usually wrap the pages front side
  • LXK Chris
    LXK Chris Feb 14, 2012
    When you say you're hearing a noise, is it a clicking sound?and is the noise coming from the back or front part of the printer?
  • ditroy Feb 15, 2012
    yeah it's a loud clacking and it's coming from the front part like a gear .
    I can see the whole tray moving a bit up when i hear the clack. Also i can see some movement in the bypass tray
  • ditroy Feb 16, 2012
    It wasn't so simple :p
    It needs all of them or 1 of them has the problem .
    Thnx for the help
  • LXK Chris
    LXK Chris Feb 16, 2012
    All 3 components need to be replaced.
  • LXK Chris
    Your welcome
    Genius:
  • 1,087 Answers
A replacement is needed for the following parts:
40X2838 Media (ACM) drive assembly40X5930 Media feed ACM clutch CBM40X2853 ACM drive shaft assembly
Please contact Lexmark Technical Support for further assistance.
Posted on Feb 15, 2012
  • LXK Chris
    LXK Chris Feb 15, 2012
    In most cases this has something to do with the printers' pick arm.
    40X2838 Media drive assembly
    40X5930 Media Feed Media feed ACM clutch CBM
    40X2853 ACM Drive shaft assembly
    Please contact Lexmark Techinical Support Center for further assistance
PRINTER SHOWS NO PAPER IN DRAWER
There is a sensor that detects paper just after the paper tray. No matter what is the reason that paper doesn't reach the sensor your printer will indicate that there is "no paper".
You should check is something preventing transport system even to reach the level of paper. In the case of Lexmark E342 or E250 printers, for example, two wheels with black rubbers rotating around common axis are pushing the paper . When you pull out the paper tray the transport system with rollers can be seen from the bottom side of the printer. If the rollers are not laying on the surface of the paper they can not push it inside the printer.
If you are sure that it is not the case the next thing you should check is the rubbers mentioned above. They must be clean enough to have efficient traction with paper. You should take the rubbers off the wheels, wash them with water and soap, rinse them and thoroughly dry. Put them back and try.
Nov 12, 2013 | Lexmark Optra Office Equipment & Supplies
It's jammed
When working with any printer it's inevitable that you'll encounter a paper jam. Below are the steps you'll want to follow when this occurs.
  1. Turn off the printer.
  2. Inspect the location or tray the printed paper ejects to. If the stuck paper is visible manually remove it.
  3. Remove all paper trays and any paper that may be stuck between the tray and the printer. If the stuck paper is visible manually remove it.
  4. Open the printer door that allows you access to the printer ink cartridges or toner and look for any stuck paper. If the stuck paper is visible manually remove it.
  5. Turn the printer back on. If you continue to receive a printer jam error try repeating the above steps again. If issue still persist and you see no paper that is stuck in the printer it's likely your printer is experiencing another hardware issues and we suggest contacting the printer manufacturer for additional assistance and/or repair.
To manually remove paper pull on the paper with both hands being careful not to tear the paper while pulling it. If you're unable to get to an edge of the paper that allows you to pull it you may need to manually rotate the gears that feed the paper through the printer.
Mar 12, 2010 | Lexmark X4530 InkJet Printer
Printer now very reluctant to pick up the paper from the tray, keeps reporting paper jam. Think this could be a problem with the rollers
The printer could be stuck with the paper jam error due to paper still stuck inside the printer. Make sure you check under the toner, in the back of the printer and at the paper tray. If there is still paper jammed then the printer will not go to a ready state. The other problem could be that the printer sensor got damaged after removing the jammed paged. If that is the case then you will probably have to take the printer to a service provider2_bing.gif to fix it. Here is a link with illustration on how to check and removed jammed paper. http://bit.ly/aqUrn7
Feb 15, 2010 | Lexmark E232 Laser Printer
Regular paper jams and printed images are not straight
hi,
follow these steps:-
  2. Inspect the location or tray the printed paper ejects to. If the stuck paper is visible manually remove it.*
  3. Remove all paper trays and any paper that may be stuck between the tray and the printer. If the stuck paper is visible manually remove it.*
  4. Open the printer door that allows you access to the printer ink cartridges or toner and look for any stuck paper. If the stuck paper is visible manually remove it.*
  5. Turn the printer back on. If you continue to receive a printer jam error try repeating the above steps again. If issue still persist and you see no paper that is stuck in the printer it's likely your printer is experiencing another hardware issue and i suggest contacting theprinter manufacturerfor additional assistance and/or repair.
Thanks!
mannu_rakesh
Aug 04, 2009 | Brother MFC 240C All-In-One InkJet Printer
Paper jams
hi,
Thanks!
Aug 04, 2009 | HP PSC 1350 All-In-One Thermal Printer
How do I clear a paper jam?
hi,
Thanks!
Aug 02, 2009 | HP DeskJet 932c InkJet Printer
Paper jams and the light comes on
hi,
  5. Turn the printer back on. If you continue to receive a printer jam error try repeating the above steps again. If issue still persist and you see no paper that is stuck in the printer it's likely your printer is experiencing another hardware issue and i suggest contacting the printer manufacturer for additional assistance and/or repair.
Jul 13, 2009 | Canon MultiPASS MP390 All-In-One InkJet...
Paper will not feed through the printer . . , ''paper jam'' message appears . How can i open the printer to check for a paper jam? I have a Lexmark X83 printer/copier/scanner.
behind the printer there is the tray that can be opened easily to check if the printer is jammed in or the paper feed sensor is stuck up.just open the back tray of your printer and check.
get back if you require more assistance on this.
thanks.
Jul 08, 2009 | Lexmark X8350 All-in-One Plus Photo with...
Printer cartridge stalled
# Turn off the printer.
# Inspect the location or tray the printed paper ejects to. If the stuck paper is visible manually remove it.*
# Remove all paper trays and any paper that may be stuck between the tray and the printer. If the stuck paper is visible manually remove it.*
# Open the printer door that allows you access to the printer ink cartridges or toner and look for any stuck paper. If the stuck paper is visible manually remove it.*
# Turn the printer back on. If you continue to receive a printer jam error try repeating the above steps again. If issue still persist and you see no paper that is stuck in the printer it's likely your printer is experiencing another hardware issue
Feb 06, 2009 | Lexmark JetPrinter Z11 InkJet Color...
First and 4th yellow lights stay on
You should still be able to do a printer test page (press the arrow button).
Look at the printed page(s) for the Photoconductor AND the Toner.
They show as OK when new (or very low count), and 100% when fully used.
It IS ossible that the toner cartridge has a faulty (or if a remanufactured cartridge - un replaced) chip.
Some 'after market' chips are not compatible with E250, and it IS possible that your replacement cartridge is for an E350, or E450 (which have different chips, and some of the poorer remanufacturers , and some reselers that don't do these very often don't know).
It could even be a Dell 1720 chip on the cartridge.
I make around150 Dell 1720, 20 E450, 50 E350 cartridges a month and only around 5 E250s, so this gives you an idea of the relative numbers, in the market
Oct 25, 2008 | Lexmark E250dn Laser Printer
Lexmark E250dn Laser Printer Logo
621 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
