Question about Brother Sewing Machines
My brother xl2620 has stopped sewing! It started missing stitches, then stopped sewing altogether! Help!
MakikiChris
  • 84 Answers
SOURCE: long stitch!!
Hi teza...I assume that you have decreased your stitch length selector resulting in no change, indicating that the internal stitch length mechanism is either insufficiently lubricated, or truly broken If not broken, you can work the mechanism free by removing your needle, selecting the maximum stitch length and any non-overlock stich pattern, ie. straight or zigzag, fully depress your foot pedal so it runs at maximum speed, and methodically press and release the Reverse button/lever. After a minute of this, hand crank your machine while observing the feed dogs, and changing your stitch length. If your stich length is set to 0, your should observe your feed dogs moving vertically up and down with no back/forward motion, however, increasing as you lengthen your stitch length. Repeat the previous high speed work out until you notice full strokes of your feed dog...good luck my friend
Posted on Aug 02, 2007
bargainbox
  • 1388 Answers
SOURCE: stitching looping
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....the question you pose could have 2 meanings....this reply is for looping thread.
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
cc3f045.jpg...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all back properly.
FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes. ie a different colour top and bottom just for the test.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is, and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine case....no case ? then make some sort of cover ! Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistant diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
If you need any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
Posted on Feb 23, 2008
SOURCE: Brother xr-65
This happened to me too! Make sure your buttonholer isn't pulled down and locked in to where it's making the machine sew backward. That's what happened to me.
Posted on Apr 22, 2008
bargainbox
  • 1388 Answers
SOURCE: tension
As this happened mid project, I would pay most attention to check the top tension for lint or thread...........this full process of elimination ought to cover all possibilities.
Ensure that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
TOP THREAD TENSION:
projects).
BOBBIN TENSION:
TOP LOADER:
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
back properly.
165ca5c.jpg FINISHING UP
OTHER ISSUES:
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
Posted on Jun 24, 2008
  • 69 Answers
SOURCE: Brother vx790, my stitches are reversed ( top is on botom & bottom is on top )
It sounds like your tensions are out of adjustment. Your upper tension should be between 3-5 and make sure the tension in your bobbin case is not too tight as well. Pull the thread through the bobbin case and make sure it comes out with a small amount of resistance. If no resistance, tighten the tension just a bit, if too much resistance, loosen it just a small bit at a time.
Posted on Feb 12, 2009
Brother ST371HD Strong and Tough. Problem with SS (Stretch Stitch) setting.
Probably something amiss with your machine. Have you tried other stitches and how do they sew?
Feb 28, 2017 | Brother Sewing Machines
I have brother xl2620 changed thread and now won't pick up thread from bobbin. Have cleaned everything still won't work
Try a brand new needle. Check that the bobbin is loaded and threaded correctly. Change the type of thread you are using--Avoid old or bargain bin variety. If these recommendations don't help, the machine may need its timing fixed. Search for sewing machine timing or take it for service.
Feb 09, 2017 | Brother Sewing Machines
Where can I find this board model#XE 7316001 for a brother CE 1100PRW computerized sewing machine?
somewhere like this or direct from Brother
http://www.brother-usa.com/homesewing/
Brother - Machine Accessories (feet, needles,globes,spare parts ...
www.sewingmachinewarehouse.com.au/machine...needlesglobesspare-parts/brother/
  1. Cached
  2. Similar
Sewing Machine Warehouse are authorised dealers for Pfaff, Singer, Brother, ... Parts and Accessories to suit Brother Machines. ... 7mm- For machines with a 7mm stitch width (feed teeth are set wider) ... Brother Open Toe Free Motion Foot. Missing: ce ‎1100prw
Brother Sewing Machine Parts & Brother Serger Parts
www.sewingpartsonline.com/brother-sewing-machine-parts-model-list.aspx
  1. Cached
  2. Similar
We have a very large selection of genuine and replacement Brother Sewing Machine & Serger parts available. If you can't find the Brother Part(s) you are ... Missing: 1100prw
Brother Sewing Machine Parts ' eBay
www.ebay.com/bhp/brother-sewing-machine-parts
  1. Cached
  2. Similar
Find great deals on eBay for Brother Sewing Machine Parts in Machine Parts and Attachments for Sewing. Shop with confidence. Missing: 1100prw
Sewing Machine Parts warehouse all Singer Brother Janome Pfaff ...
www.sewingmachinesales.co.uk/sewingmachineparts/
  1. Cached
  2. Similar
Suppliers of sewing machine parts attachments and accessories for Singer Brother Janome Paff, Toyota and Husqvarna sewing machines or overlocker spares. Missing: ce ‎1100prw
Sewing Machine Accessories & Spares ' Janome, Brother, Elna, Pfaff ...
https://www.gursewingmachines.com/sewing-spares-accessories
  1. Cached
Sewing Spares & Accessories: UK's biggest dealer of Sewing Machine Parts, Needles, Sewing Foot and all ... CE 5500, 8080. ... At GUR we have sewing feet for Brother machines and all styles of sewing, have a look at our invisible and ... Missing: 1100prw http://www.brother-usa.com/homesewing
Nov 20, 2016 | Brother Sewing Machines
How do I get it to sew?
was the presser foot lowered? check if the loop-taker is properly installed or seated.
Oct 03, 2015 | Brother XL2600I Sew Advance Sew Affordable...
E1 flashes on the message window of my brother sewing machine
Brother Computer Codes
  • E1: Make sure the presser foot is lowered before sewing.
    E2: You chose a stitch other than a buttonhole stitch or a bar tack stitch and you tried to sew with the buttonhole lever in the lowered position. Raise the buttonhole lever.
    E3: If you selected the buttonhole or tack bar stitch and start to sew with the buttonhole lever raised, you will get the E3 code. Lower the buttonhole lever.
    E4: You hit the reverse button while the bobbin winder shaft was moved over to the right. Move the bobbin winder shaft to the left.
    E5: On automatic sewing machines, the start/stop button was pressed while the foot controller was plugged in. Unplug the foot controller if you are using the automatic function.
    E6: This code tells you that the motor locked up because the thread is tangled. Untangle the thread, make sure the machine is threaded properly and that the proper tension is set before continuing.
Oct 03, 2012 | Brother CS-6000
I keep missing a stitch
Skipping stitches can be caused by a bent or dull neeedle or a needle that is not suited for the fabric you are sewing on.
Feb 08, 2012 | Brother LS-2125 Mechanical Sewing Machine
Where can I buy a foot pedel for Brother XL2620 in the code area of 3095?
Try:
http://www.sewingpartsonline.com/brother-xl2620-sewing-machine-parts.aspx
or you could try a local sewing machine repair shop for twice the price.
May 14, 2011 | Brother XL-2600
Se270d brother sewing machine
It is easier to use the help menu and forward search through to the color you stopped at the use the your forward button to go stitch by stitch till your where you need to be.
Nov 24, 2007 | Sewing Machines
Sewing Machines Logo
56 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
