I need a manual
I have forgotten how to use, after a long time without use
I need to break the pin on my sons phone is there anyway i can do this without erasing everything it is a samsung galaxy express 3
there is nothing in the user manual to unlock if the code is forgotten other than to take it to samsung service center to reset it
to reset it any other will wipe all data clean
Dec 03, 2017 | Samsung Cell Phones
Tip
Toshiba 42HP95 VChip Reset
Toshiba 42HP95 Plasma TV VChip Reset
Would you like to bypass, defeat or reset your Toshiba 42HP95 Plasma TV Parental V-Chip parental lock?
Have you forgotten your VChip PIN, passcode or password?
If you forget your V-Chip passcode, you can view the locked TV without entering your password:
  • When your PIN is requested, simply press RECALL four times withing five seconds.
  • The VChip passcode will be reset and you can enter a new passcode if desired.
I hope that helps.
________________________________________
Download Toshiba 42HP95 Plasma TV Manual
on Jul 03, 2010 | Televison & Video
Tip
Toshiba 50HP95 VChip Reset
Toshiba 50HP95 Plasma TV VChip Reset
Would you like to bypass, defeat or reset your Toshiba 50HP95 Plasma TV Parental V-Chip parental lock?
I hope that helps.
Download Toshiba 50HP95 Plasma TV Manual
Tip
Toshiba 50HP95 Channel Block Reset
Toshiba 50HP95 Plasma TV Channel Block Reset
Would you like to bypass, defeat or reset your Toshiba 50HP95 Plasma TV channel block?
Have you forgotten your channel block PIN, passcode or password?
If you forget your channel block passcode, you can view the locked channels without entering your password:
  • The channel block passcode will be reset and you can enter a new PIN if desired.
I hope that helps.
Tip
Toshiba 50HP95 Input Lock Reset
Toshiba 50HP95 Plasma TV Input Lock Reset
Would you like to bypass, defeat or reset your Toshiba 50HP95 Plasma TV Input Lock?
Have you forgotten your Input Lock PIN, passcode or password?
If you forget your Input Lock passcode, you can view the locked input without entering your password:
  • The Input Lock passcode will be reset and you can enter a new PIN if desired.
I hope that helps.
I have Samsung Galaxy Precedent and I've forgotten my password and I was wondering if there was any way to unlock it without having to spend a large sum of money? Please help? :(
call the phone company and they will either unlock it for you or have u come into the store to get it fixed. DO NOT KEEP TRYING TO UNLOCK IT. if u try to many times, you will completly get locked out and will have to get a brand new sims card
Nov 03, 2012 | Cell Phones
I have forgotten the code for my code lock which is on my bedroom door.
Here is the "literature grid" from the KABA website, which has manuals and parts lists for the
Simplex mechanical pushbutton locks:
http://www.kaba-ilco.com/access_control/literature/literature_grid_mechanical_pushbutton_locks.
aspx?id=13
You'll need Adobe Reader installed, as these are PDF files. The manuals show installation and reprogramming instructions.
You can also research other models of locks from this page.
Dec 09, 2010 | Simplex Kaba Ilco Unican 1011 keyless...
Forgotten the password , without it coputer wont boot
Sounds like you have set a password in the BIOS. If you have forgotten the password then you will need to reset the BIOS settings to their default. This is usually done by setting a jumper on the motherboard. You are going to need to get your motherboard's manual and find the BIOS Reset jumper switch. Once you set this jumper properly, the settings in the BIOS will be reset to their default values.
Oct 05, 2008 | Packard Bell Computers & Internet
k24674
jasbo
jasbo
