Question about Samsung C5510 Cell Phone
Samsung C5510 white screen
Screen is white when turned on. Have taken battery out etc, still white.
  • 1011 Answers
SOURCE: screen turned white
dear,
the strip that connects the keypad with the other circuitry is damaged. you need to repair it or replace it...it will be checked by an expert technician of mobile that either it is to be replaced or repaired...
flip and slide mobile have this kind of problem..moreover, it depends upon the usage of phone for flip/slide...
don't use it roughly, next time , it needs a lot of care..
good luck..
Posted on Sep 07, 2009
SOURCE: Phone keeps turning on and off
mine does the same thing it has continued doint this for almost a year and there is no solution ive been searching everywhere
Posted on Oct 17, 2008
SOURCE: Samsung SCH-a870 turning off and on
i have the same deal with the metropcs and it turns on to load and then it turns off
Posted on Oct 31, 2008
  • 155 Answers
SOURCE: Samsung SGH-t629 turns the screen white
Hi
The problem you are experiencing can either be virus or has to do wtih the flex of your phone.You need to first scan your phone for virus and if it is virus free then you need to open your phone with a phone screwdriver and check the flex if it is intact adjust the flex properly and couple back your phone.If it does not work after that then you would have to replace the flex of your phone.
BEST OF LUCK
Posted on Jun 27, 2010
walesarumi
  • 6993 Answers
SOURCE: JUST KEEPS GOING FROM BLUE
There are two thing involved; it's either your screen/flex is have a problem or your phone's operating system is corrupt. You will get to figure out which is the problem when you read further.
When a phone screen is blank, has a white screen, etc, there are three things that could be the cause;
  1. Bad/defective screen and the solution is screen replacement
  2. Software/Virus problem and solution is to flash the phone
  3. Flex problem and solution is to change the flex. In some cases the flex might have shifted or not in it's right position, in this case, just fix the flex back properly and all will be well.
Bad/defective screen:
If your phone is having a white screen, first thing to do is dismantle the phone carefully, check if the screen is properly fixed to the phone board, also check if screen flex is intact. Once you've confirmed that all these are okay and screen is not still coming up, then it means your screen is bad. You can go ahead and replace the screen.
Make sure you confirm the screen is bad before you do any replacement.
Software/Virus:
Sometimes software/virus problem on phones are mistaken to screen problem. When a screen is white or blank, sometimes it's a virus problem. To further confirm, turn on the phone, wait for about 2 minutes when you know the phone must have booted fully, then use another phone to call the phone with white or blank screen. If the phone rings, it means it's not a virus problem, but if it doesn't ring, it means it's a software/virus problem.
If you discover your phone has a virus problem, you will have to flash the phone for it to display again,
Flex problem
When your phone screen is blank, white, has horizontal/vertical lines, turn images up-side-down, etc, be calm, there is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out, that's why your screen is acting like any of the mentioned problem.
This is usually common with flip and slide phones. The flex worn out as a result of constant opening and close of the flip or slide phone. Samsung and Motorola phones mostly have this kind of problems.
Replacing the flex is the only solution to this problem. If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be replaced.
When you figure out what the problem is, please let me know so that I may direct you further.
Regards.
Posted on May 16, 2011
My samsung GT c5510 phone is locked. Need to unlock phone however when I try to get the IMEI number it tells me IMEI not active. How can I get this number?
Pullout your battery and look closer at the back.. should be there in plain text. That's on the phone not on the battery.
May 08, 2011 | Samsung C5510 Cell Phone
My Samsung GT-E2120 phone won't work. When you turn it on all it does is display GT-E2120 SAMSUNG and then it just blinks - display/black screen/display/black screen etc. Then it won't turn off - the only...
My Samsung GT-E2120i phone won't work. When you turn it on all it does is display GT-E2120 SAMSUNG and then it just blinks - display/black screen/display/black screen etc. Then it won't turn off - the only way to stop it is to remove the battery.what do I do to solve this?
Oct 27, 2010 | Samsung Eternity Cell Phone
My samsung impression won't turn on anymore. it has the start up screen, then freezes in the middle of its 3G flying segment and shuts off again. i've taken out the battery and put it back in, have tried...
My Samsung Impression turns off after I turn it on and the screen turned red and now blue and the screen is fuzzy. I never got it wet and the sticker is white, not red. Please help. Thanks.another thing is that when I used to call people the only way I could hear them is if I put it on speaker.
Jan 08, 2010 | Samsung SGH-A877 Impression Cell Phone
White screen
we need help with the camera
we cant see the screen,
it turns on, but we cant see the screen
Jul 31, 2008 | Samsung Digimax A402 Digital Camera
Samsung d500 screen not working
Hija!!
I have the same problem! (white screen)
And I've red some forum topics, and found the medicine of this. If you take off the battery and whack it to a table or just with your fingers (little bit hard) on the battery side of the telephone, and after it, you switch it on, it will works!!! It works with my phone, but i think?it's just a temporarly solution! flex cable change is the really good choice i think!
so jhust bang your mobiles back some times, and see, that it works. Belive me!:)
Hi, Johi!
Mar 15, 2008 | Samsung SGH-D500 Cellular Phone
Samsung S73 batteries
i am having the exact problem as you are having have you figured anything out? Thanks!
Dec 27, 2007 | Samsung Digimax S730 Digital Camera
Oct 14, 2007 | Samsung SCH-a870 Cellular Phone
Samsung Digimax S500
Whit screen means A. connector has come adrift from the main board. or B. Component failure on the main board. If A. try to restore by gently tapping and squeezing the casing around the base of the screen this may get it back. Do get on to the Samsung Tech Support team - in case this is a known issue. An out of warranty repair is not a likely scenario however.
Jul 09, 2007 | Samsung Digimax S500 Digital Camera
Samsung C5510 Cell Phone Logo
225 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
